The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > MacCar
Thread Tools Display Modes
Old 05-03-2005, 08:47 PM   #1
My Photos: (0)
Audio problems
I installed a Mac Mini in my Jeep, and when I plug it into the aux input i get low volume and really bad interference. Strange, works fine in the house... Any idea? Maybe a grounding problem?
jfelix is offline   Reply With Quote
Sponsored Links
Old 05-03-2005, 10:14 PM   #2
my nizzle
shizzle's Avatar
Vehicle: 98' Honda Accord V6
My Photos: (0)
Either a ground loop or power interference. If moving the audio cable away from the power doesnt fix it, try a ground loop isolator from radiohack.
Carputer status: [-*---------]
Im thinking laptop...
shizzle is offline   Reply With Quote
Old 05-04-2005, 06:48 AM   #3
My Photos: (0)
Are you using an inverter?
I installed mine and had the same buzz/low volume w/ an inverter. Tried grounding the case, didn't work. Ran an extension cord and plugged it into the wall. Problem solved. I'm hoping the DC power supply solves this problem.
maxipad96 is offline   Reply With Quote
Old 05-04-2005, 10:58 AM   #4
Vehicle: '91/Honda/Civic
My Photos: (0)
I'm using an inverter and when first installing my CarPC, I had really bad ground loop noise whenever the inverter was turned on, the computer's PS was plugged INTO the inverter AND I had the AUX line as the source on my HU. If I disconnected the PSU from the inverter, the sound would go away.
Solution: I bought a 3-to-2 prong outlet adapter and ran a wire from the neutral prong to the chassis.
What's the voltage on the Mini's audio out?
DRWeside is offline   Reply With Quote
Old 05-04-2005, 01:34 PM   #5
My Photos: (0)
Inverters just suck.
Old 05-04-2005, 03:52 PM   #6
my nizzle
shizzle's Avatar
My Photos: (0)
I have been running my mac mini off an inverter for weeks, and only had noise when the audio cable neared the power cable during reorganization. Maybe my inverter just doesn't suck as much. I do, however, recommend getting the p1900 and doing a proper wiring and grounding...
http://www.mp3car.com/store/product_...products_id=94
Old 05-04-2005, 05:56 PM   #7
FireAnt's Avatar
Vehicle: 2005 MINI Cooper Cabrio
My Photos: (0)
I'm using the p1900 and have no ground noise problems at all. Also have no noise problems with the motor running. I couldn't be happier. My stock Head unit has Auxillary In and it also has a gain control for Aux in. I set mine at 5.
Mike F.
05 MINI Cooper Cabrio "Mac MINI"
progress 95%- Mac Mini, Lilliput 7" , usb-wifi, Rayming GPS, Route 66,easy cat touch pad, CCAR front end"skinned",P1900 power supply
FireAnt is offline   Reply With Quote
Sponsored Links
Trackbacks are Off
Car Audio (and computer audio) Guru's I need your help (My Mp3Car Audio is too quiet) hevnsnt Car Audio 5 10-30-2004 11:33 AM
Amp turn on when audio signal is present nrls2000 Car Audio 3 10-22-2004 06:05 PM
Audio problems Rocker298 General MP3Car Discussion 3 04-07-2004 01:49 PM
Exact Audio Copy Timing Problems? jnusaira Newbie 3 02-18-2004 10:03 AM
Connect hand held MP3 player to car audio system? jasonwood General Hardware Discussion 3 10-30-2001 11:30 PM
Sponsored Links
Ad Management by RedTyger
