Go Back   MP3Car.com > Mp3Car Technical > MacCar
Old 08-15-2005, 08:28 PM   #31
DaPCWiz is on a distinguished road
nvm. I found a thread on this.
DaPCWiz is offline   Reply With Quote
Old 09-11-2005, 10:55 PM   #32
F350 is on a distinguished road
Quote: Originally Posted by 12Vsystems
You can use send keys to control the radio, so mabey I can create my own buttons in the software.
Has anyone successfully used send keys to control the radio functions?
Thanks.
F350 is offline   Reply With Quote
Old 09-11-2005, 11:36 PM   #33
send keys? what are send keys? I've setup road runner to tune (presets) and volume and mute
Old 09-12-2005, 05:35 AM   #34
Exactly what I have already done. Presets (up and down), volume and mute. But I was wondering if I could add the SEEK button.
Sendkeys is a Visual Basic command (app?) that allows you to control any windows application through keyboard commands. At least this is what I found out by doing a search on the web. I am no programmer, so this is beyond my skills.
Old 09-12-2005, 05:41 AM   #35
My Village Called
0l33l's Avatar
0l33l is on a distinguished road
SendKeys is a windows API. It is compatable with any language that can use windows API.
SkinBedder used to use it
0l33l is offline   Reply With Quote
Old 09-29-2005, 02:33 PM   #36
Hark's Avatar
Hark is on a distinguished road
Anyone have any more results with the Radioshark to report?
Hark is offline   Reply With Quote
Old 09-29-2005, 02:46 PM   #37
i was using radio shark in NYC yesterday, manhattan and queens to be specific, and reception was amazing, at least as far as FM goes. But sadly out here in jersey it doesn't work so well. I need to find a way to boost its reception.
Old 10-09-2005, 07:16 PM   #38
4thChild's Avatar
4thChild is on a distinguished road
Just got my Radioshark over the weekend and it works great, very easy to install and has excellent reception. Its sitting still as I have not yet installed it, but inside it gets better reception then my home stereo. Would also love to re-skin it.
4thChild is offline   Reply With Quote
Old 11-13-2005, 11:24 AM   #39
fastmatt is on a distinguished road
Modified RadioSHARK installed and working
I just got done installing my Mac Mini into a Mazda 3 sedan, completely removing the stock head unit to make space for the 7" monitor.
Thanks to other contributed info on this thread, I successfully re-cased my RadioSHARK, including a connection to the stock radio antenna on the car.
This helped the FM reception tremendously, though some stations still get some interference. AM was a total loss despite my efforts to make a new coil inside the project box. The software interface is of course barely usable on a 7" touchscreen. But at least I can tune when I get tired of listening to my iTunes library.
You can see a full walkthrough of my install, including pics of the RadioSHARK mod, here:
http://www.fastmatt.com/carputer
Thanks for the tip!
fastmatt is offline   Reply With Quote
Old 11-13-2005, 12:06 PM   #40
Thanks for the tip!
that's awesome, can you explain how you connected to your factory antenna?
also as far as the UI - I'm working on a new one for RadioShark using skin bedder. I have a partially working one right now, and I will be making a better one once I get around to it. The current skin I have works only @ 800x600 in CF. if you want to toy with it and your config matches that I can send it your way.
Old 11-13-2005, 12:19 PM   #41
Admin. Don't bug or I'll byte.
Bugbyte's Avatar
Bugbyte is a splendid one to beholdBugbyte is a splendid one to beholdBugbyte is a splendid one to beholdBugbyte is a splendid one to beholdBugbyte is a splendid one to beholdBugbyte is a splendid one to beholdBugbyte is a splendid one to behold
He's running a Macintosh.
Want to:
-Find out about the iBug?
-Stop being a newbie? Take a look at the FAQ Emporium?
-Help me kill my car PC
-Watch live video streams from my mobile PC? Check it out here.
-Where is the iBug?
Bugbyte is offline   Reply With Quote
Old 11-13-2005, 12:37 PM   #42
Basically I de-soldered the original 1-foot length of solid copper wire that was the original fm antenna in the radioshark. Then I soldered in a short piece of insulated wire, and connected that to the positive terminal on a motorola style jack that I got from radio shack. I didn't know if I should connect the ground of the jack to anything, so I left it unconnected (any ideas?). Just using the positive connection, the FM reception is 1000% better. I probably could have skipped the soldering and just snipped off the original fm wire and connected that to the jack. The stock antenna wire from the car just plugs right into the motorola jack (see my project website for more detailed pics/descriptions).
Old 11-13-2005, 02:19 PM   #43
hmmm - that's a tiny bit more complicated for me. I'm running a head unit between the computer and the speakers, which needs an antenna plugged into it, otherwise it won't power up. The head unit is under my passenger seat, so its not an option in terms of using for radio. I wonder if they make a splitter for the motorola jack... I am going to look into it and see what I can figure out. I also have a power antenna, so I need to find a way to trigger it and make it go up and down manually.
fastmatt - as far as the software.. my bad, I didn't realize u were running a macpc... maybe you can try using some sort of remote for it or mapping keyboard buttons to a game controller of some sort... if u can do that on a mac?
good luck on making everything work right, and I'll keep u updated when I get a chance to mess around with my setup.
Old 11-14-2005, 12:24 AM   #44
viper24's Avatar
viper24 is on a distinguished road
wow sounds like a gread idea...
2005 Dodge Ram HEMI
http://www.cardomain.com/ride/2239451
15" LCD touchscreen
Mac Mini
6" Headrest monitors
Modded Xbox
5 PSone screens going in doors
And another 15" LCD!
viper24 is offline   Reply With Quote
Old 11-14-2005, 09:40 PM   #45
MacMobile's Avatar
MacMobile is on a distinguished road
I just resize all button and, while far for perfect, it is a little bit more usable than the original software.
http://homepage.mac.com/francoborgo/...toAlbum81.html
Franco
Help me keep my web site up to date.
Mac-Mini in Passat
MacMobile is offline   Reply With Quote
OEM GPS mod. Writeup + Pics IntellaWorks Hardware Development 67 07-04-2006 03:59 AM
R E V I E W: RadioShark grepzen General MP3Car Discussion 4 03-09-2005 07:38 PM
radioShark am/fm usb adapter with timeshifting kickerks80 Car Audio 13 10-04-2004 05:08 PM
XMPCR, RadioShark, and HD Radio vs. RIAA DaveDog General Hardware Discussion 3 08-31-2004 04:54 PM
Pioneer Slot DVD plexi window mod moahdib General Hardware Discussion 1 01-24-2002 01:55 AM
