10-31-2006, 03:56 PM
#1
How do I wardrive?
Hi,
I've a Mac mini in car and a D-link Wifi adapter, how do i go about wardriving? Is there software for use with adapters? I'm a novice at this so need some pointers.
Nick
10-31-2006, 05:15 PM
#2
Just download AMP, it's got it built in.. and is available from this forum.... Also not sure about the d-link, but you should have an internal wi fi card inside your mac mini.
10-31-2006, 11:48 PM
#3
Here ya go. Everything you ever wanted to know. Jeff's a good guy.
http://www.wardrive.net/wardriving/faq
Failure is not an option....
It's installed by default on every version of Windows.
11-01-2006, 09:23 AM
#4
Admin. Don't bug or I'll byte.
I've used both MacStumbler and Kismac. Kismac is more powerful, but MacStumbler works quite well, too.
Either way, you load them up and start getting audio notifications when you drive by an access point. One sound for encrypted, another sound for open access.
Kismac has a nice feature that passively listens for access points. This allows it to detect access points where people haven't named them and thus they don't usually show up in a scan. Also, your computer isn't registered as querying the access point. It's basically stealth mode. I discovered two other points near my house that I didn't know about previously when I used it.
Kismac also has some nice graphing features that show signal levels and such. It also lets you import a map and geo-reference it, then it records all of the access points on that map. If you want to map out a particular area, it's worth it.
11-01-2006, 03:14 PM
#5
Hey,
Thanks for the responces. My mini is a G4 does not have internal wifi. How would i surf the net, say if i was outside a starbucks or similar? Ive done a local search of my area and found a few access points, but how to utilise them? Does Kismac or Macstumbler work with an external wifi adapter ive think Macstumbler doesn't.
Thanks guys,
Nick
11-01-2006, 09:02 PM
#6
Mac Car Moderator
I personally cannot remember if it does. When I last wardrived on a mac, it was only the drivers for the internal wi-fi cards.
Google may yield some results for yah:-)
11-01-2006, 09:05 PM
#7
Quote: Originally Posted by mr2mac
Hey,
Thanks guys,
Nick
They will both use external usb wifi adapters if the os supports them. The best way to get connected is ask the owner of the access point. They should have a little sheet with all the connection info. Usually if the place has public wifi available osx's built in connection manager will ask you if you want to connect.
11-01-2006, 09:59 PM
#8
Hey,
Thanks guys,
Nick
I'm not understanding you. If you have no internal wifi then how are you doing a local search? You mean you are looking them up on the web?
If available, spring for the internal airport card and add it to the Mini yourself. You won't be sorry.
11-01-2006, 10:04 PM
#9
I think he meant using an external wi fi solution via usb?
11-02-2006, 02:41 AM
#10
Sorry didn't make myself clear. Yes it is an external usb adapter, and it has OS X support.
11-02-2006, 07:44 AM
#11
Okay. I don't think you'll have any problems. Best of all, both Kismac and Macstumbler are free so, no loss if they don't work. Download and try them out!
11-03-2006, 02:01 AM
#12
My suggestion is use an Armored Personnel Carrier or perhaps an Abramms tank and just drive down the street...war won.
Sorry, you caught me on the end of a very long night drivin so I'm a bit loopy, couldn't help it.
Hi,
Nick
11-03-2006, 11:58 AM
#13
Hey, there is a Ferret APC a bit farther north of me for sale on E-Bay right now.
| Thread Tools |
| Display Modes |
Linear Mode
