Go Back   MP3Car.com > Mp3Car Technical > MacCar
Old 08-20-2005, 04:23 PM   #1
P1900 Deadman Timer Timout?
I am adding the (jumper selectable) deadman timer to the P1900 firmware. It will shut down power to the Mac after X days have elapsed without the ignition being turned on. This is to make sure the battery doesn't drain.
My initial thought was to have the 'X' equal 3 days.... However, based on the positive feedback from users using sleep mode, I'm tempted to make it more than 3 days (4-6?). I can only choose one number since there are no more available jumpers.
...your thoughts? Is 3 days the right number?
Sorry for the rush, bu Monday AM is my decision deadline...
MikeH
MikeH is offline   Reply With Quote
Old 08-20-2005, 06:03 PM   #2
FireAnt's Avatar
3 is good for me
05 MINI Cooper Cabrio "Mac MINI"
progress 95%- Mac Mini, Lilliput 7" , usb-wifi, Rayming GPS, Route 66,easy cat touch pad, CCAR front end"skinned",P1900 power supply
FireAnt is offline   Reply With Quote
Old 08-20-2005, 06:35 PM   #3
Micco's Avatar
3 is very good...pretty much perfect!
Micco
Project Status: Installed! (v1.0)
Mac Mini (1.4ghz, 1G RAM, 80G HD)
XENARC 7" (DigtalWheelz)
Carnetix 1900 + P5V Powersupply
AII-NIS HU Adapter
iMic
Belkin 7-port "Tetra" USB hub
Front end...CCar right now.
Micco is offline   Reply With Quote
Old 08-20-2005, 08:32 PM   #4
3
Mike
3 is good for me....with a truck, I don't plan to get caught out so will be shutting down when in the middle of nowhere anyways :-)
__________
rgds, raceer
raceer is offline   Reply With Quote
Old 08-20-2005, 09:45 PM   #5
3 seems good to me!
Kenny Pollock is offline   Reply With Quote
Old 08-20-2005, 11:09 PM   #6
Admin. Don't bug or I'll byte.
Bugbyte's Avatar
Three. A full 3 days, 72 hours
-Where in the world is the iBug?
-Find out about theiBug
-Attention Newbies! Have you seen the FAQ Emporium?
-No time to figure it out? Take 5 minutes to view the Car PC 101 video
Bugbyte is offline   Reply With Quote
Old 08-21-2005, 12:41 AM   #7
QCar Creator
Jirka Jirout's Avatar
3 days would probably work for me. Just a question to Mike: can't you make more versions of the firmware, each with a different timeout and let the user pick, which one he downloads into his P1900?
Jirka Jirout is offline   Reply With Quote
Old 08-21-2005, 03:49 AM   #8
3 days sounds good. and when i do the firmware upgrade, ill take the opportunity to figure out why my mac wont go to sleep. its like a kid who drank 3 mountain dews and a bag of candy before bed....
avidan is offline   Reply With Quote
Old 08-21-2005, 04:56 AM   #9
QCar Creator
Mine actually goes to sleep but then it wakes up in some 10 seconds or so. The problem is the RS232-USB adapter. I will have to modify my software to suspend all serial port activity before going to sleep and then restoring it again.
Old 08-21-2005, 08:10 AM   #10
Looks like 3 days is the right number...thanks for the feedback.
Yes. We have already done this with the P1260. I will post the memory location of the "days" (actually hours) timer location in firmware. You can then program if or whatever you want. Check out the U-Flash webpage for how this will be done.
Thanks!
MikeH
Old 08-21-2005, 08:55 AM   #11
Hey Mike, when do you think this revision will be available with the P1900's?
Carnetix P1900 (brand New Brought By Mistake) rockyfozz Classified Archive 0 08-14-2005 05:34 PM
Carnetix p1900 and Travla c138 120watt? john_draws Power Supplies 3 05-27-2005 12:42 AM
p1900 is perfect -except for one quirk: crazymadbastard Power Supplies 3 05-24-2005 06:48 PM
P1900 Hookup Help maxipad96 MacCar 3 05-12-2005 09:22 AM
help to design a timer circuit CdRsKuLL Car Audio 15 10-23-2004 05:07 PM
