Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > No Longer Supported > Map Monkey
Old 11-29-2004, 05:25 PM   #1
Map Monkey Creator
Ninja Monkey's Avatar
Ninja Monkey is on a distinguished road
Exclamation Destinator 3 Frontend v1.1.3 BETA 2 - Let's try again!
OK, most if not all the bugs that I was alerted to have been fixed. So it's time for you all to find me a whole set of new ones!
Especially seeing as I've also added a couple of stuff and made some changes!
Code:
Version History [v1.1.3.14 BETA 2] *New Features* -------------- -Import Speed Cams into Favorites On the configuration screen, you can now choose to import all of the speed cameras of your chosen database straight into the FE_SPEEDCAMS favorites folder of destinator. This means they will appear straight on the map rather than having to wait for them to be detected before showing up. -Custom Speed Warning By editing the value in Settings.INI, you can have a custom speed warning that will alert you when reach a certain speed. -Scroll Buttons There are now buttons on dialog screens that allow you to scroll up and down any lists. This helps touchscreen users who find it difficuilt to use the small scrollbar. -Camera Warning Sounds There is now a different warning sound for each type of camera. Any new types of camera can also have sounds made for them by creating a wave file and calling it Warning[x]_[TYPE].wav and placing it in the WAVE folder. -CdRsKuLL Skin The popular skin by CdRsKuLL has been updated for 1.1.3 and is now the default. *Changes / Fixes* ----------------- -Logic mode working incorrectly A bug was occurring where you wouldn't be notified audibly if logic mode was enabled and there wasn't a speed specified for the road. This has now been resolved. -Number of satellites not displayed The number of satellites was always displaying as 0. This is now fixed. -Enter Key on OSK not opening "Sort-By" dialog This is now resolved -Cycle Forward Hotkey This doesn't click navigate after the last dialog. Instead it returns to the first. To click navigate use the FE_CLICK_BUTTON_1 hotkey. -Global Hotkeys when embedded An error was occurring when using global hotkeys embedded. This should now be fixed. -Advanced Mode Several bugs were found with advanced mode. These should all be resolved.
It also looks like the NETHERLANDS speed cam database wasn't named correctly on the last release, so it wasn't included in the selection list. It should be there now
Destinator 3 Frontend BETA 2 (1.1.3.14) [11.4MB]
Go get 'em!
Destinator 3 For PC! - http://www.map-monkey.co.uk/
Ninja Monkey is offline   Reply With Quote
Advertisement Sponsored links
Old 11-29-2004, 05:36 PM   #2
ThEScReW's Avatar
ThEScReW is on a distinguished road
Here in belgium it works fine to me :-) The only problem i had was that the ETR too much on the left side is to let me show my CITY name witch is sint-eloois-winkel it ETR is above my city name.
When i start beta 2 i have the same problem warning as in beta 1 but now D3 does not stops, it just go's :-)
Good JOB !
ThE ScReW's CarPuter :-)
ThEScReW is offline   Reply With Quote
Old 11-29-2004, 05:50 PM   #3
DJSmiley is on a distinguished road
- Error message when trying to import a speed camera database:
(configuration, GPS, country selected, and pressed "import")
Quote:
Error Details:
Number: -2147467259
Description: Het veldscheidingsteken uit de specificatie voor het tekstbestand komt overeen met het decimaalteken of het tekstscheidingsteken.
Source: Import_SCDB
Version: 1.1.314
HelpContext: 5003441
HelpFile:
LastDllError: 0
Description (Translated): The fieldseparation symbol from the specification of the text file equials the decimal symbol or the separation symbol
Another note: The speed displayed in the right bottom is rather unreadable. I prefer a black box around it in order to improve visibility.
DJSmiley is offline   Reply With Quote
Old 11-29-2004, 05:57 PM   #4
Confusion Master
Enforcer's Avatar
Enforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant future
ooh!, just got around to putting the first beta onto the car PC.
Enforcer is offline   Reply With Quote
Old 11-29-2004, 06:05 PM   #5
Seth's Avatar
Seth is on a distinguished road
Excellent job NM
Will test it tomorrow......thank you for sharing your work.
Edit :
CdRsKuLL your skin is f****** amazing. I love you man
Seth is offline   Reply With Quote
Old 11-29-2004, 06:05 PM   #6
Map Monkey Creator
Meh!? Does speed camera detection work?
Also, you can change the colour of the speed / shadow in the skin.ini
Old 11-29-2004, 06:12 PM   #7
OriginalNick2 is on a distinguished road
wish the maps got this much development!
OriginalNick2 is offline   Reply With Quote
Old 11-29-2004, 06:30 PM   #8
knubile's Avatar
knubile is on a distinguished road
I still can't get this to run embedded in FrodoPlayer. I looked around and see others have. What am I missing? It was working for me in 1.1.2. With 1.1.3 it shows the destinator windows for a split second then goes back to FrodoPlayer.
I have to set it "use external application" for it to show. But then I can't go back to
FrodoPlayer without exiting destinator altogether.
Anyone?
knubile is offline   Reply With Quote
Old 11-29-2004, 06:41 PM   #9
Map Monkey Creator
Anyone?
Like I said last time, I imagine it's the nag screen interefering with frodoplayer looking for the mapping window. I'll test it myself without the nag screen to confirm - and if not, i'll fix it
Old 11-29-2004, 06:48 PM   #10
MoFo's Avatar
MoFo is on a distinguished road
yeah i'm pretty sure its the nag screen. Because if you load FP then load D3, then click the GPS button in FP...FP will 'capture' the D3 window and embed it
MoFo is offline   Reply With Quote
Old 11-29-2004, 06:52 PM   #11
knubile's Avatar
Didn't catch that explanation in the other bug thread. Sorry about that.
Old 11-29-2004, 06:58 PM   #12
Map Monkey Creator
No problem, I just get touchy when I have to repeat myself again and again and again and again...
Old 11-29-2004, 07:04 PM   #13
Rub One Out
Motoko's Avatar
Motoko is a glorious beacon of lightMotoko is a glorious beacon of lightMotoko is a glorious beacon of lightMotoko is a glorious beacon of lightMotoko is a glorious beacon of lightMotoko is a glorious beacon of light
you put the aplha beta in your car!
CarPC status: iPod, 3,456,217 songs so **** you
Motoko is offline   Reply With Quote
Old 11-29-2004, 07:11 PM   #14
Loads into Frodo fine for me - but skin changes are lost and get a destclient.exe error on closing Frodoplayer
Old 11-29-2004, 07:13 PM   #15
F4kk3r0's Avatar
F4kk3r0 is on a distinguished road
It's A freaking Language problem I changed Language to English(United States) AND units asswell. Now it works Fine. Earlier The excel sheet looked kinda funny allso.
F4kk3r0 is offline   Reply With Quote
Destinator 3 Frontend v1.1.3 BETA Ninja Monkey Map Monkey 58 07-19-2005 07:42 AM
BU-303 and Destinator 3 Frontend lummy Map Monkey 15 01-08-2005 05:26 PM
Destinator 3 Frontend v1.1 Ninja Monkey Map Monkey 139 10-25-2004 11:40 PM
Looking for beta testers for new DC-DC PSU MikeH Power Supplies 22 05-18-2004 03:22 PM
Ford Focus ME Skin Beta 1 nitr0genics ME Archive 14 09-08-2003 02:02 PM
