The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > MacCar
Thread Tools Display Modes
Old 07-24-2006, 09:08 PM   #1
schnaarf's Avatar
Vehicle: 1989 BMW 325i Touring
My Photos: (0)
Mac Mini in a Jag
Hi, I am planning a Mac Mini in an XJ40 Jag. Its going to go in the glove box. Does it need a cooling system in such a confined area, and also I presume its ok to be at any angle...?
thanks
schnaarf is offline   Reply With Quote
Sponsored Links
Old 07-24-2006, 09:29 PM   #2
Admin. Don't bug or I'll byte.
Bugbyte's CarPC Specs
Bugbyte's Avatar
Vehicle: 2001 VW Beetle
My Photos: (19)
It OUGHT to be okay at any angle. You should give it a way to exhaust air somehow, though. During those hot days, locking it up inside a glove compartment could cause it to overheat.
You could do what I did with mine when I was concerned about overheating. I used the temperature monitor lite application and monitored the temp. It has autoshutdown settings if the Mini gets too hot. Mine has run at 135F without problems.
-Where in the world is the iBug?
-Find out about theiBug
-Attention Newbies! Have you seen the FAQ Emporium?
-No time to figure it out? Take 5 minutes to view the Car PC 101 video
Bugbyte is offline   Reply With Quote
Old 07-24-2006, 09:34 PM   #3
Endon's Avatar
Vehicle: 1998 Toyota Rav4
My Photos: (0)
My mini runs at near vertical when the glove box is closed... I've had no problems with it.
Also, cases like this...
Are designed with a non-normal orientation in mind. You should be just fine...
Endon is offline   Reply With Quote
Old 07-25-2006, 12:56 AM   #4
schnaarf's Avatar
My Photos: (0)
excellent thanks. I just thought that the comp being at a slight angle (not horizontal or vertical) may cause a disk to not spin properly. When I get mine, I'll test it. The Mac is going to cost more than the car...!
Old 07-25-2006, 08:23 AM   #5
CarFrontEnd Creator
iamgnat's CarPC Specs
iamgnat's Avatar
Vehicle: 04 Ford Escape
My Photos: (0)
As far as angle, at any version of 180, 360, or 90 you should be fine (i.e. flat or on a side). Other angles *could* be an issue, but with the 2.5" drive you are *probably* ok.
As far as heat, make sure it has air flow. My space did not and I have since had to add vents and fans to help with the summer heat (not that it was a big deal or anything). In my case, the Minis fans were kicking on full blast and staying that way for my 10 - 20 minute commute in the evenings. As long as it is running long enough that the fans slow back down, you are probably ok. If, like me, there is not enough time for the Mini to cool itself off then you probably have an issue.
-dave
My pathetic worklog.
CarFrontEnd (now it's own sub-forum!!!!)
iamgnat is offline   Reply With Quote
Old 07-25-2006, 09:30 AM   #6
AMP Creator
aychamo's Avatar
My Photos: (0)
Don't you need a special driver to run a mac in a Jag??
(drum roll please! - ba dum ching!)
- http://www.aychamo.com
aychamo is offline   Reply With Quote
Sponsored Links
vB code is On
Trackbacks are Off
FAQ: Installing a Mac Mini in Your Car Bugbyte The FAQ Emporium 15 06-26-2008 02:24 AM
Mac Mini in a Mazda Protege zapwizard Show off your project 18 08-07-2006 08:18 AM
Mini Mac 4 Porsche 944 4thChild MacCar 13 06-20-2006 07:57 AM
Intel Mac Mini on TrailBlazer 2002 tizoc Newbie 0 04-19-2006 01:03 PM
Hot Rod Company to start incorporating Mac Minis stacheldraht MacCar 4 02-01-2005 12:25 PM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
