Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > No Longer Supported > Map Monkey
Old 01-30-2005, 09:36 PM   #46
Map Monkey Creator
Ninja Monkey's Avatar
Ninja Monkey is on a distinguished road
Quote: Originally Posted by mauri
Tested for "Search string "whit :
map
Map
Map Monkey
"Map Monkey - [GPS]"
"Map Monkey"
*map*
*Map*
*Map Monkey*
*Map Monkey - [GPS]*
Map Monkey - [GPS]
Don't work, not se resize to view the bar of MC
Mauri
Try re-downloading this and then setting the search string to:
Map Monkey -*
Destinator 3 For PC! - http://www.map-monkey.co.uk/
Ninja Monkey is offline   Reply With Quote
Old 01-30-2005, 09:58 PM   #47
forevertheuni's Avatar
forevertheuni is on a distinguished road
linux
anyone can run ninja monkey's frontend in linux with wine/cedega/crossover wine?
forevertheuni is offline   Reply With Quote
Old 01-31-2005, 04:20 AM   #48
mauri's Avatar
mauri is on a distinguished road
Map Monkey -*
All OK Ninja, fixed the problem!
Your hare the best :-))
Mauri
mauri is offline   Reply With Quote
Old 01-31-2005, 04:26 AM   #49
Confusion Master
Enforcer's Avatar
Enforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant future
Quote: Originally Posted by Tribune-Maximus
@ Map Monkey
Who the hell is Map Monkey???
It's Ninja Monkey dammit.
Enforcer is offline   Reply With Quote
Old 01-31-2005, 04:36 AM   #50
Confusion Master
Enforcer's Avatar
No, embedded to Mediacar MM appears correctly,but covers completely the bar aloft of MC, as if and launched in stand-halone.
Setting MC with EXTERNAL, and string * map * or * map monkey * but don't work
Mauri
Make sure this thread is not open if you use the string *Map Monkey*.
This ie session has just got embedded into mediacar
otherwise the embedding into Media Car works fine for me.
Old 01-31-2005, 05:33 AM   #51
ildena's Avatar
ildena is on a distinguished road
Guino fixed it
See my car and donate for spinning logos at www.ildena.it/carpc
ildena is offline   Reply With Quote
Old 01-31-2005, 06:54 AM   #52
wizz's Avatar
wizz is on a distinguished road
Mauri
I have the same problem (as your screenshot) Mauri. How did you fix it ?
Wizz
Car : Ford Focus Zetec 1.6
Carpc :Lin-ITX Plus 7" touchscreen/Toad 8" roof screen
Morex 3688 case/M2-ATX PSU/Commell V-672 P4 3.2Ghz/1024DDR2/40GB 2.5" SATA HDD/Sony DVD/CDRW
BU303 GPS/Mercury 11b WiFi/Parking Sensors
Colour I/R Reversing Camera
wizz is offline   Reply With Quote
Old 01-31-2005, 07:09 AM   #53
Confusion Master
Enforcer's Avatar
Wizz
what string are you using to embed?
and what is your exe path?
Old 01-31-2005, 07:58 AM   #54
mauri's Avatar
Wizz
@Wizz
Download the new hotfix by Ninja,
http://www.mp3car.com/vbulletin/show...5&postcount=46
replace the Map Monkey.exe in C.\DestinatorApp\Map Monkey
Open the Mediacar setting utility,set to:
EXTERNAL
Path:C:\DestinatorApps\Map Monkey\MapMonkey.exe
Window search string:Map Monkey -*
Work ok
Mauri
Old 01-31-2005, 08:43 AM   #55
Vik
Vik's Avatar
Vik is on a distinguished road
Hi NM,
I can't seem to get the final version installed.
it sais there is already a newer version installed..
cheers
Vik is offline   Reply With Quote
Old 01-31-2005, 08:46 AM   #56
microbionic's Avatar
microbionic is on a distinguished road
Quote: Originally Posted by Vik
Hi NM,
cheers
uninstall beta 1.3,or whatever version you have, from add remove programs
CarPuter ProgressO meterO
[+++++++++] 100%, 1Ghz Epia M,opus 90w, Earthmate GPS, 7 inch lilliput molded into dash, anything i forget?
visit me on the web at
http://gozips.uakron.edu/~cmk23/
microbionic is offline   Reply With Quote
Old 01-31-2005, 08:56 AM   #57
Registered User
mpattonm's Avatar
mpattonm
Closing MM 1.1.3 with Alt+F4
looks like when closing MM from keyboard, I need to press Alt+F4 key combination twice to get MM fully closed. First Alt+F4 only closes map "window" part while its backgroung remains alive. I have to press Alt+F4 again in order to clos MM completelly. Is there a way to fix it?
mpattonm is offline   Reply With Quote
Old 01-31-2005, 09:18 AM   #58
The Vauxhall Vectra Project
ccsnet's Avatar
ccsnet has a spectacular aura aboutccsnet has a spectacular aura about
Well done and thanks... may well send a donation when I have the money how ever it would be nice if you could get a legal way of buying this properly though PL... I'd be willing to pay for that NP.
Terran
PS Just out of intest - does any one know how many 'proper' users of MM are out there. ( Interprate 'Proper' what ever way you want )
ccsnet is offline   Reply With Quote
Old 01-31-2005, 10:13 AM   #59
Map Monkey Creator
This is a problem with the SDK. The only way I can fix this would be to catch ALT+F4 before it gets sent to the map window. You can do this yourself by opening Hotkeys.INI and changing this line:
Hotkey00=Local,FE_QUIT,{ALT},F4
Old 01-31-2005, 11:41 AM   #60
wizz's Avatar
@Wizz
EXTERNAL
Work ok
Mauri
Hi Mauri,
The only thing I was missing from above was the search string.
But still can't get it right
If I set Maximised the titlebar is still there
If I set Fullscreen there is a gap at the bottom with the taskbar in it
If I hide the taskbar there is still a gap
What am I doing wrong ?
Wizz
Map Monkey v1.1.3 BETA 3 Ninja Monkey Map Monkey 72 03-29-2005 09:50 AM
Map Monkey final - release data? alanp Map Monkey 1 01-27-2005 06:43 PM
Map Monkey : Screenshots here Ninja Monkey Map Monkey 0 12-25-2004 10:17 PM
Delorme Street Atlas 05 quick review cash_Money GPS 7 12-13-2004 08:31 PM
