The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > MacCar
Thread Tools Display Modes
Old 11-19-2007, 10:00 PM   #46
My Photos: (0)
http://www.wreckcenter.com/LCD/
Hope this helps as this thread is pretty old and I prior to making this tutorial still hadn't found any information on this display.
To make sure the computer boots into 800x480, turn off System resolutions, and uncheck all resolutions above your custom 800x480 (but leave the 640x480 as a fail safe.)
olePigeon is offline   Reply With Quote
Sponsored Links
Old 12-02-2007, 11:13 PM   #47
My Photos: (0)
Pics of the stup?
TeckniX is offline   Reply With Quote
Old 02-24-2008, 02:37 AM   #48
My Photos: (0)
Lilliput Problems
So, I just bought one of the new Lilliputs with the LED backlit screen. I worked for a few hours using the settings in this post with DisplayConfigX with no luck at all. I would screen share with the mac mini and set up the config, and then restart, and the screen would just show garbage with the 800 x 480 resolution. And, sometimes, would go into this weird safe mode type thing where it showed only 4 basic resolutions @ 60 Hz with no desktop background. If i ever did get a picture at say, 800x600 the screen was very, very dim and there was lots of flickering, even at the right Hz setting. I had thought maybe the display was defected and was going to send it back.
Before I did that though I decided to try to connect the display to my PC. I plugged it in, and it worked perfectly. It defaulted to 800x480 and it was bright and clear. So, I then plugged it back into the mac mini, and it automatically came up with the DisplayConfigX resolution I had set up previously and saved. And, it was bright and clear as well.
I'm thinking maybe there was some sort of internal calibration that needed to be done with the display at the correct resolution/setting before it worked. So, just a tip for anybody struggling with getting the DisplayConfigX settings working (it seems there's a few in this thread) Try connecting the display to a PC first and then back into the mac mini.
spy4sd6 is offline   Reply With Quote
Old 02-24-2008, 11:24 AM   #49
My Photos: (0)
That's almost a ghetto fix.. but thanks for the tip!
Old 02-24-2008, 01:27 PM   #50
onepuff's CarPC Specs
onepuff's Avatar
My Photos: (0)
yea it's really screwy. I hope it works for you when you get it in the car.
onepuff is offline   Reply With Quote
Sponsored Links
vB code is On
Trackbacks are Off
VW Golf IV - Mac Mini install Fuse314 Worklogs 12 02-24-2008 04:25 PM
Touchscreen w/ Intel Mac Mini - Please report success Count_Fred MacCar 2 10-01-2006 07:23 PM
Mac Mini in a Mazda Protege zapwizard Show off your project 18 08-07-2006 08:18 AM
FT: Apple iSight like new/1st gen silver iPod mini for Lilliput touchscreen 7"+ JeremyM Classified Archive 6 09-25-2005 10:51 AM
Hot Rod Company to start incorporating Mac Minis stacheldraht MacCar 4 02-01-2005 12:25 PM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
