^^Here are my Install advice with the CNX1900 and MacMini
What I'm using:
- MacMini (intel)
- CNX1900 latest firmware and last board version
- MacPac Wire for Mini (mp3car.com store)
- Xenarc 700TSV
Right now I'm still in the testing mode but everything works perfectly.
Here's how I tested my install...
Battery12v 4G cable ---> Both 12v Carnetix Input
Car Frame ---> Both GND Carnetix Input
IGNITION Wire take power from the 12v coming from the battery --> 2 state switch --> Yellow cable Input Ignition
Here's a good Idea coming from CNX
My Carnetix is setup for 12v (J2) and J5 which control the secondary output, is set to 12v for now...as I want to power my Xenarc.
Primary output:
MacPac Output ---> MacMini power port
---> PowerButton Y cable
Secondary output (12v):
Brown = Positive
Black = Negative
So those two wires will go to my screen when I receive the prewired plug for my TSV. Not sure if there's one for the lilluput though...you'll have to check.
**MAKE SURE TO RTFM BEFORE PLUGGING ANYTHING, espacially if your going to wire your liliput with the CNX1900** If you don't set the jumpers right, you will fry your CNX (clearly mentioned in the manual)
HOPE THIS HELPS!
