The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > MacCar
Thread Tools Display Modes
Old 10-06-2004, 01:10 PM   #31
Vehicle: 05 Acura TL 6sp Navi
My Photos: (0)
Quote:
Xenarc does not require you to hook the screen up to a regulated 12 volt source, it regulates itself. This is why it comes with a cigarette lighter adaptor to tap into the cars unregulated supply.
god_of_cpu:
Thanks. I've updated my post. Sorry for the bad info. I took a look at the Xenarc website today. Looks like the screen features have changed a good bit since I bought mine.
-TJ
tejesh83 is offline   Reply With Quote
Sponsored Links
Old 10-06-2004, 01:43 PM   #32
sdashiki's Avatar
Vehicle: 2003/Toyota/Matrix
My Photos: (0)
Quote: Originally Posted by MatrixPC
It's nice to see a Mac as CarPC, but also bad to use VPC to run Window$ apps.
But if there is no app available and VPC is the only alternative. What can you do.
We can probably do nothing. Its getting someone else with skills to do it.
(----) 0.0%
No more loot for the carpute.
Trying to fit my 20" iMac into the dash... RF 600.5 amp, two 10" JLW0, 8 Infinity Components
sdashiki is offline   Reply With Quote
Old 10-06-2004, 02:20 PM   #33
gutterslide's Avatar
My Photos: (0)
Quote: Originally Posted by IntellaWorks
Ok, I can see your argument. But mac has to be able to run any software from any platform in order to stay competetive.
yes, that might have some shred of truth to it if Apple made the VPC software. do you know who makes Virtual PC for Mac? ...Microsoft! so who has to stay competetive here?
dude, atleast google before you speak.
I can't agree with your hardware claims though, especially when you say that mac runs more efficiently when compared to EPIA boards.. Have you ever looked at the G5 towers heatsink ?? (that thing creates a LOT of heat) It needs two power supplies 1 for the 7 40mm+ cooling fans and the 2nd to power the system.
Afterthought::
I might be comparing APPLES to ORagnes (HA) putting a g5 next to a EPIA systemboard.
apples & oranges... are you honestly comparing the power usage of a $2000+ dual-processor G5 workstation (which outperforms every PC available, including dual-Xeon) to a $150 all-in-one mini-itx motherboard??!
dual 1.8GHz (minimum) vs. single 1.2GHz (maximum) hmm.. i wonder which one has a higher power consumption and produces more heat.
next time, instead of typing out your afterthought, use the backspace key. it will save you some embarassment.
gutterslide is offline   Reply With Quote
Old 10-06-2004, 02:27 PM   #34
slffl's Avatar
My Photos: (0)
Main reason I'm switching my CarPC to a CarMac? Because it can goto sleep and wake up in 2 sec. As opposed to the 30-60sec it takes for Windows.
slffl is offline   Reply With Quote
Old 10-06-2004, 02:47 PM   #35
My Photos: (0)
wow i give you props for using a mac.
Im not a pro at macs(although i remember good times playing prince of persia 1 =p) but i always thought macs were a bad choice to put into cars since it seems to be relatively low choices for parts and size for that matter.(again im not flaming but this is to my knowledge only, which is pretty limited) which i think is why PCs are so much better choices for carputers but that is merely just an opinion.
btw do you plan to house the case in the trunk?
anyways looking good and please post some pics when your done! Good luck!
tdevil is offline   Reply With Quote
Old 10-06-2004, 04:43 PM   #36
My Photos: (0)
PC magazine seems to think they're neck-and-neck. Ironically, this URL was retrieved from google.
Results G5 vs. Dell 650(bold is better)
Brian Cozzens
Duke Nukem Forever / Max Payne
www.3drealms.com
Whaleboy is offline   Reply With Quote
Old 10-06-2004, 05:31 PM   #37
sdashiki's Avatar
My Photos: (0)
Are you people that flaming mad at this apple vs M$ crap that u honestly believe anyone today would but a G5 in their car? Impossible. My god look at it, no way. Every mac carputer would be done with any g4, imac or graphite tower dont matter. The G5 the way it is, and probably anything that would come after todays processors, would run too hot for a carputer and probably involve alot of internal parts to keep it working right, like the G5. A G4 though is perfect, just a MOBO, some IDE cable and the PS, simple.
Comparing apples to oranges aint right in this sense, G5 vs any mini-itx or the like is crazy. Cost is just an afterthought when u consider everything else hardware specific to each. A G4 is comparable to any P3 or less and maybe even crappy P4s. Cuz when it comes down to it, MP3 playback and everything of that sort does play smoother and more integrated into the core OS than windows.
Yeah M$ now makes VPC but thats better, instead of connectix asking for the source code, its just there for the taking. The newer and newer VPCs that come out in the future should be much better than ever seen before, but it takes time. BUt in the end NO ONE with a carMac should run VPC, dont be a dork.
(----) 0.0%
Old 10-06-2004, 06:57 PM   #38
My Photos: (0)
yes, PC Magazine did think that... almost a year ago. that data is comparing the dual 2GHz G5 to a dual 3GHz Xeon. of course that Xeon setup outperforms the G5, it's 1GHz faster x2.
try comparing the dual 2.5GHz G5 to a comparable dual Xeon setup, like the dual 2.4GHz and the data looks more like this... http://www.barefeats.com/pentium4.html
the 2.5GHz G5 even keeps up with the 3GHz Xeon.
Old 10-06-2004, 10:39 PM   #39
My Photos: (0)
Every nerd in the world knows different clock speeds for different Architecture.
