if i understand correctly, you would like 2 seperate inputs (radio from your headunit, and audio from the mini). If this is the case, and your headunit has an rca audio out, what you should do is run it to an external sound card (or even an iMic from griffin). this way, on the mac mini, you can set the audio output to toggle between the two sources. Whenever you want to hear the audio coming out of the headunit, you just set the mac mini audio to "line-in" or "mic-in" and the output audio should be whats coming in from the headunit.
good luck.
how are you dealing with the low voltage of audio coming out of the mini? its only about 2v, so im planning to go buy a line drive....
Mac Mini BMW -- Done! (but always in progress) -- TOTALLED -- Damn lady didn't "see" the redlight
