01-31-2005, 06:03 PM
#106
Raw Wave
Quote: Originally Posted by wizz
I like you......
Careful, I don't know you!
You are So......QUICK !
So the wife says!
Especially with first posts.
MMMmm, ok!
Wizz
01-31-2005, 06:06 PM
#107
Quote: Originally Posted by GReeToZ
i had to clear the database
then download the cvs from mapmonkey.net then import that one, then add it to favorites works fine now
Forgive me! but how do i add the imported .cvs file to favourites?
01-31-2005, 06:14 PM
#108
Map Monkey Config in DestinatorApps
Advanced GPS...Tools....Import new Cameras
Wizz
Car : Ford Focus Zetec 1.6
Carpc :Lin-ITX Plus 7" touchscreen/Toad 8" roof screen
Morex 3688 case/M2-ATX PSU/Commell V-672 P4 3.2Ghz/1024DDR2/40GB 2.5" SATA HDD/Sony DVD/CDRW
BU303 GPS/Mercury 11b WiFi/Parking Sensors
Colour I/R Reversing Camera
02-01-2005, 04:05 AM
#109
Confusion Master
Whats THIS ? Guess the "embedding string" Game
You're supposed to take the tam**n out before having sex.
02-01-2005, 07:36 AM
#110
Wizz
Thanks for the replys but this is what I have already been doing, but to no avail. The damn icons are not displaying.
Also under the configuration system for searching criteria the "street/City" option does not activate when selected!
This all worked fine for me in the beta version.
Any ideas?
02-01-2005, 08:55 AM
#111
Any ideas?
The camera icons will not display until they are detected. If you have imported them all, then you should be OK. I take it you have also downloaded the Fix.Zip that followed the release of 1.1.3 ? Show icons option needs to be unticked, to avoid slowdown. Also did you do a CLEAN install.
Try changing option to City/street in map monkey config.
Wizz
02-01-2005, 09:12 AM
#112
can anyone else get GPS after standby with mapmonkey ?
James
02-01-2005, 09:15 AM
#113
Wizz
I have used the release which was updated last night, with the fix incorporated. I have also changed the setting within the config page
Ill have to check the "Show icons option" when i get back from work.
Cheers
02-01-2005, 09:22 AM
#114
Cheers
Where is the updated release, didn't see that ?
02-01-2005, 10:02 AM
#115
Check out the first post edited by NM
Im pretty sure that this had the update within the installer!
02-01-2005, 03:14 PM
#116
OK i havent read all the thread, but i know you have imported the cameras but did you click copy to favourites after you imported them. I did the same then suddenly realisedLOL
02-01-2005, 04:36 PM
#117
Good job NM. Great software, i spent saturday configuring and setting it up with my CarPC and it's definitly something i'm gonna use most days.
One thing i noticed is that in the new version, opening up a second instance of MapMonkey brings up an error. Older versions used to keep going as if nothing happened
not a big deal, just thought id bring it to your attention
02-02-2005, 02:03 AM
#118
Okay this is the dumbest question most likely but in the options it says something like add location of the cameras to the map as they are detected what does that mean ? sorry it just that i do not get it ? also how do you add a Red light camera if its not in the DB ? i know if its speed u just press the buttone and it will add it .
thanks and sorry for dumb questions
[|||||-----] 95% complete
02-06-2005, 02:50 AM
#119
My Village Called
Ninja Monkey: Could you add scrollup/down in the dialogs into MonkeyTalk? I have this problem of having two streets with the same name, one being north and one being south. And I can't get any command to move the entree down
[Edit]: Also, ShowGPSStatus does not work
02-06-2005, 07:21 AM
#120
Map Monkey Creator
There isn't a command to scroll a dialog. You can set a hotkey to scroll though, so you could then assign a voice to press the hotkey?
Also, for GPS Status, try <object>.Custom("Show_GPS_Status")
| Thread Tools |
| Display Modes |
Linear Mode
