Quote: Originally Posted by
MX5PC
Isn't there a way to whack that ONE setting into display config directly?
Yes, there is. The files with these settings are stored in /System/Library/Displays/Overrides/ If you can figure out the file structure (I belive it is documented somewhere on ADC), you can achieve exactly the same result as with DisplayConfigX. But believe me, it is much better and (counting your time) cheaper to just buy DisplayConfig X...
