Go Back   MP3Car.com > Mp3Car Technical > MacCar
Old 03-14-2005, 01:00 PM   #1
iKenndac's Avatar
iKenndac is on a distinguished road
Tutorial: Easily Power a Mac Mini without an inverter or special power supply
Today, I finally got my Mac mini powered in my car.
I've placed a connector in the wire that lets me quickly and easily transfer my Mac mini between my car and house by unplugging the connector from the car and plugging it into the Mini's power supply.
You don't need an inverter or a special power supply... just a laptop car adapter that gives out 18v (link on the page) and a couple of other of little, easy to get bits.
I've put photos and a walkthrough on my site: http://www.kennettnet.co.uk/astramac/power/
Hope it's interesting and/or helpful to you all.
Last edited by iKenndac; 03-14-2005 at 01:51 PM.. Reason: Fixed spelling error in topic title
iKenndac is offline   Reply With Quote
Old 03-14-2005, 01:07 PM   #2
Grimey's Avatar
Grimey is on a distinguished road
Pretty interesting. I don't have a Mac Mini in front of me yet so I can't really tell how feasible. Also is this just to make it easier to take in and out of the car by adding that plug?
Dak TruckPuter:
Mac: - Researching and Awaiting Funds
Changed to planning for a Mac Mini Trukputer...w3rd.
Grimey is offline   Reply With Quote
Old 03-14-2005, 01:49 PM   #3
iKenndac's Avatar
It's perfectly feasible - I did it today. That's where the pictures came from.*
If you hardwire the mini to the car adapter it will work, but that's it - if you ever want to take it out and use it in the house you need to buy another power supply 'cause you've cut the 10-pin power connector off the one you have. This lets you use the same one 10-pin connector for car and home.
Also, you have to wire that resistor to the proper wires for it to work at all.
Old 03-14-2005, 02:28 PM   #4
maxipad96 is on a distinguished road
Can I send you my brick/power wire and you can do this mod for me? Assuming you would charge a fee of course. Just realized your in UK. NM.
Back to my inverter. I'm just not that electronically/wire/soddering wise inclined to attempt something like this.
On a side note.. are you going to relocate your power button? I'm wondering how I am going to incorporate it in the dash and how to actually rewire it/extend the wires into my dash. Any tips on a power button relocation would be appreciated.
Your wiring has inspired me, just gotta get up the guts to do it and figure our where to get the parts.
maxipad96 is offline   Reply With Quote
Old 03-14-2005, 03:27 PM   #5
iKenndac's Avatar
I plan to have the power controlled by an 'intelligent' car power supply (I have the Opus 90W) that 'pushes' the button when you switch on/off the ignition. I'll still have to extend the wire...
The power button connects to the connector pointed out in the uploaded picture. It isn't a standard power button header though, so you'll have to find one that'll fit somewhere, or cut the wires and splice an extension on there. You can put a soft push button on there if you like to act as a power button.
You can get all the parts I used and have talked about (apart from the laptop adapter) from an electronics shop. In the UK, we have a shop called Maplins. I know there is a nationwide store chain in the USA that sells all this stuff, but I can't for the life of me remember what it's called.
Old 03-14-2005, 03:47 PM   #6
Grimey's Avatar
You're probably thinking of Radio Shack or something of the sort.
Dak TruckPuter:
Old 03-14-2005, 04:09 PM   #7
defender90 is on a distinguished road
Did you see this:
MacMini Power Button and Indicator
The link was mentioned here before
defender90 is offline   Reply With Quote
Old 03-14-2005, 04:10 PM   #8
Grimey's Avatar
Yea I remember that link but it was just showing the main car install, not the specific button install. If it did I missed it, that's really cool, thanks for pointing that out.
Dak TruckPuter:
Old 03-14-2005, 04:43 PM   #9
AWESOME!!. Thanks so much for the link. This thing is really starting to come together. As far as what type of wires I should use to extend the button, is their a standard I should be using?
Old 03-15-2005, 10:00 AM   #10
Mac Car Moderator
kandyman676's Avatar
kandyman676 is on a distinguished road
This is some great stuff! I'm glad there is another alternative out there on how to do this. I am personally waiting for some used mac mini's on ebay to do my tinkering.
"If it works this good why F with it?" -KMFDM "Intro"
Strive for ethical wardriving: http://faq.wardrive.net/
My CarCPUs: v1 - 2000 | v2 - 2004
Mp3Car Meets: http://detrimental.org/eyecandy/MP3CarMeets
kandyman676 is offline   Reply With Quote
Old 03-16-2005, 08:00 AM   #11
MikeH is on a distinguished road
HERE's some additional detail on the power button mod. It's specific to the P1900, but will give you some more photos in the details of the mod.
MikeH
MikeH is offline   Reply With Quote
Old 03-16-2005, 10:55 AM   #12
Sweet thanks for all the help guys. And as far as wire is concerned any 24 gauge wire will work right? Any special metal i should be looking for?
Old 03-16-2005, 10:58 AM   #13
I used plain old 24GA wire from Radio Shack... It's not critical. There's very little current/power in this line.
MikeH
Old 03-16-2005, 11:07 AM   #14
Sorry for all the questions, but did you end up integrating the button into your dash? Just trying to figure out how I am going to mount it. I see your from marietta, i'm right up the street in alpharetta. ATL
Old 03-16-2005, 11:13 AM   #15
No, I eliminated the pushbutton. The P1900 has a startup/shutdown controller (SSC) built in. This lets the SSC turn ON/OFF the Mac when you turn ON/OFF your ignition. Or you can start/stop the system with an external pulse (ie with a wireless remote car starter or car alarm system). You can wire the ignition is series with a toggle switch so you can take over manual control of the ON/OFF functions if you like. Here's a schematic of how to do this.
MikeH
My low cost, easy to build power supply... SkinnyBoy Power Supplies 52 09-27-2006 07:10 PM
HELP!! Power Supply wont supply power Saab General Hardware Discussion 3 08-28-2000 10:33 AM
AT power supply questions JustAGuy General Hardware Discussion 4 07-26-2000 05:35 AM
power supply buzzing help thing i found... read if u have noise TimW General Hardware Discussion 2 03-22-2000 04:30 PM
300 watt power inverter problems DaPyro General Hardware Discussion 6 03-10-2000 03:56 PM
Content Relevant URLs by vBSEO 3.3.0
"VaultWiki" powered by VaultWiki v2.5.2.
Copyright © 2008 - 2009, Cracked Egg Studios.Ad Management by RedTyger
