Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Support Software > Map Monkey
Old 01-30-2005, 04:08 PM   #31
Map Monkey Creator
Ninja Monkey's Avatar
Quote: Originally Posted by sajeev
I bought D3 UK version and was using your version 1.1.2. If I want to use the final version 1.1.3 what exactly do I need to do. (Officially) I have downloaded it already.
I changed the dest dll on 1.1.3, replaced it with the one from 1.1.2 without any problems.
This got rid of the message on screen regarding the SDK.
How I installed the 1.1.3 was that I removed old destinator apps folder from c drive then installed the new one.
Is this the correct way?
Can you please put me right.
Thanks.
That should work fine...I can't tell from your post, but are you having problems with doing it that way?
Destinator 3 For PC! - http://www.map-monkey.co.uk/
Ninja Monkey is offline   Reply With Quote
Old 01-30-2005, 04:11 PM   #32
mauri's Avatar
Good good work, Ninja
To work Map Monkey embedded to Mediacar or the new Road Runner ,the setup correct , EXTERNAL ,and "search string "its the old *Destinator 3* or *Map Monkey* ?
To don't wiev the nag bar ,set to "Fullscreen" ?
All its ok !!!!!
Mauri
mauri is offline   Reply With Quote
Old 01-30-2005, 04:49 PM   #33
So now that you've done it the official route, have destinator given you access to a newer SDK where TMC is enabled ?
/M
Maximus is offline   Reply With Quote
Old 01-30-2005, 04:56 PM   #34
Raw Wave
Laidback's Avatar
/M
Is there a newer SDK where TMC is enabled ?
Laidback
Laidback Carputer
Laidback is offline   Reply With Quote
Old 01-30-2005, 05:12 PM   #35
got to say GREAT WORK ninja!! ivīe got it working perfectly love the new "monkey" look to it
Dj_Aleks is offline   Reply With Quote
Old 01-30-2005, 05:19 PM   #36
superbowl's Avatar
Hi,
stupid question, how do i remove the huge yellow speed indicator ?
Until now, i thought removal of this would be possible in the final release,
but i canīt find it. Where is it hidden ?
- Superbowl
i never drink water cos fish ***** in it. (w.c. fields)
superbowl is offline   Reply With Quote
Old 01-30-2005, 05:54 PM   #37
Map Monkey Creator
Quote: Originally Posted by superbowl
Hi,
- Superbowl
I haven't had chance to document this in the FAQ yet, but if you open the SKIN.INI of the skin you're using and change this line
SpeedColor=-1
That should get rid of it
Old 01-30-2005, 06:53 PM   #38
Tribune-Maximus's Avatar
@ Map Monkey
Really great work with the v1.1.3 Release !!!
Have only two problems !? Hope you can help with this!!
1. The final seems to be no longer embedded in FP!? Can't get it work lile the Beta3
2. Speed Display is only MPH/Yard ...no change when i set to Metric in Setup !?
What's the way to solve this little cosmetic 'problems'???
REGARDS
tribune
Shuttle FE22 P3-800MHz C3, 512MB RAM
Morex 3688 black, CarTFT-M1-PowerSupply
Lilliput 7" Touchscreen TFT Monitor
Holux GM-210 GPS USB Device
Ovislink WL5480 WLan Device / 8dbi
24Bit USB Soundcard
Tribune-Maximus is offline   Reply With Quote
Old 01-30-2005, 06:59 PM   #39
Map Monkey Creator
Quote: Originally Posted by Tribune-Maximus
@ Map Monkey
REGARDS
tribune
Which setup screen did you use to change it to metric?
Old 01-30-2005, 07:06 PM   #40
mauri's Avatar
No, embedded to Mediacar MM appears correctly,but covers completely the bar aloft of MC, as if and launched in stand-halone.
Setting MC with EXTERNAL, and string * map * or * map monkey * but don't work
Mauri
Old 01-30-2005, 07:07 PM   #41
Map Monkey Creator
a screenshot if you will, mauri
Old 01-30-2005, 07:12 PM   #42
mauri's Avatar
Simple,the MM apperas some whit the launch stand-alone.
MM work correctly,only embedded to mediacar have the problem.
I launch MC, click on GPS, appears for one second the MC bar, MM apperas and cover the bar
The screen its to MM embedded to MC,the same of launch in stand-alone mode
Mauri
Old 01-30-2005, 07:18 PM   #43
@ Map Monkey
First Problem solved...HDD failure ) ...it's just working fine with Km/h
...but like Mauri said...the final vers. launches as standalone also in FP
...that's what i meant!
Is there any option to set to solve this??
REGARDS
tribune
24Bit USB Soundcard
Old 01-30-2005, 07:24 PM   #44
Map Monkey Creator
Try setting the window title as the full "Map Monkey - [GPS]" ?
Old 01-30-2005, 07:36 PM   #45
mauri's Avatar
Tested for "Search string "whit :
map
Map
Map Monkey
"Map Monkey"
*map*
*Map*
*Map Monkey*
*Map Monkey - [GPS]*
Map Monkey - [GPS]
Don't work, not se resize to view the bar of MC
Mauri
Map Monkey v1.1.3 BETA 3 Ninja Monkey Map Monkey 72 03-29-2005 08:50 AM
Map Monkey final - release data? alanp Map Monkey 1 01-27-2005 05:43 PM
Map Monkey : Screenshots here Ninja Monkey Map Monkey 0 12-25-2004 09:17 PM
Delorme Street Atlas 05 quick review cash_Money GPS 7 12-13-2004 07:31 PM
