Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > No Longer Supported > Map Monkey
Old 12-04-2004, 07:01 PM   #1
gti
gti is on a distinguished road
Onscreen keyboard (SORTED)
Hi quick question.
Im building a car pc that will use a touch screen display for input, basically will the onscreen keyboard build into the destinator front end work?
At the moment until I receive my screen, im just messing about with the software on my pc. Should I be able to click on the buttons on the onscreen keyboard to enter addresses in the search box? As when I try this nothing happens.
Many Thanks
Trev
gti is offline   Reply With Quote
Old 12-04-2004, 07:14 PM   #2
Map Monkey Creator
Ninja Monkey's Avatar
Ninja Monkey is on a distinguished road
This seems to be a bug that I'm not, under any circumstances, able to recreate
Can you (and anyone else having this problem) answer the following?
1. Operating System / Service Pack
2. Does the problem happen all the time? Is it random?
3. Does it make a difference if you use another skin?
4. Does it make a difference if you start with the /SETUP parameter?
5. Where are you launching the frontend from? (e.g. a Shortcut)
I'd really like to get this fixed!
Destinator 3 For PC! - http://www.map-monkey.co.uk/
Ninja Monkey is offline   Reply With Quote
Old 12-05-2004, 12:29 AM   #3
DJester's Avatar
DJester
Thumbs up OSK problem
I'm having the same problem...
to answer your questions
I'm Running Win XP SP1
Happens all the time when starting from short cut on desktop. I have a desktop Shortcut for configuration and application, happens on both.
When starting the app from the c:\destinatorApps\Frontend_prev or the c:\DestinatorApps directory I don't have the problem.
the above is the same for either skin...
I haven't read all the new posts yet, any resolution for the voice feedback issue?
Great job BTW
DJester
DJester is offline   Reply With Quote
Old 12-05-2004, 12:46 AM   #4
DJester's Avatar
DJester
Additional info...
I just tried to start Destinator from the Apps menu in Frodo player, keyboard works from here.
thanks
DJester
Old 12-05-2004, 04:57 AM   #5
mauri's Avatar
mauri is on a distinguished road
The OSK doesn't work ONLY if launched D3 with the utility of Configuration.
Embedded with Mediacard or directly launched by D3 link it works correctly.
Mauri
mauri is offline   Reply With Quote
Old 12-05-2004, 07:09 AM   #6
Seth's Avatar
Seth is on a distinguished road
Mauri
Wrong....the behaviour is eratic and happens no matter how you start it embedded or not...at least for me
Seth is offline   Reply With Quote
Old 12-05-2004, 07:38 AM   #7
gti
"1. Operating System / Service Pack"
Im running windows xp sp2 (same issue on my other pc that running xp sp1)
"2. Does the problem happen all the time? Is it random?" All the time
All the time
"3. Does it make a difference if you use another skin?"
No
"4. Does it make a difference if you start with the /SETUP parameter?"No
"5. Where are you launching the frontend from? (e.g. a Shortcut)"
Ive tryed running both shortcuts, and also running it throught mediacar
Just to confirm and to ensure your time is not wasted by my own missunderstanding. I should be able to use the mouse to select buttons on the on-screen keyboard yes?
Ninja Monkey If there are any apps,dll or stuff you want me to try just give me a shout.
Trev
Old 12-05-2004, 07:43 AM   #8
Map Monkey Creator
All the time
No
Trev
I'm at a loss. Are you running the app in fullscreen mode? If you are, can you try unchecking "set size & position at startup" and see if it helps?
Edit: Yes, you should be able to use the mouse to click the keys
Old 12-05-2004, 07:44 AM   #9
Map Monkey Creator
Are you saying for you it'll sometimes actually work?
Old 12-05-2004, 08:05 AM   #10
Seth's Avatar
Yes...but without any obvious reason why
Old 12-05-2004, 08:06 AM   #11
gti
Hi im running it in a window at the mo, on the config screen i can not see where you can uncheck the "set size & position at startup" option, unless its in one of the INI files.
Ive also tried setting the rez of the monitor at different rezes and still no luck
Trev
Old 12-05-2004, 08:29 AM   #12
Map Monkey Creator
Trev
It's on the "size & position" tab
Can you try something else - using explorer, go to C:\DestinatorApps\Frontend_PREV and run Destinator3.exe directly and tell me what happens.
Old 12-05-2004, 09:43 AM   #13
gti
Hi Ninja Monkey,
Erm ive looked around and still cant find that tab also when you asked me to enter the DestinatorApps dir, there is no Frontend_PREV folder, just a Frontend folder. Well i ran the exe in that folder and it still does not work.
P.S. (im running 1.1.2) would you like me to try the beta 1.1.3??
Trev
Old 12-05-2004, 09:53 AM   #14
Map Monkey Creator
Hi Ninja Monkey,
Trev
Ahh, ok... I can't remember if there were issues in 1.1.2 that I fixed for the beta.
I know seth is having random OSK problems with 1.1.3 but can you give it a try anyway?
Old 12-05-2004, 10:11 AM   #15
gti
Right ive just repeated all the previous tests that i did with 1.1.2 with 1.1.3
Ie loading the app through media car, loading the exe direct ect.
As before no luck, but i have noticed this. When i click in the textbox control and then click a button on the OSK, the button goes down like a normal windows button and there is a beep through the speakers but no chr appears in the text control. if i then click another button there is a beep through the speakers, but the button does not go down and pop back up like before.
Hope this helps
Trev
Laptop keyboard to the PS2 port.... claylong General Hardware Discussion 8 09-22-2007 07:29 AM
2 part question (keyboard hacks) chuckctv Input Devices 17 09-07-2004 09:24 PM
mini keyboard Alphared Input Devices 25 07-27-2004 11:32 AM
Hows about this for onscreen keyboard? phil.45 General Hardware Discussion 0 07-21-2002 01:00 PM
Disabling BIOS keyboard error? Squeezer General Hardware Discussion 3 02-02-2001 09:29 AM
