Quote: Originally Posted by DerekICT
Might be a 800TSV issue. I have been using a 700TSV with no problems (Panther 10.3.9) for 3 weeks now.
I tend to agree with that, but not conclusively. Under Panther I would get a panic if I unlpugged the USB cable, but waking from sleep was OK. However sometimes the touchscreen just simply didn't work even though it was present in the System Profiler.
But under Tiger it works all the time. The only time I have got a panic is during logging out having previously unplugging the USB cable, even though that in itself did cause a panic and when I unplugged the cable I was able to plug it back in and continue using the touchscreen. However, since I don't envisage logging out whilst in the car, this won't be a problem.
Another problem I have found though is that if I leave the screen powered on when I sleep the powerbook, it will wake it up again after a few seconds, so I have to power off the screen moments before I put the powerbook to sleep, but I do get the postive side effect that when I switch on the screen the computer automatically wakes up.
Rob.
