04-12-2005, 04:44 PM
#1
No more power button cable hacking!
Guys,
We now have a power button cable solution that will prevent having to hack your existing power button cable. Take a look at THIS.
Unfortunately, the DC Power Connector is still pretty far away. Now looks like August before we can get our hands on them.... sorry.
MikeH
04-12-2005, 07:01 PM
#2
Confusion Master
nice idea!
How about having the wire go to a backplane with a socket on it. Like say a PS2 or similar. Infact you could do it for the reset as well.
04-12-2005, 08:32 PM
#3
Great job man glad you finally found the part
Did you ever find the Power cable connector for the mac?
I tried everywere without luck even down here in australia with no luck
CarPC Status:
GPS: 99%
Hardware: 99%
Software: 92%
Case Install: 99.9%
Dash Install: 100%
Car Install: 72%
04-13-2005, 08:33 AM
#4
Enforcer
I'm not quite sure what you mean. This cable will get spliced into a cable that comes from the P1900 and can be unplugged if you need to remove the Mac. Are you suggesting some sort of docking station? LazzWaldo has developed one of these (see previous posts).
NiN
I have found a source, but I won't be able to get any until August..
MikeH
04-13-2005, 09:14 AM
#5
Confusion Master
Quote: Originally Posted by MikeH
Enforcer
Sorry, seemed I have stumbled into the MAC forum. I thought this was for a PC. Disregard what I said.
04-13-2005, 03:20 PM
#6
So the P1900 isn't available until August now? That really sucks.. I don't know what I'm going to do now.
04-13-2005, 03:25 PM
#7
No, the P1900 will be available late this month (April). The POWER CONNECTOR that fits the back of the Mac mini won't be available until August. So, between now and August you'll have to hack your existing AC/DC adapter power cable as show HERE.
Sorry for the confusion.
MikeH
04-13-2005, 04:02 PM
#8
Right.. Cool! Thx for the clarification.
04-13-2005, 07:01 PM
#9
MikeH, that rocks. Question: how does one actually turn on / off the Mac mini with this cable? Does this connect to a standard switch? (Please note that I have no idea what a "standard" switch is.)
WRX + Mac mini Progress:
[|---------] 1% (Planning & Fund-raising)
Visit the project headquarters.
04-13-2005, 08:01 PM
#10
MD,
This cable merely allows you to connect your existing, rear-panel-mounted power switch in PARALLEL with the P1900's "power switch". The P1900 EMULATES the Mac power switch so that the mini does not know the difference between the two. This means the mini will "sleep" if EITHER the existing power switch says "sleep" OR the P1900 says "sleep".
By "standard" I mean that it is NOT manufactured by Apple (ie you can buy it anywhere, including Radio Shack). The switch could be any off-the-shelf momentary, single-pole pushbutton switch. This simplifies your parts search.
Clear?
MikeH
05-02-2005, 03:21 AM
#11
my nizzle
If only the mac mini's power button would tell it to power down properly...
Carputer status: [-*---------]
Im thinking laptop...
05-02-2005, 08:23 AM
#12
What do you actually mean by that? Usually, hitting the power button on a Mac asks you if you want to Restart, Sleep, Cancel or Shut Down. You can change this default behavior to simply go to sleep. The checkbox is in System Preferences > Energy Saver > Options > Allow power button to sleep the computer. At least this is how it functions on my iMac G5.
05-02-2005, 08:37 AM
#13
I think what shizzle is referring to is the definition of "hitting" the power button. If the Mac is set to sleep, you "hit" the power button for a very short period of time (ie < 1 sec). If the Mac is NOT set to sleep, you must "hit" the power button for 6 seconds to shut it down.
MikeH
05-02-2005, 09:35 AM
#14
my nizzle
Exactly. If only it could do a proper shutdown from the power switch, then the p1900 would be perfect.
MikeH,
When is the Y-cable available?
I am eventually going to bite the bullet and get the P1900 (and y-cable) and just sleep the mini when I can and power it down when needed. I have one of those battery chargers in my trunk, so Ill hafta keep it charged.
At least this will power it up, right? And it can be wired to remote start, and wait to shutdown? I'm thinking I dont need sleep, and neither does my mini!
05-02-2005, 09:48 AM
#15
MP3Car store should have them by the end of this week.
Yes. I have run my Mac mini for a week using sleep, and running the car each day with no noticable effects on my battery.
If you are talking about Pulse Start, yes. You can wire this to a remote starter or car alarm.
MikeH
| Thread Tools |
| Display Modes |
Linear Mode
