01-30-2005, 06:04 PM
#1
Going from Beta3 to realease of 1.1.3
Problem? Or just sats not locked?
I just uninstalled Beta3 adn deleted C:\destinatorapps (backed up maps and .dll) and installed map monkey. This pops up every 5 seconds or so, I'm inside on the laptop so my GPS isnt locked (barely seeing 1 sat) and its snowing outside so im not gonna go out and stand there with the laptop.....
Error Details:
Number: -2147211500
Description: Index out of bounds
Source: AdvGPS_Satellites
Version: 1.1.340
HelpContext: 1000440
HelpFile:
LastDllError: 0
Is this a common thing since the program has No idea where it is on the map or do i have a problem with install? It does this with and withough Adv GPS checked and before and after maps added
Andy
01-30-2005, 06:23 PM
#2
Map Monkey Creator
Vehicle: Toyota MR2 GT T-Bar & VW Golf GT-TDi
Yep, it's because you aren't seeing any satellites, it shouldn't happen with advanced gps off though
Can't believe I missed this! Going to have to release a fix now!
01-30-2005, 06:25 PM
#3
Vehicle: Subaru WRX
Hi
I'm also getting this error.
The messages goes away if I don't use 'Advanced GPS'. Enable that option, and the error box keeps popping up.
thanks
01-30-2005, 06:29 PM
#4
Map Monkey Creator
Can you guys try this:
http://homepage.ntlworld.com/shaunjo...key_SatFix.zip
Should sort both the satellite problem (though untested) and the error when closing Map Monkey via the 'X'
01-30-2005, 06:37 PM
#5
Vehicle: Subaru WRX
Quote: Originally Posted by Ninja Monkey
Nope -
Error Details:
Number: -2147211500
Version: 1.1.342
HelpFile:
LastDllError: 0
Although I am sitting in a basement carpark with no GPS signal.
01-30-2005, 06:54 PM
#6
Map Monkey Creator
01-30-2005, 07:03 PM
#7
Vehicle: Subaru WRX
Yes - that did it.
No more error message popup.
Thanks.
01-30-2005, 07:07 PM
#8
Works
Awesome job!
01-30-2005, 07:14 PM
#9
Vehicle: 2005 Acura TL w/ Navi & BT
NM... sorry for the PM i sent ya, i didnt see your latest thread about PM's.... here ya go... if i use a big map (all of western US), it shows incorrect GPS info. It thinks im somewhere completely different, not to mention it always says that i have "0" satellites acquired all the time. I set the correct COM port and 4800. Any ideas? I can now confirm that its doing that for all the maps i use, even smaller maps. It doesnt show me where i am correctly. (random location)
'05 Acura TL w/ Navi & Bluetooth, JL Audio Cleansweep, JL Audio XR650 CSI, JL Audio XR650 CXI, JL Audio 300/4 Speaker Amp, Eclipse SW6123.4 12" Sub, JL Audio 250/1 Sub Amp, Optima D35 YellowTop Battery http://www.cardomain.com/ride/2184473/1
01-30-2005, 07:17 PM
#10
Map Monkey Creator
Are you sure you have a lock?
01-30-2005, 07:18 PM
#11
i always have 8-10 satellites in my drive way.... very strange... i dunno why it wont see anything now...
01-30-2005, 07:28 PM
#12
now it seems like im gettin half as many satellites than i did b4 even when reverting back to 1.1.3B3... very weird.... hmmm
01-30-2005, 07:46 PM
#13
New Issue with Frodoplayer 1.09 Take 3:
Any idea why the artist - track isnt showing up from frodoplayer? hmmmm, the window bar of mapmonkey is taking over and i cant see the frodoplayer bar on the top... it seems as though the embedded feature isnt working the same in terms of window focus anymore.... hmmmm
01-30-2005, 08:44 PM
#14
Rather than start a new thread...
Next Problem:
MM opens as a new window in Frodoplayer, and is 800x600 vs my 1200x720 (laptop widescreen.....)
01-30-2005, 08:50 PM
#15
Map Monkey Creator
try re-downloading the zip I posted and try again...using "Map Monkey - [GPS]" as the window title
| Thread Tools |
| Display Modes |
Linear Mode
