The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > MacCar
Thread Tools Display Modes
Old 06-27-2006, 03:11 PM   #1
My Photos: (0)
Griffin PowerMate Causing Mac Mini to crash!
Hi there I found no one has the same problem as I do:
My Griffin PowerMate is installed on my Mac Mini Core Solo. Since I installed it I have a (I think it is called) kernel panic at shutdown. Have any of you had this issue?
Thanx for the feedback...
Mac-in-a-Zuk
Suzuki Jimny 1.3 VVT - Mac Mini 1.5GHz Intel Core Solo - 7" Newision NW619VT touch screen - 2x200W amp
saabman96 is offline   Reply With Quote
Sponsored Links
Old 06-28-2006, 06:19 AM   #2
My Photos: (0)
Unhappy
Hi!
Seems no one has the same problem as I have. So I will give you an update on the situation:
I installed the UB 1.6.4 version of the Griffin PowerMate software. That went OK and then I plugged the PowerMate in, that went OK too and the knob works. But when I shutdown it panics! so I tried some variations first I just unplugged the PowerMate and then shutdown... and it worked fine no panics
Then I decided to go to my Apple reseller and ask him to test it, he actually just sat me down in front of another Mac Mini Core Solo 1.5GHz and said I could do what I wanted! I thought that was pretty good stangely the PowerMate worked on the shop's Mac Mini. So I have come to the conclusion the the PowerMate is incompatible with my configuration.
Now I have 2 external devices plugged into the USB ports: 1 is the touch screen, the other is the griffin RadioShark. I suspect very strongly that the UB version of the Touch Screen from www.newision.com is conflicting with the UB version of the PowerMate software/driver.
If anyone has a Mac Mini Core Solo 1.5GHz coupled with a Touch screen and a PowerMate and the setup works sucessfully can he/she tell me as I would be very interested to find a solution to my problem.
Thanx all
Mac-in-a-Zuk
Old 06-28-2006, 10:23 PM   #3
Sharkbite86's Avatar
Vehicle: 90' Toyota Camry DX 2.0 I4
My Photos: (0)
maybe you sould try pluggin it into a powered hub? Or for a more drastic approch yo could reinstall everything one at a time to find the issue... I think i heard somwhere that the powermate was not completely compatible with intel macs (although I could very well be wrong). email griffin and the touchscreen folks with your problem and see if they can help.
MacCar progress:
Planning:-----> [||||||||||||||||||||] 70%
Parts:---------> [||||||||||||||||||||] 0%
Construction:-> [||||||||||||||||||||] 0%
Car broken into... progress is basically zip...
Sharkbite86 is offline   Reply With Quote
Old 06-29-2006, 05:18 PM   #4
MacMobile's Avatar
Vehicle: 2000 Volks Passat
My Photos: (0)
Quote: Originally Posted by saabman96
Hi!
I have a G4 Mac-Mini, Xenarc Touch screen and many USB accessories going through two USB Hub and I did had some problems. There are only two USB ports on G4 Mini so I had a hub in each port. I was told to plug the touch screen directly into the Mini and the rest through the hub and my problem was solved.
Not sure about the Intel Mini but my best guest would do like Sharkbite86 suggest car start by writing to Grffin to see if they have received report of problem with Intel Mini.
Good luck.
Franco
Help me keep my web site up to date.
Mac-Mini in Passat
MacMobile is offline   Reply With Quote
Old 06-30-2006, 06:37 AM   #5
My Photos: (0)
Thumbs up
Thanx for you advice I will check with Griffin first
Mac-in-a-Zuk
Old 06-30-2006, 07:25 PM   #6
skippy911's Avatar
Vehicle: 2000 Lexus RX300
My Photos: (0)
It does not work with intel mini;s. Griffin knows this, I verfied this, and took the power mate back to the store. I would recommend you do the same.
skippy911 is offline   Reply With Quote
Old 07-03-2006, 04:04 PM   #7
GoHybrid's CarPC Specs
GoHybrid's Avatar
Vehicle: 2007 Honda Civic Si Sedan
My Photos: (42)
sure it does!
I've got a griffin powermate i purchased about a month ago or so and it works famously on my intel mini. I've got the Core Duo 1.6Ghz. I'll qualify that by saying that I did download the latest drivers from their website and am using no software or drivers other than what I needed for Front Row.
GoHybrid is offline   Reply With Quote
Old 11-01-2006, 03:28 PM   #8
My Photos: (0)
Hi All,
I have the same problem with my intel mac 1.5 solo and powermate. Any solution yet saabman? did you contact griffin?
thanks
guest is offline   Reply With Quote
Old 11-01-2006, 03:53 PM   #9
My Photos: (0)
I am affraid that it does not work with the core solo but it does fine with the duo, I tested it at the shop, but had to hand it back as we couldn't get it to work ...
Mac-in-a-Zuk
Sponsored Links
vB code is On
Trackbacks are Off
FAQ: Installing a Mac Mini in Your Car Bugbyte The FAQ Emporium 15 06-26-2008 02:24 AM
Mac Mini in a Mazda Protege zapwizard Show off your project 18 08-07-2006 08:18 AM
Mini Mac 4 Porsche 944 4thChild MacCar 13 06-20-2006 07:57 AM
Intel Mac Mini on TrailBlazer 2002 tizoc Newbie 0 04-19-2006 01:03 PM
Hot Rod Company to start incorporating Mac Minis stacheldraht MacCar 4 02-01-2005 12:25 PM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
