Nice. I dont need all the buttons on the bottom row (dont's use them). I suppose I can remove them from the skin?
Yes and' possible if riedit the main bar. jpg removing the buttons.
you have to also edit the file Skin.ini however' putting -1,-1, etc.. where the button that you don't use are.
EDIT: I have put them because' they serve, I have removed to the right besides the 3 button of Winamp control from the tall one and put always visible in the main bar, according to me and' better so.'
I will add' also 1 button in the main bar for use Speed alert of the new version of the D3 of Ninja (at least to writing that will add' this function)
ok this might be a stupid question, but i thought desintator was for Smartphones and PDAs, does it install ok on Windows XP/2000?
I guess if you haven't been reading the GPS forum in the last few weeks you won't really know what's going on, so I'll take it easy on you
The whole reason this forum is here is because we managed to get hold of a copy of the destinator 3 SDK. My frontend is an attempt at making it user friendly and, basically, usable!
In my opinion it is not good to have to abbreviate in buttons.
And 'switch map' is not something that can be abbreviated correct.
I like however the big buttons.
Why don't the buttons in the menu have the same width?
Michael
"It does not understand, if it does not ride."
Michael
Yeah, perhaps have "Swit. Map" just say "Map" and "Canc. Route" say "End Route"
Michael
OK i have chance the abbreviations .
Upload for same link
And' possible to increase from the file Setting.ini or in other way the space aloft where the indication there am ETA, etc...???
On my PC home and' all ok, instead on the carPC I see ONLY well the first line of indications, the second line to destination (ETR data) is cut from the map, and I don't see almost at all the data.
Of sure it depends on the the LCD Lilliput and from the resolution 800 x 600.
