08-20-2005, 04:23 PM
#1
Vehicle: 2007 Acura RDX
P1900 Deadman Timer Timout?
I am adding the (jumper selectable) deadman timer to the P1900 firmware. It will shut down power to the Mac after X days have elapsed without the ignition being turned on. This is to make sure the battery doesn't drain.
My initial thought was to have the 'X' equal 3 days.... However, based on the positive feedback from users using sleep mode, I'm tempted to make it more than 3 days (4-6?). I can only choose one number since there are no more available jumpers.
...your thoughts? Is 3 days the right number?
Sorry for the rush, bu Monday AM is my decision deadline...
MikeH
CarNetix
Helpful info at http://www.carnetix.com
C134, M10000, 40GHDD, XM-PCR, CarNetix P2140, FP
08-20-2005, 06:03 PM
#2
Vehicle: 2005 MINI Cooper Cabrio
3 is good for me
05 MINI Cooper Cabrio "Mac MINI"
progress 95%- Mac Mini, Lilliput 7" , usb-wifi, Rayming GPS, Route 66,easy cat touch pad, CCAR front end"skinned",P1900 power supply
08-20-2005, 06:35 PM
#3
Vehicle: 2004 Infiniti G35 Coupe
3 is very good...pretty much perfect!
Micco
Project Status: Installed! (v1.0)
Mac Mini (1.4ghz, 1G RAM, 80G HD)
XENARC 7" (DigtalWheelz)
Carnetix 1900 + P5V Powersupply
AII-NIS HU Adapter
iMic
Belkin 7-port "Tetra" USB hub
Front end...CCar right now.
08-20-2005, 08:32 PM
#4
3
Mike
3 is good for me....with a truck, I don't plan to get caught out so will be shutting down when in the middle of nowhere anyways :-)
__________
rgds, raceer
08-20-2005, 09:45 PM
#5
Vehicle: 1996 Chrysler LHS
3 seems good to me!
08-20-2005, 11:09 PM
#6
Admin. Don't bug or I'll byte.
Vehicle: 2001 VW Beetle
Three. A full 3 days, 72 hours
08-21-2005, 12:41 AM
#7
QCar Creator
Vehicle: 1993 Tatra 613-4Mi Long
3 days would probably work for me. Just a question to Mike: can't you make more versions of the firmware, each with a different timeout and let the user pick, which one he downloads into his P1900?
08-21-2005, 03:49 AM
#8
3 days sounds good. and when i do the firmware upgrade, ill take the opportunity to figure out why my mac wont go to sleep. its like a kid who drank 3 mountain dews and a bag of candy before bed....
08-21-2005, 04:56 AM
#9
QCar Creator
Mine actually goes to sleep but then it wakes up in some 10 seconds or so. The problem is the RS232-USB adapter. I will have to modify my software to suspend all serial port activity before going to sleep and then restoring it again.
08-21-2005, 08:10 AM
#10
Looks like 3 days is the right number...thanks for the feedback.
Yes. We have already done this with the P1260. I will post the memory location of the "days" (actually hours) timer location in firmware. You can then program if or whatever you want. Check out the U-Flash webpage for how this will be done.
Thanks!
MikeH
CarNetix
08-21-2005, 08:55 AM
#11
Hey Mike, when do you think this revision will be available with the P1900's?
| Thread Tools |
| Display Modes |
Linear Mode
