Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > No Longer Supported > Map Monkey
Old 11-17-2004, 04:19 PM   #16
Map Monkey Creator
Ninja Monkey's Avatar
Ninja Monkey is on a distinguished road
Quote: Originally Posted by RoyN
damn..... but nmea is slower than sirf right? will it ever be possible to support sirf? I dont see why it couldnt if all the information, speed, heading, etc is still available when using sirf.... can you share the limitation with us curious folk? I guess i might have to go back to nmea then!
Because I had to write code to parse the nmea data and retrieve all the information manually. SiRF is a completely different protocol and it'll take some time and a lot more coding before it's supported.
Destinator 3 For PC! - http://www.map-monkey.co.uk/
Ninja Monkey is offline   Reply With Quote
Old 11-17-2004, 04:49 PM   #17
Seth's Avatar
Seth is on a distinguished road
Installed it in my home PC with no problems. Currently changing fonts
Will test in the car tommorow (see it in action)
Good work NM
Cheers m8
Seth is offline   Reply With Quote
Old 11-17-2004, 04:51 PM   #18
heliodoro is on a distinguished road
Hi Ninja
I´m trying to use the project1 example.
When I try to connect I get a winsock error 10061.
Can you help me solve this please.
Heliodoro
heliodoro is offline   Reply With Quote
Old 11-17-2004, 04:54 PM   #19
MySQL Error
jcdillin's Avatar
jcdillin is on a distinguished road
Works great for me, love the new MPH displayed on the map.
肚子笑痛了
S60 Install
jcdillin is offline   Reply With Quote
Old 11-17-2004, 05:02 PM   #20
Map Monkey Creator
Heliodoro
You need to allow applications to connect to the frontend, I've now set this to be disabled by default.
Open up C:\DestinatorApps\Frontend_PREV\Settings.ini
Find the line that reads
[Connection]
//Allow custom apps to connect to the frontend?
Enabled=No
and change it to
Enabled=Yes
Note that there are loads of new commands that aren't yet documented in the dev manual yet. I'll update it when I make an official release
Old 11-17-2004, 05:11 PM   #21
Trudge's Avatar
Trudge is on a distinguished road
Downloading now. Really looking forward to the new features. Thanks NM for the beta, the suspense was killing me
'94 Mazda T3500 Bus, Lilliput 7", Mouse GPS, 1GHz TC1100 Tablet PC, Inverter, HUGE Spare battery, Smart Charger, Road Runner, FreeDrive.
Trudge is offline   Reply With Quote
Old 11-17-2004, 06:09 PM   #22
It ain't easy being a green moderator
meddler's Avatar
Location: Steps out the front of Henson's workshop or Sydney
meddler has much to be proud ofmeddler has much to be proud ofmeddler has much to be proud ofmeddler has much to be proud ofmeddler has much to be proud ofmeddler has much to be proud ofmeddler has much to be proud ofmeddler has much to be proud ofmeddler has much to be proud of
well done, thanks for all your hard work.
Chat on the mp3car channel on IRC
Server: efnet Channel: #mp3car
No irc client installed? Go to http://chat.efnet.org/. In the channel drop down box select "other" and type in #mp3car.
meddler is online now   Reply With Quote
Old 11-17-2004, 06:53 PM   #23
_wd
_wd is on a distinguished road
Great work ninja monkey! can't wait to take it out for a spin
_wd is offline   Reply With Quote
Old 11-17-2004, 08:23 PM   #24
My Village Called
0l33l's Avatar
0l33l is on a distinguished road
Can't wait till you release the new winsock commands
It seems to be running beautifully, but I haven't tested most winsock code yet (just tested zoom in/out).
Thanks again!
0l33l is offline   Reply With Quote
Old 11-17-2004, 11:13 PM   #25
Deactivated
Diewlay Lowmo's Avatar
Diewlay Lowmo is on a distinguished road
So far so good
Thanks NM.
Keep the beggars wanting more
Diewlay Lowmo is offline   Reply With Quote
Old 11-18-2004, 10:12 AM   #26
The Vauxhall Vectra Project
ccsnet's Avatar
ccsnet has a spectacular aura aboutccsnet has a spectacular aura about
Quote: Originally Posted by Ninja Monkey
This is a BETA version of the frontend, if you wish to participate in the test, BACK UP YOUR CURRENT DESTINATORAPPS FOLDER.
With that done with...
