Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > No Longer Supported > Map Monkey
Old 01-31-2005, 11:48 AM   #61
mauri's Avatar
mauri is on a distinguished road
Whit the setting posted for Mediacar MM work ok in embedded,fix the problem.
But one little problem i have see:
Embedded to MC the two button of scroll UP/DOWN don't work,the OSK its ok.
In stand-alone MM the scroll button work ok.
Setting in MM utility "size and positon " normal",select the " size e position on startup", select " use custom setting," "800x600"
This settings work ok in my PC.
Mauri
mauri is offline   Reply With Quote
Old 01-31-2005, 12:26 PM   #62
wizz's Avatar
wizz is on a distinguished road
Mauri
Mauri,
These are the settings I have, but in normal & maximised the Map Monkey - [GPS] title bar still shows. In Fullscreen it doesn't but I have the windows taskbar showing.
HELP !
EDIT: The settings work OK on my Laptop but not my Carpc.
Wizz
Car : Ford Focus Zetec 1.6
Carpc :Lin-ITX Plus 7" touchscreen/Toad 8" roof screen
Morex 3688 case/M2-ATX PSU/Commell V-672 P4 3.2Ghz/1024DDR2/40GB 2.5" SATA HDD/Sony DVD/CDRW
BU303 GPS/Mercury 11b WiFi/Parking Sensors
Colour I/R Reversing Camera
wizz is offline   Reply With Quote
Old 01-31-2005, 12:54 PM   #63
wizz's Avatar
Quote: Originally Posted by Enforcer
what string are you using to embed?
and what is your exe path?
I have run Mediacar setup and edited to the new path and string *Monkey Map -* , but I still get "Monkey Map - [GPS]" title bar showing.
Wizz
Old 01-31-2005, 01:20 PM   #64
Colt's Avatar
Colt is on a distinguished road
Anyone know how to remove the "Destinator SDK not for sale" message?
Or do I have to buy Destinator to remove that?
Colt is offline   Reply With Quote
Old 01-31-2005, 02:01 PM   #65
wizz's Avatar
SEE
http://www.mp3car.com/vbulletin/mm-faqs/41397-map-not-registered-destinator-sdk-not-sale-messages.html
Wizz
Old 01-31-2005, 02:09 PM   #66
Jamez_Warner
NM - Still no GPS after standby resume !
Using standard BU-303 with usb>serial driver
D2 is fine
any ideas?
James
www.digital-car.co.uk - The UK CarPC Forum
Jamez_Warner is offline   Reply With Quote
Old 01-31-2005, 02:24 PM   #67
mpfjr's Avatar
mpfjr is on a distinguished road
Quote: Originally Posted by wizz
Hey, I own Destinator 3 and Iguidance 2.0(which I have been using) but I just found out about mapmonkey today!! Now I have downloaded ver 1.13 and of course I don't have the modified sdk file.
Which files get modified? is it just DestDLL.DLL? Or are there others? What needs modified? if you can't post the answer please pm me. I do own the software so I feel I should be able to make the changes and use it with map monkey. Iguidance is just not very touch screen friendly even after all the theme.ini's and hacking the exe.
PM me instructions please!
mpfjr is offline   Reply With Quote
Old 01-31-2005, 02:27 PM   #68
Confusion Master
Enforcer's Avatar
Enforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant future
Wizz
try *Map Monkey*
works for me
Enforcer is offline   Reply With Quote
Old 01-31-2005, 03:00 PM   #69
mauri's Avatar
Wizz
I have write in my old post for correct string:
Map Monkey -*
Write as i have done me
Mauri
Old 01-31-2005, 03:11 PM   #70
Tribune-Maximus's Avatar
Tribune-Maximus is on a distinguished road
@ NM
Problem with embedding MM in FP is not solved yet...for me
Have read that other users have the same thing...other descriptions, but
the same problem! (full MM window w/o Titlebar)
Is there any way to fix it??
..the satfix does not fix it...same with the external-gps-solution
REGARDS
tribune
Shuttle FE22 P3-800MHz C3, 512MB RAM
Morex 3688 black, CarTFT-M1-PowerSupply
Lilliput 7" Touchscreen TFT Monitor
Holux GM-210 GPS USB Device
Ovislink WL5480 WLan Device / 8dbi
24Bit USB Soundcard
Tribune-Maximus is offline   Reply With Quote
Old 01-31-2005, 03:41 PM   #71
wizz's Avatar
Map Monkey -*
Mauri
It does not work for me Mauri. I find the best is *Map Monkey - [GPS]*, but even with this I cannot cover the title bar, so I have changed to Windows Classic mode and coloured it Black like yours, so at least it looks ok.
Wizz
Old 01-31-2005, 04:08 PM   #72
mauri's Avatar
Wizz
You use for setting to screen of Windows 96 dpi or 120 dpi?
Setting for test whit "normal,96 dpi"
Mauri
Old 01-31-2005, 04:14 PM   #73
Map Monkey Creator
Ninja Monkey's Avatar
Ninja Monkey is on a distinguished road
Wizz
Have you also replaced the EXE with the one from the zip file?
Destinator 3 For PC! - http://www.map-monkey.co.uk/
Ninja Monkey is offline   Reply With Quote
Old 01-31-2005, 04:16 PM   #74
wizz's Avatar
Mauri
Don't know. Have just taken my screen out of the car (for the night)
I'll check tomorrow. Thanks,
can you put up a screenshot of your skin as it is now ? just to give me an idea of what I am aiming for.
Wizz
Old 01-31-2005, 04:18 PM   #75
wizz's Avatar
Yes, sure have. Should I have the Title Bar showing ?
Wizz
Map Monkey v1.1.3 BETA 3 Ninja Monkey Map Monkey 72 03-29-2005 09:50 AM
Map Monkey final - release data? alanp Map Monkey 1 01-27-2005 06:43 PM
Map Monkey : Screenshots here Ninja Monkey Map Monkey 0 12-25-2004 10:17 PM
Delorme Street Atlas 05 quick review cash_Money GPS 7 12-13-2004 08:31 PM
