Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > No Longer Supported > Map Monkey
Old 07-21-2005, 12:49 PM   #1
bigmac999's Avatar
bigmac999 is on a distinguished road
GPS wont work.
I recently had to reinstall XP on my car PC along with everything else. I am using a Holux GM-210 USB mouse.
Now, when I launch MM, it will detect my location via GPS, then after about 5 seconds, a red cross appears on the position marker and voice says "GPS NOT FOUND." If I go into GPS settings, it will find the GPS on the correct COM port, but will not start it up again. If I exit MM and relaunch, it does exactly the same again.
I have uninstalled/reinstalled the GPS drivers loads of times, but still no joy. I used this exact same setup before and had no problems.
The green light on the GPS flashes continuously, I remember it always stayed on before.
Any on have any ideas?
bigmac999 is offline   Reply With Quote
Old 07-21-2005, 01:02 PM   #2
Matthew230 is on a distinguished road
Check you've installed all latest releases and hotfixes.
GPS is fickle. Unplug the reciever reboot and shut down and plug back in and fire back up.
Check in MM configuration that you have auto detect.
Utilise NMEA not SiRF
Try checking the automatice GPS reconnect in MM configuration, (or unchecking it if already enabled)
Matthew230 is offline   Reply With Quote
Old 07-21-2005, 01:56 PM   #3
bigmac999's Avatar
Top man!
Job done, thanks for your help.
Alturion Professional Advanced GPS 6 - The New D3 ? Is There A SDK ? ccsnet GPS 91 11-07-2006 05:47 PM
OEM GPS mod. Writeup + Pics IntellaWorks Hardware Development 67 07-04-2006 03:59 AM
GlobalSat BT-338 Review tom2112 The Review Palace 8 06-27-2005 12:02 PM
My GPS scenario & Bluetooth quest. gizak GPS 13 04-12-2005 01:11 PM
any gps handhelds work with copilot? aoLhaTer GPS 5 07-27-2003 05:08 AM