Since the Xeon gets less performance per clock tick than the G5 (and opteron) i.e longer pipe, different type of architecture, a higher clock speed would be required for fairly comparing Xeon's to the G5s.
One test noted, "In fact, under heavy enough workloads there is virtually no performance difference between a 3.2GHz Xeon and a 2.2GHz Opteron (x48). It isn't until you move to 4-way configurations that AMD's platform architecture begins to flex its muscle."
Now the Opteron's are different, you're safe to pull the equivalent clock speed and it will be close to fair.
It's a real shame thats only a 2.0 Opteron in those tests and not the 2.4.. Which as you see the 2.0 closely keeps up with the 2.5 G5 as is. The Opteron is the one thats causes the 2.5 G5 to fold like a delicate house of cards.
And to think to get all that performance out of the G5 required liquid cooling.
messy.
Of course, the real issue here is the claim Apple/IBM holds the grail for fastest PC. This is something that changes all the time, and though IBM did real good with that processor of theirs, and alot of its architecture is most impressive, it didn't ship fast enough to meet it's marketing hype.
But then again, technology always changes and so does the winner. We know which platform has the most 2nd/3rd party support - the majority has spoken.
Those that want to not conform to the mold may do so at their whim. It makes no difference to me as I use both.
Brian Cozzens
www.3drealms.com
Old 10-06-2004, 11:31 PM   #40
My Photos: (0)
xp on any reasonable hardware typicall doesn't take 60 seconds to *boot*. pc's come out of sleep in a matter of seconds as well. they also support hibernate, which os x doesn't.
edscholl is offline   Reply With Quote
Sponsored Links
Old 10-07-2004, 12:25 AM   #41
sagekoala's Avatar
Vehicle: 1999 Ford Contour
My Photos: (0)
Quote: Originally Posted by GWRedDragon
EVERYONE knows Macs are better for multimedia. Mp3=multimedia.
in what way are they better? perhaps someday i will find someone with an answer... and fyi multimedia = multiple kinds of media. mp3!=multimedia
has anyone looking into trying to get headunit to run on osX or even a ppc linux distro?
don't worry i know i usually don't make much sense
sagekoala is offline   Reply With Quote
Old 10-07-2004, 12:39 AM   #42
ppgt94's Avatar
Vehicle: MKIV VW Jetta
My Photos: (0)
I think that was meant to be kinda tongue-in-cheek.
ppgt94 is offline   Reply With Quote
Old 10-07-2004, 07:44 PM   #43
GWRedDragon's Avatar
Vehicle: 1991 Cadillac Sedan Deville
My Photos: (0)
Exactly
GWRedDragon is offline   Reply With Quote
Old 10-10-2004, 10:59 PM   #44
Vehicle: '06 Mini Cooper JCW
My Photos: (0)
1) what about your system makes it the ultimate? without any screenshots one can only assume that not only is every feature you list implimented on pc, but it probably does a better job of it. especially when you don't have anysort of ui (please no bs, i want a solid answer.)
2) why is a mac a "more suitable multi-media computer" than an epia or for that matter any other board?
3) you say that your mac can "run any software on ANY playform" (i assume you mean platform) can your mac make my athlon 64 run OS9?
4) i would also like to see numbers stating that a system similar to yours runs more efficently or has better power management.
1) I say it's the ultimate, becuase its mine! See attached pics below. I'm not saying the Mac is better because of software features; it's because of the OS X GUI and OS compatibility. I can use my fingers to access files, folders, applications, and etc. All with ease. Although my touch screen works in both MAC OS X and XP, XP is not touch screen friendly. OS X is!
2) Because the G4 mobo (even in standard configuration) is extremely versatile. Expansion: 1 AGP, 3 PCI, 2 USB, 3 FW, ATA HD, Airport Card (PC Card), audio in, audio out, 4 RAM PC100 up to 2GB, and 56K modem... and that's just on the mobo. EXPANDABILITY and QUALITY!
3) Point being, Macs can run other applications from a plethora of other platforms, whether it be from Win 98, Win 2000, XP, UNIX, LINUX, C, C++, Objective-C, or even JAVA (Xcode, OS X native). Why on earn would I (let alone anyone) even want to use an Athlon 64 to run OS 9? OS 9 is OLD!
4) Unfortunately, I don't have numbers. However, I do have a professional quote from a very reputable company. Since my mobo was unique, I went to OPUS for my power solution. I sent them my mobo with my video card and 512 RAM. This is/was the first power supply for Mac OPUS ever made. After about a week, I was called back by OPUS technician (I believe there's only one and he's a great guy) and we spoke at length about the Mac. He went on to say, and I quote "this mobo is by far the most efficient and impressive he has ever seen or worked on". Now this is obviously not with 1.4GB of RAM, nor is it a G5. This was simply a stated fact from a professionally certified technician. Argue the semantics of it all you want, but it is what it is.
MacGuru is offline   Reply With Quote
Old 10-10-2004, 11:13 PM   #45
My Photos: (0)
Pics...
Sponsored Links
vB code is On
Trackbacks are Off
Sept. 5th, Maryland Washington Virginia Meet god_of_cpu MP3Car Gatherings 65 06-23-2007 07:35 AM
So Cal San Diego meet? Walleye MP3Car Gatherings 6 10-20-2004 05:32 PM
The Ultimate UK Meet? Jamez_Warner MP3Car Gatherings 186 10-03-2004 03:59 PM
NY/NJ meet ill_ace MP3Car Gatherings 115 08-29-2004 12:36 AM
Portland OR Meet, August 28th SiGmA_X MP3Car Gatherings 11 08-28-2004 05:39 AM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
