Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > No Longer Supported > Map Monkey
Old 01-30-2005, 01:59 PM   #1
Map Monkey Creator
Ninja Monkey's Avatar
Ninja Monkey is on a distinguished road
Exclamation RELEASE: Map Monkey v1.1.3
Edit: Installer has been updated to fix the problems installing over the BETA, Advanced GPS bugs and when closing Map Monkey via the 'X'.
It's here...
Code:
Version History [v1.1.3] *New Features* -------------- -Advanced GPS Mode You can now connect Map Monkey using an advanced mode where information such as speed, heading and number of satellites is available. -Map Monkey SDK (MonkeyTalk) The SDK for Map Monkey has been released. This makes it very easy to create your own plugins or embed and integrate Map Monkey fully in your application. -Speed Camera Detection Map Monkey can now notify you of approaching speed cameras. Cameras can also be easily added or removed from the database via a buttons on the main toolbar -Automatic Update of Speed cameras When connected via the SDK, you can opt to be notified of any approaching cameras. This is useful for custom applications and plugins. -Scroll map with hotkeys You can define hotkeys to scroll the map and also return to the home position. -Fullscreen Mode A hotkey can be defined to enter and exit fullscreen mode. You can also choose to always start in fullscreen. -Reconnect GPS on power resume When returning from standby or hibernate, you can choose to automatically reconnect the GPS. -Navigate Button There is now a navigate button on all dialogs at the bottom right of the screen -Manual Destination You can now route to specific longitude and latitude coordinates. -Speed Display The current speed can be overlayed on top of the mapping window -Customisable Infobar Most aspects of the infobar can now be edited (fonts, colors, positions) by modifying the skin. -Destinator Skins Each skin can now have it's own individual "Destinator Skin" allowing you to change the scrollbar / fonts / internal buttons of destinator without effecting other skins. -Line Mute on Maneuevers As well as Winamp and Frodo control when approaching a maneuver, You can now optionally mute a sound line on your system. (Wave, Mic, Line-in etc..) -Volume Control Buttons can now be added to a skin to control the master volume -Import Speed Cams into Favorites On the configuration screen, you can now choose to import all of the speed cameras of your chosen database straight into the "Imported Speed Cameras" favorites folder of destinator. This means they will appear straight on the map rather than having to wait for them to be detected before showing up. -Custom Speed Warning By editing the value in Settings.INI, you can have a custom speed warning that will alert you when reach a certain speed. -Scroll Buttons There are now buttons on dialog screens that allow you to scroll up and down any lists. This helps touchscreen users who find it difficuilt to use the small scrollbar. -Camera Warning Sounds There are different warning sound for each type of speed camera. Any new types of camera can also have sounds made for them by creating a wave file and calling it Warning[x]_[TYPE].wav and placing it in the WAVE folder. -CdRSkuLL Skin The popular skin by CdRSkuLL has been updated for 1.1.3 and is now the default. -Plugin Structure Map Monkey now allows you to select the plugins to use at startup. -Windows Media Player Control You can now map your Prev/Play/Next buttons to Windows Media Player. -QuickFavorite A button on your skin or a hotkey can now be assigned to quickly add the current location into a favorites folder. Only the "Classic" skin has this button by default. -Default Address Sort View You can now specify the default view to use on the route to address dialog -Background image on skin By placing a "Tile.JPG" inside your skin folder, the image will be tiled on your skins background rather than a colour. -Hide Mouse It is now possible to allow Destinator to hide your mouse while it's running (and make it visible again upon exiting) -Import / Export of Speed Cameras It's possible to import new cameras to the speed camera database (MapMonkey CSV or PocketGPS CSV) and also export the current database to a CSV file. -Set Volume on speak You can now specify a volume for voice directions. This will help keep directions at a safe & suitable level even when the music is loud. *Changes / Fixes* ----------------- -Client/Frontend Merge The client and frontend have been merged into a single application. This will greately increase the speed of operation. -ETA/ETR The Estimated Times were being incorrectly calculated. It has now been fixed. -ETA/ETR (Revamp) Estimated Times Remaining/Arriving have had a complete overhaul. They are now determined on the fly using your current speed. If you are not using Advanced mode they are calculated using a customisable preset speed. -Zoom Steps You can now customise the amount of steps between each zoom (for the skinnable zoom buttons and zoom hotkeys) -Button Click Simulation not working when embedded This has now been fixed. -Zooming Loop The map scale would reset to max if you zoomed in too far. This has now been fixed. -TMC Disabled by default TMC is now disabled by default in the configuration file due to unsuccessfull testing. -New Hotkeys Hotkeys have been added to perform many new functions - such as; -Cycle Through a dialog -Toggle Map Color Mode -Toggle Map Orientation -Add a speed camera -Custom OSK Keys You can now add custom characters to the on screen keyboard without needing to replace the preset keys -Non-English Regional Settings The frontend now fully supports non-english regional settings -Close Message freezing Destinator When an application sent a window close message to the frontend it froze up. This is now resolved. -Global Hotkeys when embedded An error was occurring when using global hotkeys embedded. This should now be fixed. -Various other undocumented bugs have been fixed
I strongly urge you to back up your maps and delete your C:\DestinatorApps folder before installing this version. If you choose not to, this is the first thing I'm going to tell you to do if any problems arise.
