Go Back   MP3Car.com > Mp3Car Technical > MacCar
Old 07-01-2006, 10:21 AM   #61
CarFrontEnd Creator
iamgnat's Avatar
Quote: Originally Posted by airspeed
You mean the mini won't start even after adding the resistor to the carnetix P1900?
No. I said that if it's NOT there it won't start.
-dave
My pathetic worklog.
CarFrontEnd (now it's own sub-forum!!!!)
iamgnat is offline   Reply With Quote
Old 07-06-2006, 01:55 AM   #62
regarding the p1900
it seems they have fixed it for the intel
Version 2.2 Change Log:
*Modified to work with Intel based MacMinis
Valhalla is offline   Reply With Quote
Old 07-06-2006, 11:18 AM   #63
thanassius's Avatar
Question about MacPac and G4 Mini
I have a V2.0 P1900 that is getting installed with my G4 Mac Mini. I want to buy a MacPac cable, but I have a question first. On the carnetix site, it says the following:
"(Note: Users of the CNX-P1900 V2.0 regulator and Intel-based mini will need to add a "resistor mod" to their P1900. Please check HERE for the P1900 V2.0 resistor mod)."
My question is, will I need to add the resistor if I buy the MacPac cable (remember, P1900 V2.0 & G4 Mini)? I'm probably misinterpreting the wording...does it mean that if you have both an Intel Mini AND and V2.0 P1900, you'll need to do this, or does it mean that anyone with a V2.0 P1900, regardless of Intel or PPC, will have to do this?
Thanks!
thanassius is offline   Reply With Quote
Old 07-06-2006, 12:03 PM   #64
pepsibobby's Avatar
i have a version 2.0 and a PPC mini and i didnt do the resistor mod. mine works fine, but i'm not very good with the power bit.
pepsibobby is offline   Reply With Quote
Old 07-06-2006, 01:08 PM   #65
CarFrontEnd Creator
iamgnat's Avatar
The resistor is just for us Intel users. You should be able to just plug everything up.
-dave
Old 07-07-2006, 09:58 AM   #66
thanassius's Avatar
Awesome, thanks for your helps guys! :-)
Old 07-13-2006, 07:16 PM   #67
Hey, is the resistor 6.8 Kohms for the MacMini Intel mod?
Aberrant is offline   Reply With Quote
Old 02-16-2007, 09:16 AM   #68
I've been searching and I'm trying to find the significance of installing the y-cable with the macpac power cable kit. So my question is, what is the consequence of not installing the y-cable(grn/blk) into your mac mini?
kristyle04 is offline   Reply With Quote
Old 02-16-2007, 09:26 AM   #69
mac mini won't be able to turn on/off as you turn on/off your car. You'd have to push the button on mac every time. If your mac is in the passenger compartment this should be fine, but if it's in a trunk or somewhere where it's not easiliy accessable I would assume you'd want to do the y-cable trick, so that the mac will turn on/off with your car.
metalac is offline   Reply With Quote
VW Golf IV - Mac Mini install Fuse314 Worklogs 12 02-24-2008 04:25 PM
Mac mini in my 2006 Honda Ridgeline coolcat Show off your project 10 04-23-2006 01:11 PM
MINI Cooper Cabrio, Mac Mini FireAnt Show off your project 14 05-02-2005 10:44 AM
Help Needed: Mac Mini Carputer dazuck MacCar 15 03-12-2005 10:30 AM
Install coming up... but Power questions technopsych Power Supplies 2 04-14-2004 07:16 PM
