Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > No Longer Supported > Map Monkey
Old 02-22-2005, 02:44 AM   #1
Skorpion's Avatar
Skorpion is on a distinguished road
Question Speed / Red Light Camera
Hello,
A couple of questions:
1. Is there a way of changing the voice from saying "a Gatso has been detected" to "a speed camera has been detected". I see the wav files in the dir, but i can't see anywhere in the ini files (or in the config) to change this?
2. I can add new speed camera's (at varying speeds), but how can i add a red light camera instead? or how can i get the voice to say "speed camera detected" or "red light camera detected" depending on which was coming up.
thanks..
Skorpion is offline   Reply With Quote
Advertisement Sponsored links
Old 02-22-2005, 02:54 AM   #2
2THXTRM is on a distinguished road
Couldn't you just record your own .wav and name it the exact same as the one you are replacing? I would think that as long as they have the same name and are in the same dir the software will play it.
2THXTRM is offline   Reply With Quote
Old 02-22-2005, 03:31 AM   #3
Skorpion's Avatar
Yeah, I did think of doing that, but I'd rather do it the "proper" way. And it won't solve the problem with having a different voice to red light and speed camera's.
Old 02-22-2005, 01:59 PM   #4
Map Monkey Creator
Ninja Monkey's Avatar
Ninja Monkey is on a distinguished road
1. Just delete Warning1_GATSO and Warning2_GATSO and it will revert to using the normal "Speed Camera" alert instead
2. The "Add Speed Camera" function adds a camera to the database under the category "MANUAL". I didn't want to place yet another button for choosing which type of camera due to the fact that you're going to be driving while doing this...In a future version I'll possibly add an optional button to select the type
Destinator 3 For PC! - http://www.map-monkey.co.uk/
Ninja Monkey is offline   Reply With Quote
Old 02-22-2005, 02:29 PM   #5
2Fast's Avatar
2Fast is infamous around these parts2Fast is infamous around these parts2Fast is infamous around these parts2Fast is infamous around these parts2Fast is infamous around these parts2Fast is infamous around these parts
how do i go about removing old camera sites from my database?. i know of a few Gatso's that have been removed, but the warnings are still there.
2Fast is offline   Reply With Quote
Old 02-22-2005, 02:36 PM   #6
Skorpion's Avatar
ok, thanks!
with the removal of speed camera's, the skin i'm using has another button appear when in range of a speed camera which allows you to remove it.
Old 02-22-2005, 02:44 PM   #7
2Fast's Avatar
Thanks, I've not noticed that on mine, i shall have a look tomorrow.
SPEED CAMERA: countries to be included in 1.1.3 miagi Map Monkey 23 12-29-2005 10:05 AM
red light camera avoidance system Chuck Off Topic 46 12-28-2005 06:01 PM
Destinator freezing when you approach a speed camera? Ninja Monkey Map Monkey 10 01-31-2005 06:37 PM
Speed camera detection software on laptop rickyaswell LCD/Display 5 08-26-2004 08:13 AM
Updated Destinator: with Speed/Bearing, Winamp control and Speed Camera Database Confused MediaCar 11 04-12-2004 06:10 AM
Content Relevant URLs by vBSEO 3.3.0
"VaultWiki" powered by VaultWiki v2.5.2.
Copyright © 2008 - 2009, Cracked Egg Studios.Ad Management by RedTyger
