01-22-2005, 11:30 AM
#1
Map Monkey Creator
Centrafuse Launcher (Fixes Map Movement)
I've written a D3 Launcher for centrafuse that will workaround the map not moving problem
I've only given it a quick test so your feedback would be appreciated.
Simply copy the EXE into your Frontend_BETA3 folder and then in centrafuse:
Point your GPS application to : C:\DestinatorApps\Frontend_BETA3\CFD3Launcher.exe
Set the GPS Window Title to : CFD3
Also, ensure that Plugin support is enabled and "Set size & Position" is disabled in Destinator configuration.
What this won't currently do
Although the launcher will only run if centrafuse is running, when centrafuse is closed it doesn't send the correct message to quit applications and freezes the app...so the closing problem still remains. This needs to be fixed in centrafuse.
Download here
01-22-2005, 11:37 AM
#2
just tryed it and i get a sceen that is embeded saying launching destinator but another window opens with destinator in it ontop
Program aborting close all that you have worked on,You ask to much. You step into the stream,but the water has moved on, This page is not here. Chaos reigns within, Reflect,repent,and reboot.Order shall return The car
01-22-2005, 11:40 AM
#3
Map Monkey Creator
Did you enable plugin support?
01-22-2005, 11:45 AM
#4
it was size and posish had it ticked and plugin not ticked all fine now thanks
your the man
also it doesnt freeze any more when exiting .destinator keeps running fine so its nice and easy to exit it properly once CF has closed
01-22-2005, 11:55 AM
#5
nice work ninja monkey
01-22-2005, 01:25 PM
#6
VENDOR - Centrafuse
Great job Ninja... I am looking into the closing problem.... I will get something figured out and include in my next update..
david
01-22-2005, 05:22 PM
#7
Hi there,
Great job in getting it going, only one slight problem. When i went to change the the volume in centrafuse the navigation window dissapeared and alll i could see was the ninja monkey splash screen. I exited centrafuse and the window was then shown for destinator.
01-22-2005, 06:09 PM
#8
Map Monkey Creator
Quote: Originally Posted by clkraj
Hi there,
When you clicked volume the destinator window should have dissapeared but then reappeared after a brief moment, if it didn't then there's something wrong with your setup, it works fine here.
Like I said, this is a workaround not a solution. It's just so you guys using centrafuse can at least have destinator working until we figure this thing out
01-22-2005, 06:12 PM
#9
Great
Hi Ninja,
GREAT ! THANKS !
- superbowl
i never drink water cos fish ***** in it. (w.c. fields)
01-23-2005, 11:33 PM
#10
NM, You da Man !!!
Can't wait for "Map Monkey", although I like Gorilla Guidance myself.
Keep up the awesome work.
'94 Mazda T3500 Bus, Lilliput 7", Mouse GPS, 1GHz TC1100 Tablet PC, Inverter, HUGE Spare battery, Smart Charger, Road Runner, FreeDrive.
01-24-2005, 01:34 AM
#11
It doesn't reappear on my setup untill i tap the space were destinator should be.
Any ideas whats wrong with my setup ?
01-24-2005, 09:58 AM
#12
Hi,
i experience the same behaviour as skydiver. Whenever i press a "centrafuse-button" the map disapears and only the splash screen is visible. A single tap in the "maparea" brings it back.
My problems with the osk have disappeared, so i guess it was my error in configuration.
- Superbowl
01-28-2005, 05:47 PM
#13
@ clkraj same here but wait for the correct fix in CF 1.13. That will fix it I'm sure.
01-31-2005, 10:51 AM
#14
See me in my wet t-shirt.
Hiya
Does this need to be updated to work with Map Monkey or is there a way I can get it working
Ford Focus MP3 : www.stevieg.org/carpc Blog Updated 29 January 2009!
Car PC Status: Complete - Undergoing Software Redevelopment
01-31-2005, 01:22 PM
#15
yeah i would like to get it to work with mapmonkey
i think its just a change in the exe to upen mapmonkey.exe instead of the beta .exe
my destinator map resource down permanently
| Thread Tools |
| Display Modes |
Linear Mode
