TESTING OF 1.1.3 IS NOW OVER
Download updated 16th Jan to include Hotfix #1, #2 and #3
Code:
Version History
[v1.1.3.29 BETA3 Hotfix 3]
-Added ability to import PocketGPS databases
-Added ability to export speed camera databases to CSV
-Fixed issues with Centrafuse closing the frontend
-Fixed overflow errors with speed camera alerts
[v1.1.3.26 BETA3 Hotfix 2]
-Added ability to set volume for voice directions
-Non-English regional settings should now be supported
[v1.1.3.23 BETA 3]
*New Features*
-Destinator Frontend SDK (D3Talk)
The SDK for the frontend has been released. This makes it
very easy to create your own plugins or embed and integrate
the frontend fully in your application.
-Plugin Structure
The frontend now allows you to select the plugins to use
at startup.
-SiRF Support in Advanced Mode
It is now possible to recieve higher quality updates via the
SiRF protocol. This has not been fully tested.
-Windows Media Player Control
You can now map your Prev/Play/Next buttons to Windows Media
Player.
-QuickFavorite
A button on your skin or a hotkey can now be assigned to
quickly add the current location into a favorites folder.
Only the "Classic" skin has this button by default.
-Default Address Sort View
You can now specify the default view to use on the route to
address dialog
-Background image on skin
By placing a "Tile.JPG" inside your skin folder, the image will
be tiled on your skins background rather than a colour.
-Hide Mouse
It is now possible to allow Destinator to hide your mouse while
it's running (and make it visible again upon exiting)
-Remove Speed Camera
When a speed camera warning appears, a button also appears next
to the "Add Speed Camera" button allowing you to delete the
camera from the database
-Route Home
A new destinate option has been added called "Go Home". This
allows you to quickly route to some preset coordinates.
*Changes / Fixes*
-Speed Camera Databases
The speed camera detection now uses full databases to store and
retrieve data. This should greatly improve speed of operation
and work independent of the users language settings.
-Border around speed
As well as a shadow effect, it is also possible to simply have a
coloured border around the on-screen speed display
-Clicking Satellite Image
Clicking the satellite image next to the satellite count will now
open GPS Status
-ETA/ETR
Estimated Times Remaining/Arriving have had a complete overhaul.
They are now determined on the fly using your current speed. If you
are not using Advanced mode they are calculated using a customisable
preset speed.
-Scroll Speed in Dialogs
The scrolling speed of the scroll buttons when in dialogs has been
greatly reduced
-Zoom Steps
You can now customise the amount of steps between each zoom (for the
skinnable zoom buttons and zoom hotkeys)
-Hotkeys for scroll buttons
Hotkeys have been added for scrolling dialogs
-Other Bugs/Fixes
Many other undocumented or trivial bugs have been resolved.
Now this version is the first to offer full support for plugins! The SDK is so easy to use I created 4 to include in the standard installation!
Daily Logs
This plugin, when activated, will keep a categorised-by-day history of your entire journeys including total distance travelled, speed, road name etc.. Look back at any point in time and see exactly where you were!
External Audio
Have alerts for upcoming maneuvers played on a different sound card
SAPI Plugin
Prefer a customisable computerised voice for voice directions? Well here you go! This plugin can even speak the name of the road you need to be turning into as well as the added option of announcing whenever you enter a new area (city / zipcode etc)
Location Trigger
An advanced database-driven plugin that lets you perform actions based on your current whereabouts. You can specifiy the sensitivity, required max/min distances, speeds, bearing. Once set you can specifiy either a sound file to play or even run an application passing your coordinates as parameters.
An extra feature of this plugin allows you to set up a keyboard shortcut to automatically add an item to the database based on your current location and then automatically begin recording the sound file to play!
Download Here [15.1MB]
Find me some bugs!
