The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > MacCar
Thread Tools Display Modes
Old 03-08-2007, 08:55 AM   #16
My Photos: (0)
as long as i know others have done it on the eby701, i will have to play around with it more. all the documentation seems to talk about the gl series screens. thank you
CaptainTrap is offline   Reply With Quote
Sponsored Links
Old 03-08-2007, 06:29 PM   #17
My Photos: (0)
Quote: Originally Posted by onepuff View Post
try these settings
800 active 480
24 front porch 3
72 sync 7
96 back porch 10
bandwidth 29.910
horizontal frequency 30.151
refresh rate 60.302
must be a timing resolution
i think those are the settings i used. i'll check to make sure
let me know if you have questions
I entered these settings exactly into the purchased "newest version" of display config x as a timing and clicked install then rebooted and upon reboot got the blue screen of "out of range"
Only difference is where you refer to it as "bandwidth" the first field under "back porch" is called "pixel frequency" in display config x.
Am i missing something here? I have the eby701 and an intel core duo mac mini with all newest updates.
Old 03-11-2007, 12:29 PM   #18
My Photos: (0)
bump....any1?
Old 03-16-2007, 11:45 AM   #19
My Photos: (0)
Old 03-17-2007, 03:26 PM   #20
My Photos: (0)
I've just put these settings into my Lilliput 629GL-70NP (run from a Mac Mini) and the size is great but I am getting excessive flickering that I didn't get before (at the higher resolutions).
Anybody have any ideas for more suitable Refresh Rates. I presume that the problem is with the refresh rate?
joesan is offline   Reply With Quote
Sponsored Links
Old 03-17-2007, 07:00 PM   #21
My Photos: (0)
Actually ignore the above - everything seems to have stabilised now and there is no more flickering.
But does anyone know how to keep the 800 x 480 as the default res - my Mac defaults to a much higher resolution upon reboot and I can't get it to default to the 800 x 480.
Old 03-17-2007, 07:31 PM   #22
QCar Creator
Jirka Jirout's CarPC Specs
Jirka Jirout's Avatar
Vehicle: 1993 Tatra 613-4Mi Long
My Photos: (0)
I only had problems with keeping the default resolution when I was using the settings I found here and there on the internet. When I took time and created my own settings, all problems went away. Will try to post them, so you can give it a try.
Jirka Jirout is offline   Reply With Quote
Old 03-17-2007, 07:51 PM   #23
My Photos: (0)
Thanks Jirka - that would be much appreciated.
I looked into the cscreen option but it looks like the instructions on MacVroom are slightly incorrect because I can't get the directories set up correctly when following their instructions.
Seems incredible that there is not a simple way to change the default setting to a low resolution. I read that a number of tests for appropriateness of the setting are done on startup and if any of the test fail a "safe" default is chosen instead.
Old 03-20-2007, 04:09 AM   #24
My Photos: (0)
Bump!
Jirka - any chance you could let me know those settings? It would be much appreciated.
Old 03-20-2007, 04:49 AM   #25
QCar Creator
My Photos: (0)
Sorry for the delay, here you go:
The thing is naturally set as Timing...
Horizontal:
- Active: 800
- Front porch: 32
- Sync: 56
- Back porch: 136
Vertical:
- Active: 480
- Front porch: 2
- Sync: 3
- Back porch: 92
Refresh rate: 60.015 Hz
If this does not work for you, just go to the DisplayConfigX page, read the basics of how it works and experiment. And you may need to adjust the image position using the display's on-screen menu. In case you have two Macs, enable the ssh login on the one te screen is connected to - in case of problems, you can go in using ssh and delete the files generated by DisplayConfigX - much easier than having to go to single user mode etc.
Old 03-20-2007, 07:47 AM   #26
Admin
Bugbyte's CarPC Specs
Bugbyte's Avatar
Vehicle: 2001 VW Beetle
My Photos: (19)
Thread name changed to make it easier to find with a search.
-Where in the world is the iBug?
-Find out about theiBug
-Attention Newbies! Have you seen the FAQ Emporium?
-No time to figure it out? Take 5 minutes to view the Car PC 101 video
Bugbyte is offline   Reply With Quote
Old 03-20-2007, 11:17 AM   #27
My Photos: (0)
That's great thanks Jirka.
I've made the adjustments but I am thinking that I need to set the first page also as the DisplayConfigX notes say that these must be correct.
I've searched all over the net for these specs but they really don't seem to be anywhere.
Can you tell me what you used on the first page (Monitor)?
Old 03-21-2007, 08:48 PM   #28
My Photos: (0)
I have had no luck getting 800x480 on my lilli eby701 and intel mac mini core duo. I hope your settings will work for me Jirka.
Old 03-22-2007, 04:51 AM   #29
My Photos: (0)
CaptainTrap - I think it is important to get the "Monitor" page setting correct also. Unfortunately there seems to be no information out there on what the Lilliputs specs are.
We are going to be reliant on Jirka or someone else who has successfully implemented the lower resolution telling us what they entered for the first page.
Old 03-23-2007, 12:03 AM   #30
My Photos: (0)
post #15
i said i had the same problems at first. then i changed the default refresh rate to 60hz and didn't have the out of range issue.
blown_mx5 is offline   Reply With Quote
Sponsored Links
vB code is On
Trackbacks are Off
VW Golf IV - Mac Mini install Fuse314 Worklogs 12 02-24-2008 04:25 PM
Touchscreen w/ Intel Mac Mini - Please report success Count_Fred MacCar 2 10-01-2006 07:23 PM
Mac Mini in a Mazda Protege zapwizard Show off your project 18 08-07-2006 08:18 AM
FT: Apple iSight like new/1st gen silver iPod mini for Lilliput touchscreen 7"+ JeremyM Classified Archive 6 09-25-2005 10:51 AM
Hot Rod Company to start incorporating Mac Minis stacheldraht MacCar 4 02-01-2005 12:25 PM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
