Go Back   MP3Car.com > Mp3Car Technical > MacCar
Old 06-15-2005, 11:54 AM   #31
FociMan's Avatar
FociMan is on a distinguished road
The screen mount looks awesome. I have some friends with a new mini, so I'll be trying to talk them into having an install...
FociMan
Ford Focus Collection
EPIA M10K / 512Kb / Creative Audigy NX USB
8" touchscreen
D-Link USB Radio
USB GPS Mouse
Bluetooth GPRS Web Connection
Centrafuse Beta2 / MapMonkey
FociMan is offline   Reply With Quote
Old 06-15-2005, 01:51 PM   #32
NikolauZi is on a distinguished road
hi there,
nice idea of placing the monitor. can you give me the bmw part number for the cupholder so i can order it here in austria?
thanks,
markus
NikolauZi is offline   Reply With Quote
Old 06-16-2005, 03:12 PM   #33
Phiber is on a distinguished road
51-16-0-300-878
for Anthracite
Phiber is offline   Reply With Quote
Old 06-22-2005, 08:27 AM   #34
defender90 is on a distinguished road
Did you see this Mini in a Mini?
mac2go
defender90 is offline   Reply With Quote
Old 06-24-2005, 09:51 PM   #35
flash77 is on a distinguished road
mac2go
Very nice! Though I don't really see the point in the two decently sized LCDs (what are those... 15"?) behind the front seats: who the heck is sitting back there?? Kidding... that's more of a show car setup, though I'm sure it would entertain any rugrats I tucked into the back.
What screen is he using up front? Looks like a motorized, retractable touchscreen.
flash77 is offline   Reply With Quote
Old 06-25-2005, 04:32 AM   #36
yes, seems so.. but i don't like these b/c you never know when to refuel ;-)
markus
Old 06-27-2005, 03:01 AM   #37
hi fireant, i finally decided to place the display in my cooper as you did it. could you please post some close up pictures of how you mounted the cupholder to the display?
thanks in advance!
Old 06-27-2005, 08:37 AM   #38
FireAnt's Avatar
FireAnt is on a distinguished road
I will try to take some closer pics for you, but understand if you don't have the exact same monitor it may not work the same. I used a hole on the side of my monitor where the stylus was to insert the alluminum rod near the top. I had to open up the monitor and I think even drill a little bit to allow the rod to insert. Then i had to insulate the alluminum from making contact with the pcb by covering the area with electrical tape. Please note you will void the warranty on your monitor when you open it and the lilliput monitors are sensitive, the ribbon cable inside can be damaged or unseated easily.
Good Luck!
Mike
05 MINI Cooper Cabrio "Mac MINI"
progress 95%- Mac Mini, Lilliput 7" , usb-wifi, Rayming GPS, Route 66,easy cat touch pad, CCAR front end"skinned",P1900 power supply
FireAnt is offline   Reply With Quote
Old 06-29-2005, 11:54 AM   #39
today, i ordered the cupholder for my cooper. it is here 43,95eur.. pretty expensive, imho.. how much is it in the us?
and which monitor are you using? is it a touchscreen? are you satisfied with the model?
markus
Old 06-30-2005, 10:21 AM   #40
FireAnt's Avatar
I am using the 7" Lilliput Touch Screen XGA Car Monitor (Model 629GL 70 P/C/T). (purchased from ebay) It had problems with the cable right after I received it. I think it is an ok Monitor but can be dificult to see in a convertible. It does have the touch screen which I really like, but lowers the brightness slightly and provides more of a mat finnish to the screen. (creates a diferent kind of glare)
It ended up that I cut the cable connector out that was bad and soldered the wires together. This actually helped reduce the bulk of connectors that would have been visible 3" below the screen. Very small wire to work with though. It took hours to do.
Good luck!
Mike
Old 07-13-2005, 05:33 AM   #41
Montanaja's Avatar
Montanaja is on a distinguished road
Power source?
How hard was it to wire up the power source on the MINI COOPER?
Montanaja is offline   Reply With Quote
Old 07-13-2005, 10:09 AM   #42
FireAnt's Avatar
Very easy! I ran a fused wire from the battery and another from the accessory plug that is switched by the ignition.
Mike F.
Old 07-31-2005, 06:37 PM   #43
FireAnt's Avatar
Here is the latest! I've just heard my car is in the September "MacWorld" magazine!
Here is my updated front end using CCAR with a color change to match my car.
Mike F.
Old 08-03-2005, 03:28 AM   #44
786mine is on a distinguished road
quick question... what do you do when you want to turn your car off? does the mac turn off or do you have to wait till it turns off before you can shut off the car? and when you turn on the car, what happens then?
786mine is offline   Reply With Quote
Old 08-03-2005, 10:23 AM   #45
FireAnt's Avatar
I just turn my car off. After 45 seconds the power to the Mac mini is then cut off by the p1900 carnetix power supply.(unfortunately this is like pulling the plug) Then when I turn my car back on the power supply sends a signal to the computer to turn it on. This has worked great so far. I can also enable the sleep mode which the power supply would just put it to sleep. Instant wake up that way. But, computer will draw power in the sleep mode.
Hope this helps
Mike
First Mac Mini in a Land Rover dmonckton Show off your project 12 08-14-2005 07:53 PM
Help Needed: Mac Mini Carputer dazuck MacCar 15 03-12-2005 11:30 AM
Uses for a Mac mini... migel628 Off Topic 2 02-16-2005 02:22 PM
The Mac mini setup... bubbalito MacCar 7 02-03-2005 03:33 PM
Hot Rod Company to start incorporating Mac Minis stacheldraht MacCar 4 02-01-2005 01:25 PM
