Go Back   MP3Car.com > Mp3Car Technical > MacCar
Old 05-10-2005, 10:46 PM   #31
BenjaminS's Avatar
Quote: Originally Posted by FireAnt
I loaded it tonight on My MacMINIcooper and had fun! Looks very good. You are headed in the right direction. This thing is very touch screen friendly and I can actually see the words on my 7" screen. (not like itunes).
I had a tough time getting out of it. It stayed on top of the menu and I couldn't select close. I came over from windows, so I had to play with the keyboard for a while to get the right close key press combo. But i did it.
It ran pretty well on my Mac Mini. Only one crash.
Is this ment to run on 800 x 480? My screen is set to 800 X 600 and it doesn't fill it up.
Thanks,
Mike F
Mike
COuld you please post the ~/Library/Logs/CrashReporter/CCarProject.log file so i can figure out where the bugs are. THe ~/ means you home dir
It was made to run on 800x480, but no one ever gave me what the NORM is so i assumed it was 800x480. But if everyone runs 800x600 then there is 120 more pixels of fun :P
BenjaminS
Powered by Imagination
http://www.ccarproject.net/
BenjaminS is offline   Reply With Quote
Old 05-11-2005, 07:17 AM   #32
Banjamin,
If .02 is working well...should we go ahead and install .03? Or is this rev for a specific bug fix?
I think most folks use 600x800.
MikeH
MikeH is offline   Reply With Quote
Old 05-11-2005, 08:23 AM   #33
BenjaminS's Avatar
Quote: Originally Posted by MikeH
Banjamin,
Well then 800x600 is, unless someone else says other wise.
I am in the proccess of changing things/adding new features that are requested, so each version that i will release (probably every night for a while) will be a bug fix and or add a new features. This time around i addded a loading screen, threaded the loading, and the off move off screen button(the ugly orange thing on the controller).
I havn't heard back from anyone that was having loading troubles with the first release, did .03 fix it?
BenjaminS
Old 05-11-2005, 08:32 AM   #34
my nizzle
shizzle's Avatar
I went straight to .03 on my MM and it worked great, no problems.
My most sincere thanks.
Carputer status: [-*---------]
Im thinking laptop...
shizzle is offline   Reply With Quote
Old 05-11-2005, 08:39 AM   #35
Do you think it is possible to ad a phonebook, based on addressbook? Using a bluetooth gsm when connected?
defender90 is offline   Reply With Quote
Old 05-11-2005, 11:44 AM   #36
BenjaminS's Avatar
sounds possible, but thats later on down the road, and if someone wants to buy me a blue tooth phone to test it with
BenjaminS
Old 05-11-2005, 11:59 AM   #37
Banjamin,
Isn't the native res of the 7" screens 800 x 480? Seems that would be the most logical...
dmeyer is offline   Reply With Quote
Old 05-11-2005, 01:33 PM   #38
BenjaminS's Avatar
Ok now its 50/50 ha, I am going to start a thread about this and see what happens.
BenjaminS
Old 05-11-2005, 01:55 PM   #39
Banjamin,
Mike, your sig says you're running a 7" Lilliput, isn't the native res 800x480? Do things look squished? I am only in the planning stages of an install and have yet to get one...just going from native resolution specs.
Old 05-11-2005, 08:46 PM   #40
V0.3
Great work Benjamin !!
I have tested 0.3 on powerbook (G4 512M) on fully patched 10.3.9 using a library of approx 2000 (11GB music) no dramas/crashes or anything else to report.
Btw. is the little icon on the top right (for settings?) implemented ? as it does not respond to moi.
Again keep up the GREAT work !!
raceer is offline   Reply With Quote
Old 05-11-2005, 09:04 PM   #41
BenjaminS's Avatar
yay 2000 songs :P thats good to hear. The only button that is implemented right now is the music button. I am working on the settings design, trying to figure out what needs to be settings and all the fun stuff.
I won't be able to make my nightly build tonight, i am in the process of cleaning code and separating sorting through my functions to make sure my controllers are controlling, and not viewing or modeling.
The source should go up sometime this weekend if anyone is interested in helping.
And thank you all for your support, i really appreciate it!
BenjaminS
Old 05-11-2005, 09:07 PM   #42
BenjaminS's Avatar
Quote: Originally Posted by Bugbyte
Seems like a lot of the crashes happened on dual machines. I didn't mention it but mine is a dual 1ghz G4. Just a possibility.
I have used this on my mm, laptop, and G5 at work, all seems well for me.
The bug is in a get artwork selector. I think i may have gotten it, but I have yet to hear back from you to see if .03 fixed it or not.
BenjaminS
Old 05-11-2005, 10:25 PM   #43
DerekICT's Avatar
The Xenarc is 800 x 480 too
Work in progress - 95% Complete
MacMini 1.42GHz 1GB RAM - WiFi, Bluetooth
NewerTech miniStack 160GB
Xenarc 7" 700TSV
GPS - Rayming TN-200 w/ Route 66
XM PCR
AM/FM Radio Shark
CCar Front End
Carnetix P1900
Griffin AirClick Remote
DerekICT is offline   Reply With Quote
Old 05-11-2005, 10:41 PM   #44
FireAnt's Avatar
I run 800 x 600 because it is easy and looks very sharp on my lilliput 7". Yes, the native resolution is 800 x 480 but I don't find that things look squashed. Of course I'm not doing CAD on this thing and Avril still looks skinny in her music videos
Has anyone got the liiliput to run at 800 x 480 on a mac? I read the thead about the xenarc screen and it sounded like a pain.
No crashes today using it to and from work. I just can't close it with out using the keyboard. Please incorporate an exit or power button.
Thanks,
Mike
PS I think everyone can get 800 x 600 to work while many people have problems getting 800 x 480 to display.
Mike F
05 MINI Cooper Cabrio "Mac MINI"
progress 95%- Mac Mini, Lilliput 7" , usb-wifi, Rayming GPS, Route 66,easy cat touch pad, CCAR front end"skinned",P1900 power supply
FireAnt is offline   Reply With Quote
Old 05-11-2005, 11:00 PM   #45
Admin. Don't bug or I'll byte.
Bugbyte's Avatar
No joy! Version 3 launched and the "loading songs" progress bar went fine, then the "loading albums" progress bar, slower (40 seconds or so for about 3100 songs) but still fine. Then no window. The app didn't crash, it just didn't open up a window with the controls on it.
It showed in the dock and you could hide it, show it, etc. just like a regular app but no window and controls and of course, no music either.
No crash reporter log for the app either!
Running 10.3.9 Panther, 1 gig of RAM, dual 1ghz G4. Looks like I'm the only one with a problem, which is a good thing...for everyone else.
-Where in the world is the iBug?
-Find out about theiBug
-Attention Newbies! Have you seen the FAQ Emporium?
-No time to figure it out? Take 5 minutes to view the Car PC 101 video
Bugbyte is offline   Reply With Quote
Destinator 3 Frontend v1.1.3 BETA 2 - Let's try again! Ninja Monkey Map Monkey 49 01-16-2005 04:45 PM
I got beta Powermate Drivers. fluffy2097 Input Devices 23 01-11-2005 08:01 PM
Nice device for VW Beta?? Enigmaster Car Audio 0 06-13-2004 02:33 PM
Ford Focus ME Skin Beta 1 nitr0genics ME Archive 14 09-08-2003 01:02 PM
Beta Test 1.6.9 Available CarComp ME Archive 6 12-10-2002 10:59 AM
