Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > No Longer Supported > Map Monkey
Old 01-13-2005, 03:59 PM   #46
Raw Wave
Laidback's Avatar
Laidback is on a distinguished road
Quote: Originally Posted by Ninja Monkey
5. I can't control mediacar
That's a bit bizzare, Mediacar can't have changed either! Maybe your sending a back/esc keystroke when d3fe is closing or something?
Laidback
Laidback Carputer
Laidback is offline   Reply With Quote
Old 01-13-2005, 07:54 PM   #47
SBDJ's Avatar
SBDJ is on a distinguished road
Quote: Originally Posted by Enforcer
5. When dest is closed down when it is embedded in Mediacar, it just goes back to main menu, previous versions went back to last option activated, ie Music.
Mine has always done this?
SB
"The gene pool could use a little chlorine..."
SBDJ is offline   Reply With Quote
Old 01-13-2005, 08:51 PM   #48
wizawuza is on a distinguished road
Quote: Originally Posted by wizz
We have a major routes of europe map where a european international journey can be planned, but I don't think a similar map is available for USA, at least I have never seen one.
Wizz
http://www.buygpsnow.com/item.aspx?itemid=285
note: I've never installed this major roads stuff, so I'm not sure if it works, and I'm not sure if it's cheaper somewhere else. If it is, PM me!!!
wizawuza is offline   Reply With Quote
Old 01-13-2005, 09:23 PM   #49
IQ < 70
dim-8 is on a distinguished road
now does destinator use the pocket pc or palm systems, or windows? i know this frontend is for windows, but if i want to buy the maps, do i need the pocket pc maps? and if i use the pocket pc ones, i need to load new maps every once in a while to keep the trip going? will destinator use existing maps? i have delorme street atlas, and i'm assuming it won't use the map files in there, i need destinator, right? and if i need destinator, and they make one for windows, not just the pda files, where is the best place to buy it from. i want to try this frontend, it looks EXACTLY like what i'm looking for, 3d viewing, turn by turn directions, rerouting for avoiding routes, whammo.
dim-8 is offline   Reply With Quote
Old 01-14-2005, 04:25 AM   #50
Confusion Master
Enforcer's Avatar
Enforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant future
1. Have you even looked in destinators own settings?
2. SiRF or NMEA?
3 & 4 I'll look into
1.
(some of the below may be settings I need to change, so if they are I apologise now).
Destinators startup defaults have been changed.
2. NMEA
5. Not expecting you too, just mediacar has not changed but the behaviour has since the new beta came out. Will doublecheck this to make sure I'm not seeing things
As said before, nice work ninja.
Enforcer is offline   Reply With Quote
Old 01-14-2005, 07:39 AM   #51
See me in my wet t-shirt.
stevieg's Avatar
stevieg is on a distinguished road
Think you buy the pocket PC version with the maps you want.
UK at least 1 map for whole of the country.
Ford Focus MP3 : www.stevieg.org/carpc Blog Updated 29 January 2009!
Car PC Status: Complete - Undergoing Software Redevelopment
stevieg is offline   Reply With Quote
Old 01-14-2005, 09:01 AM   #52
grave is on a distinguished road
@ Ninja Monkey great job, works fine in sirf !
I have two questions :
First : Custom speed alert : works with one speed. Could it be possible for alert user when speed is over autorized speed + delta speed ?
ex : Delta speed 5 km/h In town alert for 50+5= 55 km/h
In autospeed alert for 130+5=135 km/h
Second :What about a new icon in menubar for direct access to "my favs" ? It could be better than only "Go Home"
grave is offline   Reply With Quote
Old 01-14-2005, 09:26 AM   #53
superbowl's Avatar
superbowl is on a distinguished road
@Ninja:
In germany we donīt need things linke a speed alert on highways ;-)
But what about a warning like "your speed exceeds 220 km/h, please slow down to save fuel" ?
- superbowl
superbowl is offline   Reply With Quote
Old 01-14-2005, 12:46 PM   #54
MySQL Error
MatrixPC's Avatar
MatrixPC is on a distinguished road
Just some good comment.
Darn nice work, installer look prettier
I have Delorme Yellow USB GPS.
I can run D3 in SiRF mode and Routis in NMEA mode at the same time via virtual COM ports Xport2 and Compass
In D3 front end just setup the whatever COM port, SiRF, and Auto Detect for port speed.
