11-17-2004, 02:39 PM
#1
Map Monkey Creator
Destinator 3 Frontend v1.1.3 BETA
This is a BETA version of the frontend, if you wish to participate in the test, BACK UP YOUR CURRENT DESTINATORAPPS FOLDER.
With that done with...
Code:
Version History
[v1.1.3 BETA]
*New Features*
-Advanced GPS Mode
If you have a NMEA GPS receiver, you can now connect destinator
using an advanced mode where information such as speed, heading
and number of satellites is available. If you use the winsock
control, you can even retrieve the entire NMEA string.
-Speed Camera Detection
The frontend can now notify you of approaching speed cameras.
Cameras can also be easily added to the database via a button
on the main toolbar
-Automatic Update of Speed cameras
When connected via the winsock control, you can opt to be notified
of any approaching cameras. This is useful for custom applications.
-Scroll map with hotkeys
You can define hotkeys to scroll the map and also return to the home
position.
-Fullscreen Mode
A hotkey can be defined to enter and exit fullscreen mode. You can
also choose to always start in fullscreen.
-Reconnect GPS on power resume
When returning from standby or hibernate, you can choose to
automatically reconnect the GPS.
-Navigate Button
There is now a navigate button on all dialogs at the bottom right of
the screen
-Manual Destination
You can now route to specific longitude and latitude coordinates.
-Speed Display
The current speed can be overlayed on top of the mapping window
-Customisable Infobar
Most aspects of the infobar can now be edited (fonts, colors,
positions) by modifying the skin.
-Destinator Skins
Each skin can now have it's own individual "Destinator Skin"
allowing you to change the scrollbar / fonts / internal
buttons of destinator without effecting other skins.
-Line Mute on Maneuevers
As well as Winamp and Frodo control when approaching a maneuver,
You can now optionally mute a sound line on your system.
(Wave, Mic, Line-in etc..)
-Volume Control
Buttons can now be added to a skin to control the master volume
-New Voice Pack
A new voice pack from the PPC version has been included called
'UK'
-New Winsock Control
A newer version of the Microsoft Winsock Control (MSWINSCK.OCX)
has been included. This should fix any compatability problems
with other applications and help with performance issues.
*Changes / Fixes*
-Client/Frontend Merge
The client and frontend have been merged into a single application.
This will greately increase the speed of operation.
-ETA/ETR
The Estimated Times were being incorrectly calculated. It has
now been fixed.
-Button Click Simulation not working when embedded
This has now been fixed.
-Zooming Loop
The map scale would reset to max if you zoomed in too far. This has
now been fixed.
-TMC Disabled by default
TMC is now disabled by default in the configuration file due to
unsuccessfull testing.
-New Hotkeys
Hotkeys have been added to perform many new functions - such as;
-Cycle Through a dialog
-Toggle Map Color Mode
-Toggle Map Orientation
-Add a speed camera
-New Winsock Commands
Many winsock commands have been added to enable lots more control
from a custom application. Please see the development folder for
further information.
-Custom OSK Keys
You can now add custom characters to the on screen keyboard
without needing to replace the preset keys
-Various other undocumented bugs have been fixed
I've not got time to write a quick FAQ right now, so just install and start playing... "Advanced GPS" is what you want to enable for the good stuff
Destinator 3 1.1.3 BETA - Full Package [12.0MB]
Enjoy!
Edit: If you're getting errors about missing TABCTL32.OCX, download it here
11-17-2004, 02:47 PM
#2
Downloading now, i'll give it a go and let you know how I got on..
Nice work
11-17-2004, 03:08 PM
#3
I still get the Tahoma font missing, and then i get this error
Error Details:
Number: 339
Description: Component 'TABCTL32.OCX' or one of its dependencies not correctly registered: a file is missing or invalid
Source: Open_Setup
Version: 1.1.300
HelpContext: 1000339
HelpFile:
LastDllError: 0
11-17-2004, 03:11 PM
#4
Confusion Master
Downloading as the above said.
11-17-2004, 03:15 PM
#5
Cheers Ninja
d/l now
Kevin
Build status {..........|} 99%
All installed - now into the fiddling about stage
Car:MR2
MB: EPIA C800
Display:Xenarc 700TS
Power:PW-70A & ITPS
Mem:384MB
HDD:40Gb Maxtor Diamond max
Radio:Dlink DRU-100
GPS:BU-303
OS:XP SP2
11-17-2004, 03:35 PM
#6
Map Monkey Creator
Those of you missing TABCTL32.OCX can get it here
11-17-2004, 03:41 PM
#7
Nice Thank You, still getting the font error? can i do anything with that?
11-17-2004, 03:44 PM
#8
downloading now, looking forward to seeing it in action.
thanks
11-17-2004, 03:45 PM
#9
If you hare using XP , move the TABCTL32.OCX to windows/system32,
Then start , run , regsvr32 \windows\system32\TABCTL32.OCX
Then you can configure D3
heliodoro
11-17-2004, 03:53 PM
#10
if i am pressing The Arrow in the right corner or trying to use any buttons in the menu, i get the message that windows has closed it down, and i can send a fail report. etc.
I also get this fail on my 2 laptops (XP SP2), and also with the earlier version of D3
11-17-2004, 03:59 PM
#11
This is the fail report windows writes.
#12
Map Monkey Creator
I also get this fail on my 2 laptops, and also with the earlier version of D3
What OS is on your laptops, never heard this one before
Also, please don't post any more problems / bugs in this thread.
11-17-2004, 04:04 PM
#13
Raw Wave
Are questions ok for here? anyways, I finally got Sirf mode, which seems to have helped get better usage of GPS support here in sao paulo... locks are more reliabel apparently, with the ton of buildings in the area...
Anyways, advanced gps is just for nmea? any technical reason for that or is it just that sirf isnt ready yet? what are the differences? can i use speed cams in sirf? what are the other advantages of advanced mode?
11-17-2004, 04:09 PM
#14
Map Monkey Creator
It's just for NMEA I'm afraid.
Advanced Mode will enable you to do the following:
Detect speed cameras
Overlay your current speed on the map
Display the number of satellites on the infobar
The rest is really for developers (the full nmea string can be queried, along with speed cameras, current heading etc.)
11-17-2004, 04:16 PM
#15
Raw Wave
damn..... but nmea is slower than sirf right? will it ever be possible to support sirf? I dont see why it couldnt if all the information, speed, heading, etc is still available when using sirf.... can you share the limitation with us curious folk? I guess i might have to go back to nmea then!
| Thread Tools |
| Display Modes |
Linear Mode
