Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > No Longer Supported > Map Monkey
Old 08-30-2005, 12:35 PM   #1
surfatwork is on a distinguished road
Feature request: speed camera notifications based on current speed
Ninja, thanks for a very good and robust piece of kit. i have never had MapMonkey crash (though other bits have) so I am well impressed.
as you probably know, the world's favourite road, the M25 is festooned with speed cameras - so much so that there is pretty much a continuous stream of warnings from MapMonkey - and I cant listen to any music. here's a request:
Would it be possible for MapMonkey to warn of impending speed cameras only if the current speed is greater than the speed camera limit?
Maybe this could be a switchable option i.e. you can choose to have "all" cameras announced or to use the Smart announcements that also check your current speed.
surfatwork is offline   Reply With Quote
Old 08-31-2005, 04:09 PM   #2
Map Monkey Creator
Ninja Monkey's Avatar
Ninja Monkey is on a distinguished road
It already does, if you have "Logic Mode" enabled. This won't work if the database doesn't have the speed limit for the camera though
Destinator 3 For PC! - http://www.map-monkey.co.uk/
Ninja Monkey is offline   Reply With Quote
Old 08-31-2005, 07:01 PM   #3
Pentode is on a distinguished road
Had this too between the M40 and M23 CCW - virtually non stop speed cameras. Any chance of a button to disable speed camera voice prompts on the fly. It might make sense to reset back to enabled it on every reboot too.
Pentode is offline   Reply With Quote
SPEED CAMERA: countries to be included in 1.1.3 miagi Map Monkey 23 12-29-2005 10:05 AM
Map Monkey v1.1.3 BETA 3 Ninja Monkey Map Monkey 72 03-29-2005 09:50 AM
Destinator freezing when you approach a speed camera? Ninja Monkey Map Monkey 10 01-31-2005 06:37 PM
Speed camera detection software on laptop rickyaswell LCD/Display 5 08-26-2004 08:13 AM
Updated Destinator: with Speed/Bearing, Winamp control and Speed Camera Database Confused MediaCar 11 04-12-2004 06:10 AM
Content Relevant URLs by vBSEO 3.3.0
"VaultWiki" powered by VaultWiki v2.5.2.
Copyright © 2008 - 2009, Cracked Egg Studios.Ad Management by RedTyger