I don't use any speed alert or camera thinggy as we do not have the DB for it yet
Thanks NM
Y2K Accord Dell GX150
EmoRebellion is a SCAMMER
MatrixPC is offline   Reply With Quote
Old 01-14-2005, 02:50 PM   #55
Raw Wave
Laidback's Avatar
Thanks NM
What?? Are you saying the yellow thing spits out NMEA & SIRF...at the same time?!
Laidback
Laidback Carputer
Old 01-14-2005, 03:27 PM   #56
MySQL Error
MatrixPC's Avatar
Yup, that is what the setting in D3 FE. SiRF and COM6 (Via Xport2), and Auto Detect for speed. I am not sure if it work like that or NOT, but when I come back to the setting screen, whatever I selected before, still selected.
Old 01-14-2005, 03:38 PM   #57
Map Monkey Creator
Ninja Monkey's Avatar
Ninja Monkey is on a distinguished road
Nah, if SiRF fails it tries to use NMEA instead. The frontend is probably running with NMEA
Destinator 3 For PC! - http://www.map-monkey.co.uk/
Ninja Monkey is offline   Reply With Quote
Old 01-14-2005, 05:16 PM   #58
Chita79's Avatar
Chita79 is on a distinguished road
Anyone else having issues embedding the latest D3 1.1.3 with Frodoplayer 1.09 Take 3? When i try to embed it, it briefly shows the song on the top, then exits D3 soon after.... any ideas? Is this not supported as of yet? And my other quick question was when NM is planning to get rid of that Beta Text on the top right corver of the map... its kinda annoying ..... great job on your coding NM! MUCH props!!
'05 Acura TL w/ Navi & Bluetooth, JL Audio Cleansweep, JL Audio XR650 CSI, JL Audio XR650 CXI, JL Audio 300/4 Speaker Amp, Eclipse SW6123.4 12" Sub, JL Audio 250/1 Sub Amp, Optima D35 YellowTop Battery http://www.cardomain.com/ride/2184473/1
Chita79 is offline   Reply With Quote
Old 01-16-2005, 02:37 PM   #59
The Vauxhall Vectra Project
ccsnet's Avatar
ccsnet has a spectacular aura aboutccsnet has a spectacular aura about
Right time for my report... one problem but I can't even say waht it is.
Right - SiRF mode - bob on.... worked fine. No noticable CPU killing this time other than when I zoom in and out the music stopped for a while a second or two. I put this down to the CPU ( being a 800hz ) because I have a 16mb vid card installed for just such a reason... more memory might help. I sorted of prooved this by going in to the 2D mode which did not suffer the same problem... as much.
Apart from that after importing my cameras ( as discussed in the bug thred ) most of them disapeared - defo the local ones - as a consiquence they where no longer been shown.
How ever... as I was passing one point where there was a camera the machine sort of stopped - it was not hung as the music every few seconds came back on... in other words the CPU was being hammered I think... again no error messages but I ended up reseting it. I had set the view to the default of birds eye but at the time I was in 2D mode...
Any way - ended up setting D2 again with the new map... the strange thing was that the GPS had now defaulted back to the NMEA mode...
Hope thats helpfull NM...
Terran
PS - I'm all over in the next month or so ... this means if you do get a fix out soon I may be able to test it over a few thousand miles for you.
ccsnet is offline   Reply With Quote
Old 01-23-2005, 01:05 PM   #60
My man uses Levitra.
Peoples's Avatar
Peoples is on a distinguished road
is the front end install link down? I cant seem to find this anywhere. If anyone has it posted anywhere else can you please PM me. I already searched, just cant find it. The link at the begining of this forum is down.
PC Components:
My work log
Peoples is offline   Reply With Quote
Destinator 3 Frontend v1.1.3 BETA Ninja Monkey Map Monkey 58 07-19-2005 07:42 AM
Destinator 3 Frontend v1.1.3 BETA 2 - Let's try again! Ninja Monkey Map Monkey 49 01-16-2005 05:45 PM
Map Monkey : Screenshots here Ninja Monkey Map Monkey 0 12-25-2004 10:17 PM
Delorme Street Atlas 05 quick review cash_Money GPS 7 12-13-2004 08:31 PM
Content Relevant URLs by vBSEO 3.3.0
"VaultWiki" powered by VaultWiki v2.5.2.
Copyright © 2008 - 2009, Cracked Egg Studios.Ad Management by RedTyger