Yes, this is the official version!
Download here [16.1MB]
Destinator 3 For PC! - http://www.map-monkey.co.uk/
Ninja Monkey is offline   Reply With Quote
Advertisement Sponsored links
Old 01-30-2005, 02:02 PM   #2
Raw Wave
Laidback's Avatar
Laidback is on a distinguished road
I got 1st reply!
Laidback
Laidback Carputer
Laidback is offline   Reply With Quote
Old 01-30-2005, 02:14 PM   #3
DJSmiley is on a distinguished road
Cool, we're back
NM: You still have to update the screenshots, its still saying Destinator 3.. And your signature
The links to the older releases are also back online I see..
Nice to see the new domain for mapmonkey now working
DJSmiley is offline   Reply With Quote
Old 01-30-2005, 02:17 PM   #4
superbowl's Avatar
superbowl is on a distinguished road
Hi,
beeing number three ísn´t so bad either ;-)
Already downloaded it.. going to install in my car right now.
Great job, Ninja !
- Stefan
i never drink water cos fish ***** in it. (w.c. fields)
superbowl is offline   Reply With Quote
Old 01-30-2005, 02:27 PM   #5
My Village Called
0l33l's Avatar
0l33l is on a distinguished road
The SDK still won't work with delphi
Code:
unit Unit1; interface uses Windows, Messages, SysUtils, Variants, Classes, Graphics, Controls, Forms, Dialogs, OleServer, MonkeyTalk_TLB, StdCtrls, ExtCtrls; type TForm1 = class(TForm) mm: TMonkeyMessenger; Timer1: TTimer; Label1: TLabel; procedure FormCreate(Sender: TObject); procedure Timer1Timer(Sender: TObject); private { Private declarations } public { Public declarations } end; var Form1: TForm1; implementation {$R *.dfm} procedure TForm1.FormCreate(Sender: TObject); begin mm.Connect; end; procedure TForm1.Timer1Timer(Sender: TObject); begin if mm.Connected = true then label1.caption := 'connected'; end; end.
And when I exit mapmonkey by clicking on the little X I get a nice msvbm60.dll and unknown error But it works perfectly when you click on exit.
0l33l is offline   Reply With Quote
Old 01-30-2005, 02:28 PM   #6
Confusion Master
Enforcer's Avatar
Enforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant future
Quote: Originally Posted by Laidback
I got 1st reply!
Sado
Enforcer is offline   Reply With Quote
Old 01-30-2005, 02:33 PM   #7
Map Monkey Creator
The "Connect" method you're calling isn't part of my SDK, to connect you have to set the "Connected" property to True. Maybe that's what's wrong?
Old 01-30-2005, 02:33 PM   #8
knubile's Avatar
knubile is on a distinguished road
NM. Can you allow installation to install to a specific location again. I used to be able to install to the D drive. No I can't.
It would be greatly appreciated. I already have a dll that works from the D drive. Now I just need your app on the D drive.
Kareem
knubile is offline   Reply With Quote
Old 01-30-2005, 02:36 PM   #9
Map Monkey Creator
Kareem
You mean a cracked DLL?
Old 01-30-2005, 02:39 PM   #10
knubile's Avatar
Two more questions/requests.
1. Is the "Destinator SDK Not For Sale" message right in the middle of the map neccessary? Is that something PowerLoc wanted you to do?
2. A close button next to the scroll buttons on your skin would be great too. It's pretty hard to hit the little X on a touchscreen.
Really good work so far NM. I hope powerloc smartens up.
Old 01-30-2005, 02:45 PM   #11
knubile's Avatar
I just opened it up in a hex editor and changed all the C:\destinatorapps\ to D:\destinatorapps
Old 01-30-2005, 02:50 PM   #12
Map Monkey Creator
1. I didn't put it there (nothing to do with my app), that's part of the SDK demo
2. Why do you need to hit the X? Doesn't HOME do the same thing?
Old 01-30-2005, 02:50 PM   #13
itrends's Avatar
itrends is on a distinguished road
(covered here too)
Dashboard Monkey - CarPC News, reviews, installs and more
itrends is offline   Reply With Quote
Old 01-30-2005, 02:55 PM   #14
knubile's Avatar
So you started using a newer SDK? I've never seen this message before. I wonder if my old sdk files will still work with your new release?
Think you can still allow me to install it in a specified location?
Old 01-30-2005, 02:57 PM   #15
Map Monkey Creator
It's the same SDK, it just hasn't been modified to accept large maps (and the "Demo" message hasn't been removed)
There's nothing to stop you using a previous DLL, but I'm not advising that.
Edit: I'm not reuploading 16mb (forcing everyone who's downloading now to cancel) just so you can install to a different drive. Can't you install to C:\ and just copy it across?
Map Monkey v1.1.3 BETA 3 Ninja Monkey Map Monkey 72 03-29-2005 09:50 AM
Map Monkey final - release data? alanp Map Monkey 1 01-27-2005 06:43 PM
Map Monkey : Screenshots here Ninja Monkey Map Monkey 0 12-25-2004 10:17 PM
Delorme Street Atlas 05 quick review cash_Money GPS 7 12-13-2004 08:31 PM
