Go Back   MP3Car.com > Mp3Car Technical > MacCar
Old 07-22-2008, 09:03 AM   #1
Machinehead's Avatar
Machinehead will become famous soon enoughMachinehead will become famous soon enough
Dead Optical Drive
The optical driver on my Mac Mini has died. It was acting flaky over the last 2 weeks and now I can't boot from it or get it to show up in the OS. It still works mechanically as in ejecting and accepting discs though.
I'm past the 1-year warranty, I bought the Mini in May of last year.
Any suggested vendors to buy a replacement from?
Also, could it be the controller rather than the drive?
Machinehead is offline   Reply With Quote
Old 07-22-2008, 09:26 AM   #2
Admin. Don't bug or I'll byte.
Bugbyte's Avatar
Bugbyte is a splendid one to beholdBugbyte is a splendid one to beholdBugbyte is a splendid one to beholdBugbyte is a splendid one to beholdBugbyte is a splendid one to beholdBugbyte is a splendid one to beholdBugbyte is a splendid one to behold
I've only ever had the regular DVD drive quit on me, not the slot load. Replaced that one at Circuit City.
Want to:
-Find out about the iBug?
-Stop being a newbie? Take a look at the FAQ Emporium?
-Help me kill my car PC
-Watch live video streams from my mobile PC? Check it out here.
-Where is the iBug?
Bugbyte is offline   Reply With Quote
Old 07-22-2008, 09:30 AM   #3
I probably should open the case and re-seat the drive to see if it's just loose. It's not really acting like it's loose though.
Old 07-23-2008, 11:23 PM   #4
golfguy's Avatar
golfguy is an unknown quantity at this point
Other World Computing has replacement slot-load SuperDrives for under $100. I'm sure you can pick up DVD/CD-RWs for much less than that. They're not hard to replace in the Mini.
Any day is a good day for golf.
Mazdaspeed6 Carputer Progress: Gone
(Check Speedy's Install)
Speedy was traded for a 2004 350z - installation will commence Any Day Now
golfguy is offline   Reply With Quote
Old 07-24-2008, 07:33 AM   #5
I found a couple other vendors as well.
And yes, changing the drive isn't too hard. Taking the case apart is probably the hardest step in the process and that's too tough, a little tricky maybe.
Old 07-25-2008, 10:13 AM   #6
roseforeplay is an unknown quantity at this point
There are many places you can find a replacement optical drive. I would recommend making sure it is the same manufacturer and the preferrably the same model. I have worked with many Macs, a lot of the minis, and in my experience the drive has to be the same model and come from an equivalent machine.
If need be I can point you to some websites I've used in the past to get replacement parts for Macs.
roseforeplay is offline   Reply With Quote
FAQ: How to install a DVD R/RW in your Xenarc 700IDT cdcamaro9534 The FAQ Emporium 28 12-10-2007 01:34 PM
Slim dvd drive problems. JAE 50pin to IDE at fault? 2k1Toaster General Hardware Discussion 17 08-16-2007 05:06 PM
Hard drive shock / vibration thoughts S11D336B General Hardware Discussion 60 09-27-2006 12:40 AM
MB870 & Slimline Floppy Drives McGreggor General Hardware Discussion 5 11-09-2005 07:32 AM
2.5" drive help? IntellaWorks General MP3Car Discussion 4 10-03-2005 08:36 AM
