03-14-2005, 02:29 PM
#16
Para Laura
Vehicle: Xterra SE supercharged
Thanks for you answer ninja
03-16-2005, 04:35 PM
#17
Hi NM,
I have a doubt, when launch for before famous the Mapmonkey time that informs to me that I do not have the connected antenna. If I exit and I reopen the Mapmonkey application not it perceives me that I do not have the connected antenna gps. Normal ? Moreover as I make to insert the push-button in order to remove the camera? Famous that in the skin the key exists in order to add the camera but does not exist the key in order to remove it. Thanks
03-17-2005, 01:30 PM
#18
Map Monkey Creator
Vehicle: Toyota MR2 GT T-Bar & VW Golf GT-TDi
Quote: Originally Posted by manung
Hi NM,
Was this translated by software? it hurt my brain!
The remove-camera button only appears when a camera is being detected...I think that's what you're asking about anyway
03-17-2005, 02:59 PM
#19
Thanks for Speed button remove now is OK.
Now I wanted to know why the vocal message of "GPS NOT FOUND" appears only once after the first installation. If I close then and I reopen MM does not inform to me more than the GPS it is not present.
I hope that you understand to me.
Excuse for my English but I will try to improve.
P.S.
My BU 303 is not connected
03-18-2005, 03:18 PM
#20
Vehicle: Ford Focus 2.0 Zetec
I tried this fix and I lost the satellite number upleft and the speed downright. Do you know what can I do to restore them? And how can I run mapmonkey from frodoplayer without problems? No now it opens like a second application, I haven't the possibillity to hide the mapmonkey, it is impossible to ee the title of the song I hear etc.
03-18-2005, 03:30 PM
#21
Raw Wave
Vehicle: 1999 Range Rover 4.6HSE
maybe it cleared your config for advanced gps mode? try running config tool and make sure it is there
03-18-2005, 03:40 PM
#22
Ok, I'll check it but I think It marked as before. Do you know something about frodoplayer?
03-19-2005, 05:44 AM
#23
Vehicle: 2001 Volvo V70
Quote: Originally Posted by Ninja Monkey
-ETA Distance On the fly
The ETA has been updated with an experimental new method that allows
the distance to be calculacted in real time rather than at the
beginning of each maneuver. ETA's should be more accurate this way.
This ETA works much better, but is it not possible to get the ETA from Destinator (the one that shows down to the left in the light blue field when routing) ? The internal ETA seems to be more accurate and does not change so much with speed...
03-19-2005, 07:02 AM
#24
Vehicle: 1999 Isuzu Vehicross
what's wrong with me, I can't find the mml.conf file for mapmonkey
[------|-] 95% computer... is it ever really done?
www.vehicross.info for all you VXer's
03-20-2005, 11:14 AM
#25
-Voice Muting
A new skinnable button has been added that enables you to
quickly enable and disable the turn-by-turn voice directions.
An example button has been added to the "Classic" skin.
Is this command possible to send thru MonkeyTalk/Winsock ??? And if so, what command do I use ?
03-20-2005, 04:25 PM
#26
Map Monkey Creator
until the DLL is updated, this is the best you can do:
MonkeyTalk.Custom("Hotkey_CMD|FE_VOICEPROMPTS")
which will toggle between on/off, although you won't be able to retrieve the current status
03-20-2005, 05:21 PM
#27
Thanks, just what I was looking for !
03-20-2005, 08:33 PM
#28
My Village Called
Vehicle: 1995 Lexus SC300 1997 Mazda Miata
How about scroll up/down (the list, not the map) for the DLL?
03-22-2005, 11:41 PM
#29
Vehicle: 88 skyline
ninja monkey you rule, i love you.
map monkey is awsome too.
CarPC Status:
Hardware: 100%
Software: 100%
Case Install: 100%
Dash Install: 100%
Car Install: 100%
crap factor: 100%
new carpc finished, thinking of way to mount HDD
and not installed yet.
03-23-2005, 07:08 AM
#30
Map Monkey Creator
MonkeyTalk.Custom("Hotkey_CMD|FE_SCROLLDIALOG_UP")
MonkeyTalk.Custom("Hotkey_CMD|FE_SCROLLDIALOG_DOWN ")
| Thread Tools |
| Display Modes |
Linear Mode
