Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > No Longer Supported > Map Monkey
Old 12-28-2004, 03:55 PM   #1
Map Monkey Creator
Ninja Monkey's Avatar
Ninja Monkey is on a distinguished road
Destinator freezing when you approach a speed camera?
If destinator is locking up / CPU hitting the roof whenever you approach a speed camera read below, I've recently had time to test this bug and I think I've got the answer...
It is most likely because you have imported all the speed cameras into destinator (using the frontends own import tool) and also have "Add / Display new cameras on the map" enabled (Under Advanced GPS settings).
When you approach a camera, the frontend will check whether it already exists in the favorites and if not - add it. The SDK is really slow at reading through this information and so if you have thousands of entries you're going to have problems...
If you have imported all the cameras into destinator then I recommend that you disable "Add/Display New Cameras on the map". It won't stop them appearing, because they've all been added manually anyway.
Destinator 3 For PC! - http://www.map-monkey.co.uk/
Ninja Monkey is offline   Reply With Quote
Old 01-28-2005, 05:53 AM   #2
caddy_mattee is on a distinguished road
I've installed the new beta, and hotfix and still have the freezing problem when I approach a speed camera.
I've looked for the function "Add/Display New Cameras on the map" in the configuration, but can't find it.
is there any other way to solve this problem?
caddy_mattee is offline   Reply With Quote
Old 01-28-2005, 06:53 AM   #3
OriginalNick2 is on a distinguished road
run the dest3.1 configuration shortcut in C:\destinatorapps
OriginalNick2 is offline   Reply With Quote
Old 01-28-2005, 06:58 AM   #4
I think I've done that allready...
Old 01-28-2005, 08:02 AM   #5
Raw Wave
ShawJohn's Avatar
ShawJohn is on a distinguished road
Try running it as Destinator3.exe /setup
ShawJohn is offline   Reply With Quote
Old 01-28-2005, 01:50 PM   #6
Map Monkey Creator
It's the very last option on the Adv GPS tab.
It may be called something slightly different in the newest version, but it's something about displaying/adding cameras to the map
Old 01-28-2005, 05:36 PM   #7
Map Monkey Creator
Also note that is is fixed in the final version, whether your cameras are imported or not
Old 01-29-2005, 04:58 AM   #8
sow the problem is that you may not display the camera at the screen.
ok when this fixes the problem I will uncheck the "display speed camera's" (or something like that).
thanx monkey!
Old 01-29-2005, 05:30 AM   #9
Map Monkey Creator
No....you imported them, so they WILL be shown on the map regardless
I'll go insane having to explain this so many times, i know it!
Old 01-29-2005, 05:49 AM   #10
I'm sorry, and you are....?
frodobaggins's Avatar
frodobaggins will become famous soon enoughfrodobaggins will become famous soon enough
K Farber, with beens o' right yo. Will not believe manual
crap RTFM! foo! There has increased the right to belief
the. Who ? My mother has lol wtf. Can you not believe ?
[H]4 Life
I'm a lesbian too.
I am for hire!
frodobaggins is offline   Reply With Quote
Old 01-31-2005, 06:37 PM   #11
Chita79's Avatar
Chita79 is on a distinguished road
here is some interesting info.... my PC freezes up when Map Monkey 1.1.3 is running, and it happends randomly. I have to reset the PC and thats not cool when your on the road because that would be impossible! Any ideas NM? i PMed u about this and i updated to the new version and i still have that issue. I am not overheating my pc and everything else works fine on my pc. I turned off the speed cameras too in the configuration.
'05 Acura TL w/ Navi & Bluetooth, JL Audio Cleansweep, JL Audio XR650 CSI, JL Audio XR650 CXI, JL Audio 300/4 Speaker Amp, Eclipse SW6123.4 12" Sub, JL Audio 250/1 Sub Amp, Optima D35 YellowTop Battery http://www.cardomain.com/ride/2184473/1
Chita79 is offline   Reply With Quote
SPEED CAMERA: countries to be included in 1.1.3 miagi Map Monkey 23 12-29-2005 10:05 AM
Speed Camera FAQ ? ccsnet Map Monkey 12 12-29-2004 05:14 AM
Speed Camera Alerts for Destinator 3.1 Matthew230 GPS 28 10-27-2004 08:33 AM
Speed camera detection software on laptop rickyaswell LCD/Display 5 08-26-2004 08:13 AM
Updated Destinator: with Speed/Bearing, Winamp control and Speed Camera Database Confused MediaCar 11 04-12-2004 06:10 AM
