Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > No Longer Supported > Map Monkey
Old 11-29-2004, 07:16 PM   #16
Map Monkey Creator
Ninja Monkey's Avatar
Ninja Monkey is on a distinguished road
Quote: Originally Posted by OriginalNick2
Loads into Frodo fine for me - but skin changes are lost and get a destclient.exe error on closing Frodoplayer
Destclient!? That was part of 1.1.2!
Sure frodo is loading the right version?
Destinator 3 For PC! - http://www.map-monkey.co.uk/
Ninja Monkey is offline   Reply With Quote
Old 11-30-2004, 04:12 AM   #17
Confusion Master
Enforcer's Avatar
Enforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant future
Quote: Originally Posted by Motoko
you put the aplha beta in your car!
Well, I was about to.
It's the only place I can test it, as it has the GPS and moves, unlike my house which doesn't have the GPS and doesn't move.
Enforcer is offline   Reply With Quote
Old 11-30-2004, 06:52 AM   #18
OriginalNick2 is on a distinguished road
he he he
OriginalNick2 is offline   Reply With Quote
Old 11-30-2004, 07:33 AM   #19
Raw Wave
ShawJohn's Avatar
ShawJohn is on a distinguished road
I've just installed this on a test machine, and set it to import the UK camera database, well that was nearly three hours ago now and its still running... Is that normal?
John
ShawJohn is offline   Reply With Quote
Old 11-30-2004, 08:31 AM   #20
The Vauxhall Vectra Project
ccsnet's Avatar
ccsnet has a spectacular aura aboutccsnet has a spectacular aura about
Bravo... keep it going...
Terran
ccsnet is offline   Reply With Quote
Old 11-30-2004, 08:53 AM   #21
cheap custom title
JC-S60's Avatar
JC-S60 is just really niceJC-S60 is just really niceJC-S60 is just really niceJC-S60 is just really niceJC-S60 is just really nice
About the separators and laguages, it's a known issue in excel. Some languages use a semicolon as a separator in a 'comma separated values'-file. Just find/replace ; with , in the file with your favourite text-editor
JC-S60 is offline   Reply With Quote
Old 11-30-2004, 01:52 PM   #22
chewiee's Avatar
chewiee is on a distinguished road
Separators
Why not use Access as the import/export tool, or have I lost the plot in this thread?!
www.my4x4.co.uk
[---------0] (99% complete)
Vauxhall Frontera Sport RS:
Kenwood KDC-W6527 HU
Silver Travla C134, Slot Loading DVD/CDRW,
256MB, VIA Epia MII 12000, Carnetix 60W, Xenarc VGA/Composite TS and a GPS Mouse
chewiee is offline   Reply With Quote
Old 11-30-2004, 03:29 PM   #23
mauri's Avatar
mauri is on a distinguished road
Explained better:
you see in the bugs report, me and others we have the probleme of errors with the separator in Import file....in advance GPS configuration mode.
From thing it depends according to you?
There and perhaps to edit or to change something in the file SC_DV. csv (I use that " Italy")
Thanks for info...
Mauri
mauri is offline   Reply With Quote
Old 11-30-2004, 04:14 PM   #24
Map Monkey Creator
Quote: Originally Posted by mauri
Explained better:
Thanks for info...
Mauri
Mauri can you check my suggestion in the bugs thread?
Old 11-30-2004, 09:55 PM   #25
Trudge's Avatar
Trudge is on a distinguished road
Test Night
Downloading it now. Will test tonight and report.
Thanks again for all your hard work NM.
'94 Mazda T3500 Bus, Lilliput 7", Mouse GPS, 1GHz TC1100 Tablet PC, Inverter, HUGE Spare battery, Smart Charger, Road Runner, FreeDrive.
Trudge is offline   Reply With Quote
Old 12-01-2004, 01:30 AM   #26
djmickyg's Avatar
djmickyg is on a distinguished road
i seem to only have the loading in frodoproblem
good work.. looks good
djmickyg is offline   Reply With Quote
Old 12-01-2004, 09:47 AM   #27
Maximus is on a distinguished road
Very nice indeed !
A small feature request regarding the speed cams.
When adding a camera manually you get a predefined set of speedlimits
or you could enter one manually... would it be possible to have the predefined set configurable through a .ini file ?
Another question, I assume TMC is on hold for now, but is it on hold forever because the SDK-kit (dll's) doesn't include that feature or is it because there's only 24h in a day ?
Many thanks !
/M
Maximus is offline   Reply With Quote
Old 12-01-2004, 02:49 PM   #28
Map Monkey Creator
Quote: Originally Posted by Maximus
Very nice indeed !
Many thanks !
/M
They are already configurable now! inside the folder of the skin you're using is a SKIN.INI. If you open this file there is a section called "Add Speed Camera" that will have the following values
Speed1=31,3,60,60,30
Speed2=128,5,60,60,40
Speed3=27,87,60,60,50
Speed4=131,83,60,60,60
Speed5=28,167,60,60,70
Speed6=133,167,60,60,99
The last value of each (30,40,50 etc.) is the speed that will be entered. (a speed of 99 means it will show the keypad)
Once you've changed these, unfortunately you'll need to amend the images (ADD_CAMERA_DOWN.JPG and ADD_CAMERA_OFF.JPG) but it shouldn't be too difficuilt
Old 12-10-2004, 04:54 AM   #29
andreagospa's Avatar
andreagospa is on a distinguished road
Talking thank you for your work
I'm a new in this forum ! I'm from Italy .
I have a carpc with media player and Destinator 3 ...
My auto is a Alfaromeo 147 and my carpc is a Intel celeron 2.4 ,256 mb ram, hdd - 30gb laptop , mainboard Shuttle mv43vn. Touch screen Lilliput 7 " .
For Ninja Monkey , a special thank's for your work !!!!
andreagospa is offline   Reply With Quote
Old 12-10-2004, 05:46 AM   #30
ThEScReW's Avatar
ThEScReW is on a distinguished road
What power supply do you have? can you show me the current your power supply gives at the 5V line?
ThE ScReW's CarPuter :-)
ThEScReW is offline   Reply With Quote
Destinator 3 Frontend v1.1.3 BETA Ninja Monkey Map Monkey 58 07-19-2005 07:42 AM
BU-303 and Destinator 3 Frontend lummy Map Monkey 15 01-08-2005 05:26 PM
Destinator 3 Frontend v1.1 Ninja Monkey Map Monkey 139 10-25-2004 11:40 PM
Looking for beta testers for new DC-DC PSU MikeH Power Supplies 22 05-18-2004 03:22 PM
Ford Focus ME Skin Beta 1 nitr0genics ME Archive 14 09-08-2003 02:02 PM
