Go Back   MP3Car.com > Mp3Car Technical > MacCar
Old 03-16-2005, 01:40 PM   #16
tigabalm is on a distinguished road
yeah mike actually had a question about that...
i am going to get a compustar system installed... and its going to have remote start/shut-off.... will that affect my carputer install?
thanks
peace
tigabalm is offline   Reply With Quote
Old 03-16-2005, 01:48 PM   #17
MikeH is on a distinguished road
Tiga,
Most of the Compustar systems seem to have a couple of AUX outputs. The P1900 needs either a +12V pulse or a GND pulse to start it. Just make sure something like this (aux output) is available in your remote/alarm system.
MikeH
MikeH is offline   Reply With Quote
Old 03-25-2005, 06:30 PM   #18
villian503 is on a distinguished road
i am assuming this voids the warranty? i bought the mac mini just for my car and i also got the extended warranty. i hope i didnt get that for nothin.
villian503 is offline   Reply With Quote
Old 03-26-2005, 07:07 AM   #19
There was some discussion earlier about the warranty remaining in place if you "crack open" you mini. I really don't know where this came down. But if upgrading to larger ram or HDD (which requires cracking opne the mini) voids the warranty that would be a shame.
As far as cutting/splicing cables on your AC adapter..... well that's obviously a different matter . However, this piece can be more easily replaced.
MikeH
Old 03-26-2005, 01:58 PM   #20
iKenndac's Avatar
iKenndac is on a distinguished road
Apple says that opening your Mac mini to upgrade RAM/HD/etc won't void the warranty unless you break something.
Cutting open their proprietary power cable and splicing it to something else, however, would most definitely void it. That's why I didn't get the extended warranty .
iKenndac is offline   Reply With Quote
Old 04-05-2005, 10:51 AM   #21
mjtprelude is on a distinguished road
Quote: Originally Posted by iKenndac
Today, I finally got my Mac mini powered in my car.
I've placed a connector in the wire that lets me quickly and easily transfer my Mac mini between my car and house by unplugging the connector from the car and plugging it into the Mini's power supply.
You don't need an inverter or a special power supply... just a laptop car adapter that gives out 18v (link on the page) and a couple of other of little, easy to get bits.
I've put photos and a walkthrough on my site: http://www.kennettnet.co.uk/astramac/power/
Hope it's interesting and/or helpful to you all.
Awesome...this is exactly what I was looking for to replace to aging ibook....btw, as far as why Apple didn't combine the negative and the ground on the same wire....this is due to the fact that the only source for a ground/earth connection when using the power brick is the house's earth ground. This means that it needs to have a seperate ground wire that passes from the metal chassis of the mac mini through the power brick and to the house's ground. In automotive applications, the chassis of the car is ground, however to ease wiring, they use this ground/chassis as a the negative side of the electrical system via a short cable connecting the negative side of your battery directly to the chassis. Due to this, by seperating the ground and the negative on the power going to the mac mini while in the vehicle, you are just duplicating work since both the "negative" power going to the mac mini as well as the chassis ground for the vehicle are connected together. Although you can combine them, since the other side of the connection (the side of the cable going to the mac mini) has it seperated, you will have to have a jumper going from the ground to the negative similar to the way the control wire is wired with the resister, however for the ground, we just want a straight wire.
mjtprelude is offline   Reply With Quote
Old 04-05-2005, 10:54 AM   #22
MySQL Error
Scouse Monkey's Avatar
Scouse Monkey has much to be proud ofScouse Monkey has much to be proud ofScouse Monkey has much to be proud ofScouse Monkey has much to be proud ofScouse Monkey has much to be proud ofScouse Monkey has much to be proud ofScouse Monkey has much to be proud ofScouse Monkey has much to be proud ofScouse Monkey has much to be proud ofScouse Monkey has much to be proud of
Jsut thought i would let you know, Makro (UK) has a Trust laptop DC-DC that will output from 15V to 20V at 6A and 20V to 35V at 5A. that is a 120W - not bad for £24.99+VAT. more than enough for your MAC minis.
If you want more answers on anything I have posted you can find me at digital-car.co.uk
or skiing or diving or doing somthing else fun!
Scouse Monkey is offline   Reply With Quote
My low cost, easy to build power supply... SkinnyBoy Power Supplies 52 09-27-2006 07:10 PM
HELP!! Power Supply wont supply power Saab General Hardware Discussion 3 08-28-2000 10:33 AM
AT power supply questions JustAGuy General Hardware Discussion 4 07-26-2000 05:35 AM
power supply buzzing help thing i found... read if u have noise TimW General Hardware Discussion 2 03-22-2000 04:30 PM
300 watt power inverter problems DaPyro General Hardware Discussion 6 03-10-2000 03:56 PM
