Go Back   MP3Car.com > Mp3Car Technical > MacCar
Old 11-19-2005, 08:35 PM   #1
SanRemoRex's Avatar
Slimline DVI cable?
Does anyone know where I could get a DVI cable with a low profile end? Kind of like Bugbyte's VGA cable?
I don't have a huge amount of clearance behind the mac as-is. I could use the adapter and a small VGA like the one above, but I think if I can find a DVI cable like that it would be even better.
Thanks!
JD
MY04 Subaru WRX, San Remo Red,
Mac Mini carputer (Macindash) nearly complete. Current capabilities: Media playback, touchscreen interface, dual OS via VPC, iGuidance navigation. Future plans: Video capture, OBD-II interface, more racing stuff.
SanRemoRex is offline   Reply With Quote
Old 11-19-2005, 08:53 PM   #2
viper24's Avatar
what i did with my xbox is take a dremel or dye cutter and shave off the plastic connector and expose all of the wires going to the pins. then just electrical tape them up and it will be very small/flexable instead of a big block. i hope i made sense. it takes away fron the durability of the cable but just dont pull on the cable super hard and you will be fine.
2005 Dodge Ram HEMI
http://www.cardomain.com/ride/2239451
15" LCD touchscreen
Mac Mini
6" Headrest monitors
Modded Xbox
5 PSone screens going in doors
And another 15" LCD!
viper24 is offline   Reply With Quote
Old 11-19-2005, 08:55 PM   #3
fixerofallthing's Avatar
How about something like this
The Car 2005 Scion xB
The Truck 2004 GMC Canyon
fixerofallthing is offline   Reply With Quote
Old 11-19-2005, 08:56 PM   #4
markopolo311's Avatar
http://store.yahoo.com/videoware/dvirightangle.html
how about a right angle adapter for your current DVI cable?
:edit: above option looks better
I'mmmmmm a n00b.... feel free to make fun
markopolo311 is offline   Reply With Quote
Old 11-19-2005, 10:39 PM   #5
Admin. Don't bug or I'll byte.
Bugbyte's Avatar
That's good! I wish I'd found that before I put mine in. Ultimately, I had to make my own VGA connector to get the clearance I needed. The one in the picture was still too big for my needs.
-Where in the world is the iBug?
-Find out about theiBug
-Attention Newbies! Have you seen the FAQ Emporium?
-No time to figure it out? Take 5 minutes to view the Car PC 101 video
Bugbyte is offline   Reply With Quote
Old 11-21-2005, 09:50 AM   #6
Fuse314's Avatar
Man, If I had known this before I glued my DVI-I Plug in my Dock (to be soldered very soon), I would have taken this option!!
Mac Mini in VW Golf 4
Current Status:
35% - screen in car, dock almost finished
Check out my Worklog
Fuse314 is offline   Reply With Quote
Old 11-21-2005, 04:41 PM   #7
Will it work ?
this looks like a dual link dvi. will this work with a mac mini which appears to be a single link ?
__________
rgds, raceer
raceer is offline   Reply With Quote
Old 11-21-2005, 06:58 PM   #8
SanRemoRex's Avatar
Just from the scale, it doesn't appear that the right angle would be much shorter than the other adapter I'm looking at. It's a great idea though. Apple actually makes one that serves the same purpose as the one that came with the mini, but has a short cord between the DVI plug and the VGA plug. I'm guessing it will be similar dimensions to my TV adapter, which fits fine as far as I've seen. Thanks for the suggestions everyone!
Earthmate USB to Serial cable New_Compact GPS 22 05-22-2008 01:55 AM
Slimline DVI cable? SanRemoRex LCD/Display 1 11-19-2005 09:06 PM
where should i go to get a cable? blackpacu LCD/Display 11 09-08-2004 12:25 AM
A cable I found. masterful LCD/Display 5 08-17-2003 09:36 PM
1:1 Hirose Cable Group Buy! claylong Classified Archive 30 08-31-2002 02:55 PM
