Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Support Software > Map Monkey
Old 02-24-2005, 05:47 AM   #1
please add a Cancel-button to "Add Speed camera" window
AlCapone is offline   Reply With Quote
Old 02-24-2005, 12:52 PM   #2
Map Monkey Creator
Ninja Monkey's Avatar
Either press "Add Speed Camera" again or press the Home Button
Destinator 3 For PC! - http://www.map-monkey.co.uk/
Ninja Monkey is offline   Reply With Quote
Old 02-24-2005, 05:14 PM   #3
Raw Wave
RoyN's Avatar
Somewhat related:
I click on add camera, then on #, then enter speed... no enter button? Is it just a skin problem? I see a "<--" backspace button, a "." button that clears the speed I typed, and a "-" button that also clears the speed...
I only have this skin on this comp so if that is the issue Ill get another one...
thanks!
RoyN is offline   Reply With Quote
Old 02-24-2005, 05:14 PM   #4
Raw Wave
RoyN's Avatar
scrap that.... I just realized that clicking the speed sign again adds it...
what is the . and - though?
thnks!
Old 02-24-2005, 08:52 PM   #5
Map Monkey Creator
the . and - are used when you're on the "Manual Destination" screen to enter coordinates, it just uses the same keypad
Old 02-26-2005, 02:42 AM   #6
which sat nav software are you using which allows you to add speed camera locations and does it have noice guidance
cheers
g1smo is offline   Reply With Quote
Old 02-26-2005, 02:47 AM   #7
code-'s Avatar
omg, are you blind?!
code- is offline   Reply With Quote
Old 02-26-2005, 12:46 PM   #8
Raw Wave
RoyN's Avatar
Seriously welcome to planet earth newbie... go into the forums, go into the software section, and then READ all the forums....(It shouldnt take long to find the answer)
-although with the intelligence display u have provided thus far i could very well be wrong!-
Onscreen keyboard gti Map Monkey 40 06-14-2008 10:00 PM
RELEASE: Map Monkey v1.1.3 Ninja Monkey Map Monkey 161 05-03-2007 05:40 PM
Add dvd button in skin.ini justme1 FrodoPlayer 5 12-27-2004 08:47 AM
volume button speed Bobby Digital FrodoPlayer 2 11-18-2004 12:51 PM
I want to add a power button on my dash. Which can i use? Sonicxtacy02 General Hardware Discussion 2 10-25-2004 03:17 PM
