02-06-2005, 04:05 PM
#121
My Village Called
Quote: Originally Posted by Ninja Monkey
There isn't a command to scroll a dialog. You can set a hotkey to scroll though, so you could then assign a voice to press the hotkey?
Also, for GPS Status, try <object>.Custom("Show_GPS_Status")
Can the scroll a dialog command be something to look foreward t o in the next version?
The Show_GPS_Status doesn't work either. It kindo freezes my app.
02-11-2005, 03:43 PM
#122
The Vauxhall Vectra Project
Just installed Roadrunner and 1.13... I have to say it works a lot better than using MC... MC must have been hogging the ol processor.
@NM - ... can you provide an uninstaller on your next version ? Deleted the ol dir and copied over another version which I had already pre installed the speed cameras and some how it said that there was a higher version installed ??? How ???
Any installed the latest fixed version of 113 then copied it all over and it worked - bravo.
Terran
02-11-2005, 07:53 PM
#123
Map Monkey Creator
There is an uninstaller...look in the start menu
02-12-2005, 11:18 AM
#124
... and heres me thinking look in the add remove area lol... thanks
Heres a link to a post in the RR forum from a problem I had today... I'll see if I can get you more info later....
Terran
http://www.mp3car.com/vbulletin/show...&postcount=158
02-21-2005, 05:06 AM
#125
My Village Called
About the SDK: MyMonkeyTalk.CompassHeading -> An INTEGER indicating the current compass heading.
What would each integer mean?
[Edit]: Request to have ScrollMap in the real sdk instead if sending a custom command.
02-21-2005, 05:11 AM
#126
I'm sorry, and you are....?
shouldn't be too hard to figure out...
[H]4 Life
I'm a lesbian too.
I am for hire!
02-21-2005, 05:14 AM
#127
My Village Called
It is when you can't take a desktop with you on the road and test
And my laptop doesn't have MM
02-28-2005, 04:49 PM
#128
Is it possible to make the City ---> Street ---> Number into touchscreen type buttons (like the ones on the on-screen keyboard) in an upcoming release? Or maybe i'm missing something, meaning is there a way to go to the next entry once you've entered the "city" for instance. When I hit "enter" on the keyboard, it pops up the dialog asking me if I want to change the order of entry.
Biostar MicroATX with 2600+ XP-M
Xenarc TS VGA
60GB Notebook Drive
Opus 150W PSU
Rikaline 6010
Gyration Keyboard and Mouse (for passengers)
5 GB MicroDrive in-dash for quick access
V710 for Bluetooth internet express network
03-03-2005, 09:37 AM
#129
hi Ninja,
can you tell me how to change car motion symbol with another?
03-14-2005, 05:31 PM
#130
IQ < 70
can't get latest release .348 to work. put all the map files into folder into destinator folder, unzipped them, blah blah.. keeps telling me "mm has encountered a problem and needs to close......" error.  'd the forum, no answers here.
03-30-2005, 02:57 AM
#131
Sorry if i'm covering old questions but just wondering if theres a way to convert the measurements to metric via the software?
CAR INFO HERE
"He who dies with the most toys, wins".
03-30-2005, 03:34 AM
#132
Confusion Master
Have you checked all the settings?
03-30-2005, 03:42 AM
#133
It ain't easy being a green moderator
Location: Steps out the front of Henson's workshop or Sydney
It's in the settings of D3. Go menu / settings / general settings. There is a units system setting. Choose MPH or km/h
Chat on the mp3car channel on IRC
Server: efnet Channel: #mp3car
No irc client installed? Go to http://chat.efnet.org/. In the channel drop down box select "other" and type in #mp3car.
04-29-2005, 01:07 PM
#134
hi there,
i have an odd problem: when i launch map monkey the normal way everythign works. it reconnects to GPS at startup, displaying my correct position. Within Centrafuse however, the location-cursor jumps to my current location and then, half a second later, jumps to a totall different adress in my city. when i start to drive the map rotates according to my car-movement but the location is fixed to this specific adress.
I just drove to this adress and guess what happened: the location-cursor jumped irradically somewhere inside a nearby sea...
Then, when i drove back, about 100meters away from this strangly fixed location, i jumped back from the see to the mysterious location.
has anyone encountered a similar phenomenon or has a fix? As i said... normal mapmonkey works like a charm... (despite it also Starts at the mysterious adress but THEN jumps to my correct location)
thanks
My Car-PC: Athlon XP Barton 2800+, 512 MB Ram, 60GB HDD, Radeon 9800 Pro, 7" Touchscreen MM400 :)
04-30-2005, 04:34 AM
#135
If we have these gps values E023°51.232', N038°10.564' how can we convert them to such values that will be recognised by MM?
| Thread Tools |
| Display Modes |
Linear Mode
