03-11-2005, 06:11 PM
#1
Map Monkey Creator
RELEASE: Map Monkey v1.1.348 (Hotfix)
Code:
[v1.1.348 Official Hotfix]
*New Features*
-Voice Muting
A new skinnable button has been added that enables you to
quickly enable and disable the turn-by-turn voice directions.
An example button has been added to the "Classic" skin.
-Optional Alternative OSK Method
In the skin.ini you can now specify to use an alternative
method for sending the key. This will help in cases where
certain foreign keys are sent incorrectly (e.g. í)
-Automatic Reconnect of GPS
If automatic reconnection is enabled, as well as reconnecting
when returning from hibernate, Map Monkey will also attempt
to automatically reconnect the GPS when gaining a signal
after previously losing it.
-Optional Height Offset of Mapping Window
You can now specify a "HeightOffset" value in the settings file
to increase / decrease the height of the mapping window. This can
be used to hide the default Destinator status window.
-SDK Hotkey Command
A new SDK command has been added to allow developers to call one
of the commands used in the Hotkeys.ini file. This enables extra
functions such as scrolling dialogs and opening / closing
menus to become available.
This must be called using the "Custom" method.
e.g.
MonkeyTalk.Custom("Hotkey_CMD|FE_EXIT")
*Changes / Fixes*
-New Hotkeys
Hotkeys have been added to do the following :
-Toggle between map views
-Activate 2D View
-Activate 3D View
-Activate Birds Eye View
-Toggle Turn-By-Turn Directions
-ETA Distance On the fly
The ETA has been updated with an experimental new method that allows
the distance to be calculacted in real time rather than at the
beginning of each maneuver. ETA's should be more accurate this way.
-Reconnecting after hibernate
A time delay has been introduced before Map Monkey will reconnect the
GPS device after returning from hibernate. This may help with
problems in connecting the COM port before windows has
re-detected it.
-Speed Camera Notification
You can now click an empty space in the speed camera notification box
to hide it
Download here [594KB]
03-11-2005, 06:53 PM
#2
Cool. Looking forward to trying this tomorrow as there's a fix in there for me!
Ric.
03-11-2005, 07:04 PM
#3
It ain't easy being a green moderator
Location: Steps out the front of Henson's workshop or Sydney
good work NM.
03-12-2005, 01:19 AM
#4
03-12-2005, 05:55 PM
#5
Map Monkey error with new Hotfix
Hi,
I just installed the new hotfix. However, whenever I try to close the menu dialog (by clicking the "X"), I get the following error:
Error Details:
Number: 9
Description: Subscript out of range
Source: MainMenu_MouseDown
Version: 1.1.348
HelpContext: 1000009
HelpFile:
LastDllError: 0
Is anyone else seeing this?
03-12-2005, 07:53 PM
#6
Map Monkey Creator
You need to add a new item in your skin.ini for "QuickMute" (all the default skins have had this updated but custom skins like yours will need altering)
e.g:
[Main Menu]
QuickMute=-1,-1,-1,-1
03-12-2005, 07:57 PM
#7
Para Laura
How to install the new hotfix??
just unzip the files in to destinatorapps???
03-12-2005, 09:51 PM
#8
e.g:
[Main Menu]
Ninja Monkey,
That was exactly the problem! Thank you very much for a great program.
03-13-2005, 03:43 AM
#9
Map Monkey Creator
Just run the executable and let it extract to "C:\"
this will do everything you need
03-13-2005, 02:47 PM
#11
Map Monkey Creator
Quote: Originally Posted by cdevelasco
Yes
03-13-2005, 02:49 PM
#12
Excellent!
03-13-2005, 05:15 PM
#13
The Vauxhall Vectra Project
FANTASTIC - Thanks
Terran
PS TMC ??? lol
03-13-2005, 11:42 PM
#14
Para Laura
Thanks ninja monkey....
P.S:for the others skins, we have to make the "mute" botton ans place on the main menu???
03-14-2005, 07:44 AM
#15
Map Monkey Creator
You can place it on the Main Menu or on both the Left and Right toolbars
| Thread Tools |
| Display Modes |
Linear Mode
