The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > MacCar
Thread Tools Display Modes
Old 07-04-2008, 02:12 PM   #1
Vehicle: 2000 Toyota 4Runner
My Photos: (1)
'No Signal' on wake from Sleep
I've got a Xenarc screen hooked to an Intel Mac Mini using DVI. When the Mac boots up it works great with the screen, but when the Mac goes to sleep (on engine shutoff) and then wakes up the screen will show 'No Signal'. The only way I can seem to fix it is by rebooting.
Anyone else run into this?
Thanks,
Sean
hammer32 is offline   Reply With Quote
Sponsored Links
Old 07-04-2008, 08:37 PM   #2
My Photos: (0)
does it turn back on if you press the power button? if not it might be similar to my problem.
I had my xenarc mounted without the back casing, and it wouldn't auto on properly, then i replaced the back casing and it turns on/off perfectly everytime.
Punky is offline   Reply With Quote
Old 07-04-2008, 09:04 PM   #3
My Photos: (1)
The other inputs on the Xenarc continue to work. If I power cycle the Xenarc the DVI connection to the Mac still says "No Signal", but If I power cycle the Mac then it works again.
I'm thinking there is a signal that the Mac sends via DVI on startup that is not sent on wake...
Old 07-05-2008, 11:13 PM   #4
My Photos: (0)
Having no experience with the Xenarc screen, this may just be a shot in the dark...
I've had similar problems with projectors over the screen set to "auto-source", in my experience there are a few things that you can do to "fix" this.
Easiest: Turn auto-source "off". If you then leave it set to the desired input (DVI), it should be fine.
On some newer projectors (and possibly your Xenarc), there is a setting called "Source Threshold" (or something comparable). You can lower/raise this to help with "detection". On a projector, sometimes bright "flashes" (eg explosion during a movie) will cause the projector to switch sources. To compensate, you raise the threshold. Conversely, if the threshold is too high, it won't properly switch.
I don't know if this helps you at all, but figured I would share just in case.
hanzov69 is offline   Reply With Quote
Sponsored Links
vB code is On
Trackbacks are Off
New OBDII scantool - Beta testers? tmort Engine Management, OBD-II, Engine Diagnostics, etc. 173 01-08-2008 06:44 PM
weak HD signal tuning Lithoss BoomzBox HD 4 10-15-2007 11:17 PM
Hibernation / Resume issue with PhoCo zorro Centrafuse 15 10-09-2007 01:21 AM
Reconnect on loss of signal ric355 Map Monkey 12 03-03-2005 03:41 PM
FS: LCD Controllers - $90.00+shipping infrared Classified Archive 98 07-20-2003 08:30 AM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
