Go Back   MP3Car.com > Mp3Car Technical > MacCar
Old 06-26-2009, 06:47 PM   #1
demonspeeding is an unknown quantity at this point
Question Newbie Installing in a '97 Celica GT-Four
Hi guys,
I've been trawling these forums for the last few years. I finally have a car I think it's worth spending some money on so I have an ICE guy fitting the Mac Mini on Monday. I know very little about electronics and I don't want to do anything stupid to the car as I only bought it a week ago so I figured I'd leave it to the professionals.
Hardware:
Intel Mac Mini
Lilliput 629GL-70NP/C/T (2008) 7” Touchscreen
Carnetix CNX-P1900 V2.2 PSU
Carnetix MacPac Power Cable Kit
4-Port Belkin Powered USB Hub
Griffin Powermate in Silver (although I will bite your hand off for a black one)
GlobalSat BU353 USB GPS Receiver SIRF III Waterproof
Roll-Up Keyboard (in case it's needed)
3.5mm to L&R Phono Adapter
2x Phono to 2 Phono Adapters
2 Channel Amp (for Fronts)
3 Channel Amp (for Rears and Sub)
10" Sub
Software:
Mac OS X 10.5.7
DisplayConfigX
Hear
ICE3
VMWare Fusion / Windows 7 / PC Navigator 9 UK
The guy who's fitting it usually installs standard stereos and media units, he's never fitted a Mac Mini before. He was a little confused when I said I was going to be running the audio out of the Mac's headphone jack. I've read through the forums and it seems like it should be fine to go:
Mac Headphone Jack > 3.5mm to L&R Phono > 2x Phono Splitters > 4x Phono Leads
Have I misunderstood what you guys have said or should I be okay with that setup?
demonspeeding is offline   Reply With Quote
Advertisement Sponsored links
Old 06-29-2009, 02:27 PM   #2
Machinehead's Avatar
Machinehead will become famous soon enoughMachinehead will become famous soon enough
Sounds quality is only thing I'll caution you about. What you're proposing will work, if it sounds good or not is the question. You can always try it and if you aren't happy with the results find a better solution.
Edit: You're going direct from the Mac to your amps right?
Machinehead is offline   Reply With Quote
Old 06-29-2009, 07:21 PM   #3
Thanks Machinehead. I am indeed going directly to the Amps.
Phase one went in today, as I'm waiting for the three channel amp and my new 12" shallow sub to arrive.
I also neglected to order the 5v add on for the P1900 as I thought it was part of it. So I haven't got the hub in yet and I have to manually disconnect the USB devices before switching off the ignition. It's been ordered though and should arrive fairly shortly.
I'm impressed with the sound so far. The previous owner fitted nice aftermarket speakers so even with only the fronts connected the output is pretty good. I'll post up some pics once it's all in.
Old 06-30-2009, 10:43 PM   #4
Relientone is an unknown quantity at this point
this should work as long as the speakers are wired to the right amps, right? I have a 4 channel amp for my speakers and a mono amp for 2 10" JL w3's it works like a charm.
On a side note, is the 97 a 5th gen? a 5th gen celica is the only one I have liked, maybe a 6th gen but my friend has a 6th gen convertible and I don't like the soft top...Especially in Washington state where it rains some 200+ days a year I think.
Relientone is offline   Reply With Quote
Old 07-01-2009, 01:03 AM   #5
natedawgg is an unknown quantity at this point
IMHO the sound output straight from the mini is fine. the sound quality can be hurt or helped anywhere down the line. for instance in my car i am running straight from the mini into a secondary amp that jumps the signal high enough to be pushed into my factory amp, everything sounds great unless i get a low bitrate mp3. Of course you can always get a usb sound card that can make that output much better. from what i hear maudio makes a good one. good luck with the install. post some pics once you get it together.
Check out the new version of NAS, a cross platform music frontend here
natedawgg is offline   Reply With Quote
Old 07-01-2009, 03:30 AM   #6
Thanks for all your help guys!
Quote: Originally Posted by Relientone View Post
...On a side note, is the 97 a 5th gen?
One of the last of the 6th Gen ones. In terms of looks the GT-Four has a more aggressive front end and generally a big spoiler at the back (mine doesn't but it's on the shopping list).
Install looks like this so far:
Mac Mini is squirreled away here:
Old 07-01-2009, 11:13 AM   #7
Or firewire...
pics
That's a nice screen install. Very Clean.
Old 07-01-2009, 11:36 AM   #8
colin's Avatar
colin will become famous soon enoughcolin will become famous soon enough
Looks good, nicely installed.
However, it seems your car is backwards?? Steering wheels are supposed to be on the left side! When will you guys get it right?
2001 Mustang Convertible Worklog
Indigo Custom Frontend (Flash/Delphi)
Blog
Code:
Currently: - Working on my new product! Wiring: |■■■■■■■■■■■■■■■■■■--| Trunk: |■■■-----------------| Sound: |■■■■■■--------------| Screen: |■■■■■■--------------|
colin is offline   Reply With Quote
Old 07-06-2009, 02:21 PM   #9
I shot a quick video of the interface today although I'm sure you guys all know what ICE3 looks like: Link to video.
What settings should I be putting into DisplayConfigX for my screen? I'm using the ones from this thread but it still seems a bit off, as though the image is slightly wider than the screen. Any ideas?
97 Celica Carpc... 1st post be gentle! Gaer Newbie 8 06-18-2009 12:21 AM
I need help installing a CD/MP3 deck on my 97 Neon Mic4 Car Audio 15 04-30-2006 01:30 AM
Custom log parsing automation… xcntrk75 Software & Software Development 4 05-11-2005 03:19 PM
Lilliput LCD, 2000 Celica GT and voltage problem Goose LCD/Display 15 12-29-2003 05:53 PM
1990 Celica GT - New Install HereFishyFishy Show off your project 16 09-08-2003 01:15 AM
Content Relevant URLs by vBSEO 3.3.0
"VaultWiki" powered by VaultWiki v2.5.2.
Copyright © 2008 - 2009, Cracked Egg Studios.Ad Management by RedTyger
