The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > MacCar
Thread Tools Display Modes
Old 02-08-2006, 06:06 PM   #1
My Photos: (0)
Carnextix P1900 and USB Powered Hub
How are you guys doing. I am looking to purchase the P1900 soon but I have some questions that still remain. One puzzling me now is, since there are two outputs for p1900, one for mac mini and one for something else, like a USB Powered Hub, how would I get that Hub powered through to the p1900. Is it a special adapter that has to come with the hub power supply? Does the power supply of the hub have to go through a similiar process of the mac mini (stripped, then power/ground)... Let me know if you guys know any solutions. Thank You.
edit - (put an extra x in topic, whoops)
kristyle04 is offline   Reply With Quote
Sponsored Links
Old 02-08-2006, 07:09 PM   #2
viper24's Avatar
Vehicle: 2005 Dodge Ram HEMI
My Photos: (0)
The P1900 has a few outputs, one for the mini and another (two maybe?) that are 5v that will power USB hubs. If you get a powered USB hub, it should have a 5v input so just cut the cord on the powersupply it comes with and connect the positive on the hubs cord to the positive on the P1900 and negative to negative and you are set.
2005 Dodge Ram HEMI
http://www.cardomain.com/ride/2239451
15" LCD touchscreen
Mac Mini
6" Headrest monitors
Modded Xbox
5 PSone screens going in doors
And another 15" LCD!
viper24 is offline   Reply With Quote
Old 02-09-2006, 10:05 PM   #3
Vehicle: 1998 Subaru Forester
My Photos: (0)
You can either set the secondary output of the P1900 to 5v or purchase the tertiary 5V output. In both cases you then cut your hub's power cord and splice it to the P1900 output wires.
Use a continuity tester or a multimeter to find which wire connects to the outside of the plug and the hub power adapter should tell you whether the outside of the plug is negative or positive (I think it's negative).
Installed:
Lilliput 7" w/ TS * Kenwood head unit interface
Deluo GPS * BR3 OBD-II * P-1900
Removable/Exchangable:
Mac mini * Dell Latitude 600m
ShaneFK is offline   Reply With Quote
Sponsored Links
vB code is On
Trackbacks are Off
Problem with USB devices not working after restart DucSloerie MacCar 4 01-07-2006 09:46 PM
Carnetix p1900 and Travla c138 120watt? john_draws Power Supplies 3 05-27-2005 12:42 AM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
