The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > MacCar
Thread Tools Display Modes
Old 03-24-2007, 03:15 PM   #1
My Photos: (0)
Feedback on Car stereo with Mini
I used a Ground Loop Isolator, as someone suggested, no success.
Im still getting feedback, any ideas???
crzunch is offline   Reply With Quote
Sponsored Links
Old 03-24-2007, 06:36 PM   #2
Super Duper Moderator
Bugbyte's CarPC Specs
Bugbyte's Avatar
Vehicle: 2001 VW Beetle
My Photos: (14)
Do you mean feedback in the rock and roll guitar style like when you put a microphone directly in front of a speaker, or do you mean a whining or buzzing noise that tends to vary with the speed of the car?
-Where in the world is the iBug?
-Find out about theiBug
-Attention Newbies! Have you seen the FAQ Emporium?
-No time to figure it out? Take 5 minutes to view the Car PC 101 video
Bugbyte is offline   Reply With Quote
Old 03-26-2007, 11:49 PM   #3
KRS_Juan's Avatar
Vehicle: 2004 Infiniti G35 Coupe
My Photos: (20)
If it's "a whining or buzzing that tends to vary with the speed of the car" as Bugbyte said, try moving the audio cables further away from any cables carrying power, or get better shielded audio cables.
-KRS Juan-
KRS_Juan is offline   Reply With Quote
Old 04-04-2007, 11:00 PM   #4
aaronle06's CarPC Specs
My Photos: (0)
i get this problem bad when i have my hacked cable going through the mini to the power switch. is there any way to shield that from EMI from alternator whine?
aaronle06 is offline   Reply With Quote
Old 11-05-2007, 05:24 PM   #5
My Photos: (0)
Yep
So I get feedback as well and I am pretty certain that it is from the alternator. It is also limited to the right channel. If I plug in the XM radio it gets way worse. I have everything grounded, but not using the same ground. Can that be a problem?
pand0ra is offline   Reply With Quote
Old 11-06-2007, 09:03 AM   #6
Bugbyte's Avatar
My Photos: (14)
Yes. One of the causes of feedback -known as a ground loop, is caused by slight voltage differences between ground points. The car body as a ground system has differing resistance across the various ground points. It is also possible that even though you may ground to a single point, that point isn't a good one.
Check the Wiki and the FAQ for more info searching on terms "ground loop" or "whine".
Old 11-06-2007, 04:47 PM   #7
zapwizard's CarPC Specs
zapwizard's Avatar
Vehicle: 2006 PT Cruiser
My Photos: (0)
It does help if everything is grounded to the same point, but it is not required.
What is more important is that the ground of your audio signal (or shield) is NOT connected to the power supply ground.
You need to double check your wiring for the amplifier and the PC.
A ground loop isolator won't help if the audio ground is still connected elsewhere.
A good amp will completely isolate the audio ground from the power ground.
Another possibility is that your alternator is directly affecting your amplifier when the voltage changes. In this case a power filter is what you need. They are dirt cheap at any auto parts store. I used one before my amp and LCD (had noise) along with a ground loop isolator.
zapwizard is offline   Reply With Quote
Old 05-06-2008, 08:00 PM   #8
My Photos: (0)
Update
So I figured out the alternator noise problem. It is because I was running the power wires next to the speaker & RCA wires. Once I pulled them the noise went away. I read somewhere that you should run power wires along one side of the car and the audio wires down the other.
Sponsored Links
vB code is On
Trackbacks are Off
FAQ: Installing a Mac Mini in Your Car Bugbyte The FAQ Emporium 13 03-30-2008 09:03 AM
PPC Car GPS and MP3 mini How To hotrod_nut General Hardware Discussion 1 02-25-2008 01:24 PM
Mac Mini in a Mazda Protege zapwizard Show off your project 18 08-07-2006 08:18 AM
how powerful of a mini do I need for a car install pedro_sandchez MacCar 2 09-25-2005 11:00 AM
Car Stereo Installation Video's for Sale johnram Classified Archive 2 09-05-2002 10:27 PM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
