Here are a couple of launcher applications to help the problems with using Map Monkey in certain front ends.
- FrodoPlayer/MediaCar Frontend Launcher
This launcher has been mainly created to work with frodoplayer, but can be adapted to work in any environment. You can customise the launchers window title and the frontend application to search for (e.g. Frodoplayer, if frodo is found to be no longer running the launcher will close Map Monkey).
Mediacar users don't have to worry about closing map monkey before closing mediacar, the launcher will sort this all out for you.
To Configure
Frodoplayer users:
Don't need to do anything. The default window title is "Destinator 3 - [Dest3.1]" and the default application search is "frodoplayer.exe"
Mediacar etc users:
You need to run the launcher first to create a "mml.conf" file. Open this up in notepad and change the 2nd line to the name of the applications EXE file
Make sure you tell your frontend to run the Launcher as your GPS application rather than Map Monkey directly.
Edit: Also, make sure "Enable Plugin Support" is enabled in Map Monkey configuration
Download Here