Code:
Version History [v1.1.3 BETA] *New Features* -------------- -Advanced GPS Mode If you have a NMEA GPS receiver, you can now connect destinator using an advanced mode where information such as speed, heading and number of satellites is available. If you use the winsock control, you can even retrieve the entire NMEA string. -Speed Camera Detection The frontend can now notify you of approaching speed cameras. Cameras can also be easily added to the database via a button on the main toolbar -Automatic Update of Speed cameras When connected via the winsock control, you can opt to be notified of any approaching cameras. This is useful for custom applications. -Scroll map with hotkeys You can define hotkeys to scroll the map and also return to the home position. -Fullscreen Mode A hotkey can be defined to enter and exit fullscreen mode. You can also choose to always start in fullscreen. -Reconnect GPS on power resume When returning from standby or hibernate, you can choose to automatically reconnect the GPS. -Navigate Button There is now a navigate button on all dialogs at the bottom right of the screen -Manual Destination You can now route to specific longitude and latitude coordinates. -Speed Display The current speed can be overlayed on top of the mapping window -Customisable Infobar Most aspects of the infobar can now be edited (fonts, colors, positions) by modifying the skin. -Destinator Skins Each skin can now have it's own individual "Destinator Skin" allowing you to change the scrollbar / fonts / internal buttons of destinator without effecting other skins. -Line Mute on Maneuevers As well as Winamp and Frodo control when approaching a maneuver, You can now optionally mute a sound line on your system. (Wave, Mic, Line-in etc..) -Volume Control Buttons can now be added to a skin to control the master volume -New Voice Pack A new voice pack from the PPC version has been included called 'UK' -New Winsock Control A newer version of the Microsoft Winsock Control (MSWINSCK.OCX) has been included. This should fix any compatability problems with other applications and help with performance issues. *Changes / Fixes* ----------------- -Client/Frontend Merge The client and frontend have been merged into a single application. This will greately increase the speed of operation. -ETA/ETR The Estimated Times were being incorrectly calculated. It has now been fixed. -Button Click Simulation not working when embedded This has now been fixed. -Zooming Loop The map scale would reset to max if you zoomed in too far. This has now been fixed. -TMC Disabled by default TMC is now disabled by default in the configuration file due to unsuccessfull testing. -New Hotkeys Hotkeys have been added to perform many new functions - such as; -Cycle Through a dialog -Toggle Map Color Mode -Toggle Map Orientation -Add a speed camera -New Winsock Commands Many winsock commands have been added to enable lots more control from a custom application. Please see the development folder for further information. -Custom OSK Keys You can now add custom characters to the on screen keyboard without needing to replace the preset keys -Various other undocumented bugs have been fixed
I've not got time to write a quick FAQ right now, so just install and start playing... "Advanced GPS" is what you want to enable for the good stuff
Destinator 3 1.1.3 BETA - Full Package [12.0MB]
Enjoy!
Edit: If you're getting errors about missing TABCTL32.OCX, download it here
Great funtion list, no screen shots though.... I've not installed it yet and would love to see what it looks like.
Incase your wondering, for stability reasons I never install beta software, its not that I am lazy.
Terran
ccsnet is offline   Reply With Quote
Old 11-18-2004, 11:00 AM   #27
My Village Called
0l33l's Avatar
Terran
Take a leap of faith. This version has a beta nagscreen
Old 11-18-2004, 11:06 AM   #28
ccsnet's Avatar
Mmmm but to install on my box is a git - cos I got to go out to the car where its raining and cold and if it all goes wrong I'll be left with out a carpc.... still I might get round to it. Depends on how long it takes for me to finnish my new skin.
Terran
Old 11-18-2004, 11:12 AM   #29
Raw Wave
ShawJohn's Avatar
ShawJohn is on a distinguished road
Hi Ninja,
Nice modifications to D3 front end. I've just noticed that the AutoAlert Catagories have no items in them?!? Will that come later?
EDIT: I've just copied Fav's over from other D3 install, sorry!
I've just notice that we can now use CSV files instead of those silly DAT files for Cameras. Much better, and easier to update, and has many countries on too. Nice one Ninja.
I don't want to upset you with more requests but could you add functionality to remove cameras that are either non existant, or have been added in wrong place or by accident. A logo with traffic lights would be nice too as well as speed.
I love the work you're doing and I admire your persistance with such a time consuming project.
We should all be making a christmas donation (£$£) to Ninja for his hard work I think! He deserves it. Just think, if he got a Fiver for every download of this, well, it would make a nice gesture I thought...
Is Sirf ever going to be imlemented again in D3 or are we stuck with NMEA?
John
ShawJohn is offline   Reply With Quote
Old 11-18-2004, 12:50 PM   #30
mauri's Avatar
mauri is on a distinguished road
Do I want to study a skin for the new version of the D3, however' you should tell me if I can move the buttons that are in the Classic version in the main menu in other part now according to my will or these buttons they are forced to be in the main menu bar?
The management volume not the I have seen (I owe us to look well still however') however and' skinnabile in any point or.....?
Same question for the Winamp control play, next etc...
A last thing: the main bar with the buttons he is able' to increase (instead of the 40 actual pixels) or no?
The GPS original bar its in only this dimension or skinnable to big?
It excuses Ninja for the too questions, but they serve me for the skin to do.
Thanks so many.
Mauri
mauri is offline   Reply With Quote
I got beta Powermate Drivers. fluffy2097 Input Devices 23 01-11-2005 09:01 PM
Destinator 3 Frontend v1.1 Ninja Monkey Map Monkey 139 10-25-2004 11:40 PM
Looking for beta testers for new DC-DC PSU MikeH Power Supplies 22 05-18-2004 03:22 PM
Beta testing team ? coyote MediaCar 31 03-18-2004 04:02 AM
Wanted: beta testerss for X-MP3Pad (formerly MP944) PorscheMP3 Software & Software Development 0 05-07-2002 12:58 PM
